HDMI Receptacle? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 01-04-2014, 02:00 PM - Thread Starter
derekarita's Avatar
Just got a 60ZT60 and will be wall mounting it.  I want to have no wires showing, so I'm going to run power to behind the ZT60, however I'm not sure what to do about the HDMI cable/cables.  Does anyone make an HDMI receptacle that I will allow me to run the wires in the wall or do I have to run HDMI cables directly from equipment to ZT60?  If I have to direct connect, can I put those in the wall?
derekarita is offline
post #2 of 9 Old 01-04-2014, 02:35 PM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 519 Post(s)
Liked: 775
There are lots of different HDMI wall plates available in various combinations and configurations (1 or 2 HDMI, or HDMI and Eithernet, or HDMI and RF, HDMI and Component, etc).
Search Google Images for "HDMI Wallplate", and poke around Amazon, Monoprice, EBay, and even Home Depot and Lowes websites and see what's out there.
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #3 of 9 Old 01-04-2014, 03:28 PM
Latinoheat's Avatar
Quoted: 1113 Post(s)
Liked: 889
I bought mine at Monoprice, very good quality and excellent price. Work perfect.
Media room- LG 4K OLED EG9600, Pioneer Elite VSX-90, Samsung 4K K8500, Klipsch Gallery G28's, Klipsch Sub 12, Klipsch RS-52 II, Optik HD cable
Living room- Sony 4K 79XBRX900B, Onkyo RC-360,HTPC, Klipsch Reference R-62II, Rc52II,PS4
Gaming room -Panasonic ST60, PS3, Wii
Latinoheat is offline
post #4 of 9 Old 01-04-2014, 09:26 PM
olyteddy's Avatar
Quoted: 531 Post(s)
Liked: 931
To keep the connection count down you can also use a plate like one of these: http://www.amazon.com/s/ref=nb_sb_ss_i_1_14?url=search-alias%3Daps&field-keywords=av+wall+plate&sprefix=a%2Fv+wall+plate%2Caps%2C225&rh=i%3Aaps%2Ck%3Aav+wall+plate
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #5 of 9 Old 01-05-2014, 06:44 AM - Thread Starter
derekarita's Avatar
I think I must be looking for a wall plate, with mulitple female HDMI ports to put behind the TV and down lower on the wall.  Question is, what goes in between?  Does an HDMI cable simply plug into the back of the wall plate, from port to port?
post #6 of 9 Old 01-05-2014, 07:17 AM
olyteddy's Avatar
Quoted: 531 Post(s)
Liked: 931
Yes. Adding 4 more connections per HDMI run.
olyteddy is offline
post #7 of 9 Old 01-05-2014, 09:19 AM
"Don't PM Me Bro"
Quoted: 519 Post(s)
Liked: 775
Just got a 60ZT60 and will be wall mounting it.  I want to have no wires showing, so I'm going to run power to behind the ZT60, however I'm not sure what to do about the HDMI cable/cables.  Does anyone make an HDMI receptacle that I will allow me to run the wires in the wall or do I have to run HDMI cables directly from equipment to ZT60?  If I have to direct connect, can I put those in the wall? ....... I think I must be looking for a wall plate, with mulitple female HDMI ports to put behind the TV and down lower on the wall. Question is, what goes in between? Does an HDMI cable simply plug into the back of the wall plate, from port to port?
What exactly are you doing with that wall and wiring? How are you getting the wiring and power cables inside the wall? Are you opening up the drywall and exposing the bare wall studs? Are you just running the wires down to the components directly below the TV? Or running them to an equipment closet nearby or in another room etc? That will help folks direct you to specific products that will work best for your particular install. There are a LOT of different ways to do this stuff.
Randy
post #8 of 9 Old 01-05-2014, 09:42 AM - Thread Starter
derekarita's Avatar
Regular construction wall between 2 rooms.  The plan is to simply install retrofit boxes where I need them.  There's power directly below where the TV will be mounted.  Equipment will likely be directly below the wall mounted TV or close to it.  I don't want to see any wires below the TV, running to the equipment, so I'd like to have all cables in the wall.  I may also add a blank receptacle for future cable runs, like ether net.  I don't remember who makes them, but there are some nice wall plates that allow you to just pop in different kinds of connectors, as needed.
post #9 of 9 Old 01-06-2014, 08:23 AM
turnbowm's Avatar
Quoted: 51 Post(s)
Liked: 59
The Legrand/Wiremold CMK70 Power Cable kit might satisfy your needs. Good quality and very easy to install. The power cable itself is Romex, so it's code-compliant. Make sure that the HDMI cables you use are rated for in-wall use (CL2).
http://www.homedepot.com/p/Wiremold-Legrand-Flat-Screen-TV-Cord-and-Cable-Power-Kit-White-CMK70/203227289?cm_mmc=SEM|THD|G|VF|D27E|Electrical|ModelNumbers&skwcid=AL!3360!3!20814786397!e!!g!!wiremold%20cmk70&ef_id=UsiihwAABFECvluI:20140106161203:s#
turnbowm is offline
Panasonic Viera Tc P60zt60 60 Inch Plasma Tv
