Pioneer 8G 9G Kuro Reset Guide - Page 25 - AVS Forum | Home Theater Discussions And Reviews
 101Likes
post #721 of 2396 Old 02-22-2014, 11:50 AM
qwknuf6's Avatar
Quoted: 132 Post(s)
Liked: 166
Originally Posted by makaveddie81 View Post
So you tweaked it just to see if you could improve on dnices work?
Im interested to know your current rstp and s1,s3,s4 values, if you dont mind.
rst p 002
fs1d 126
fs3d 116
fs4d 137
untouched as far I know hours are 860
if i can help let me know , I can do some testing but I don't want to reset my panel
qwknuf6 is online now
post #722 of 2396 Old 02-22-2014, 11:58 AM
VidPro's Avatar
Quoted: 88 Post(s)
Liked: 109
Well I can't be sure if it worked because I thought 12 was the value for RSTP. I put everything back to what I wrote down as my defaults before the reset last night. I lowered RSTP to 1 and other than black rain (which is what I got the very first reset) there were no visible issues. On close inspection I had to raise SUS back up from 128 to near 150 to eliminate magenta misfires on white.
The television screen is the retina of the mind's eye.
VidPro is offline
post #723 of 2396 Old 02-22-2014, 12:06 PM
qwknuf6's Avatar
Quoted: 132 Post(s)
Liked: 166
no , I just did some trial and error , adjusting only one thing at a time , making note of all factory settings , I could not believe how dark the panel became with the fsad adjusted to 100.
this was all due to learning to correct magenta pixels on moving images , dark to light , on a different display.
post #724 of 2396 Old 02-22-2014, 12:14 PM
Stu03's Avatar
Quoted: 69 Post(s)
Liked: 169
name="VidPro" url="/t/1510500/pioneer-8g-9g-kuro-reset-guide-updated-2014-02-21/680_40#post_24394414"]
Interesting. RSTP was set at 12 the first time I entered the SM. At 2 there was only black rain and it seemed worse than usual. That's why I raised it. What seemed weird was the setting back to 12 didn't do anything to the black level that I could see.
Stu, I did say that but it was still there on menus. I jumped the gun a bit.
Perhaps you did but...
I have been doing this stuff long enough to know what's what - two years and three months to be exact.
RSTP being lowered isn't for reset pulse and hour meters.
If you put RSTP at default - SUS at a sensible post reset value - (YKNOFS1 at default or a little bit higher than default (because you have no white misfires post reset)... YKNOFSA up (until) misfires on moving images subside...
Then you will have black lower than NIB KRP500M minus the Kuro crying because it feels under the weather driven wise.
People (not you) who haven't been doing this long should not confuse reset and tweaked Kuro's with non reset Kuro's and tweaks.
They are hugely different
Stu03 is offline
post #725 of 2396 Old 02-22-2014, 12:15 PM
makaveddie81's Avatar
Quoted: 477 Post(s)
Liked: 273
Yeah, I set mine to the defaults listed in the service manual.
Do this (if you'd like):
1. Set voltages to the below values (I'm pretty sure you have a 101FD or KRP500M, as these values are for those displays).
SUS 128
VOF 113
VRP 18
XPOFS1 85
XPOFS2 63
YKNOFSA1 138
YKNOFSA3 128
YKNOFSA4 149
YKNOFSAD 128
2. Reset your display with these commands in this order.
CHM
CPM
CSD
CPD
CPC
CMT
3. Turn off KURO and unplug for 5 minutes.
4. Plug back in and turn on KURO.
5. See if you have any artifacts but don't adjust anything.
6. Set RSTP to 2 to reduce black level.
7. If any artifacts, try removing them by adjusting the separation between 3 and 4. Once you find a sweet spot where artifacts are reduced, adjust S1, S2 and S3 up and down (all at the same time and amount) to see which direction provides an improvement. Find a sweet spot but dont got below factory minimum.
8. If any remaining artifacts reduce VOL OFFSET to factory minimum.
9. If any remaining artifacts, increase SUS.
Pioneer Kuro KRP-500M
Pioneer Kuro PRO-141FD
Pioneer Kuro PRO-111FD x 2
Pioneer Kuro PDP-5020 x 2
makaveddie81 is offline
post #726 of 2396 Old 02-22-2014, 12:17 PM
Quoted: 477 Post(s)
Liked: 273
Originally Posted by qwknuf6 View Post
rst p 002
fs1d 126
fs3d 116
fs4d 137
Set SAD to 128 and set S1 to 117, S3 to 107, and S4 to 128 and report back results. I bet you'll have the same deep blacks. Those are the settings that I used on my 101FD with 900 hours before resetting. It was absolutely perfect.
post #727 of 2396 Old 02-22-2014, 12:19 PM
Stu03's Avatar
Quoted: 69 Post(s)
Liked: 169
Makaveddie81 why are you encouraging people to lower rstp on Kuro's that have been reset?
Stu03 is offline
post #728 of 2396 Old 02-22-2014, 12:21 PM
Quoted: 477 Post(s)
Liked: 273
If this was directed at me, I am simply posting what worked for my RESET display. If not meant for me, then move along.
post #729 of 2396 Old 02-22-2014, 12:21 PM
qwknuf6's Avatar
Quoted: 132 Post(s)
Liked: 166
ok I will try them and report back
post #730 of 2396 Old 02-22-2014, 12:22 PM
Quoted: 477 Post(s)
Liked: 273
Because it worked on mine after I reset it and lowered blacks without having to tweak anything else. Blacks looked grey with it at 18. They can put it back to where it was if they encounter issues, no damage done.
post #731 of 2396 Old 02-22-2014, 12:23 PM
VidPro's Avatar
Quoted: 88 Post(s)
Liked: 109
SUS 128
VOF 113
VRP 18
XPOFS1 85
XPOFS2 63
YKNOFSA1 138
YKNOFSA3 128
YKNOFSA4 149
YKNOFSAD 128
CHM
CPM
CSD
CPD
CPC
CMT
As soon as it gets dark in a couple of hours I'll do that.
Is there a link for the service manual? I have a 500M by the way.
VidPro is offline
post #732 of 2396 Old 02-22-2014, 12:31 PM
Stu03's Avatar
Quoted: 69 Post(s)
Liked: 169
[ name="makaveddie81" url="/t/1510500/pioneer-8g-9g-kuro-reset-guide-updated-2014-02-21/720_40#post_24394589"]
Because it worked on mine after I reset it and lowered blacks without having to tweak anything else. Blacks looked grey with it at 18. They can put it back to where it was if they encounter issues, no damage done.[/quote]
Well if black looks grey at 18 post reset when the pulse meter has began again - then something is deeply wrong.
Because if you actually read back when all this started people who reset couldn't tell the panel was on in blackout conditions who had the measured MLL to prove it - so close to zero. ..
Stu03 is offline
post #733 of 2396 Old 02-22-2014, 12:34 PM
Quoted: 477 Post(s)
Liked: 273
Because if you actually read back when all this started people who reset couldn't tell the panel was on in blackout conditions who had the measured MLL to prove it - so close to zero. ..[/quote]
Blacks looked grey on the 5% grey window and low apl content. Sorry should have clarified that.
post #734 of 2396 Old 02-22-2014, 01:13 PM - Thread Starter
pg_ice's Avatar
Liked: 179
here is a picture showing the differences between different RSTP values.
this was taken 2 months ago when i tested it
i think the effect lowering or raising RSTP AFTER the reset isnt that huge as it may be before the reset.
i have a default RSTP of 016
and i also think that it looks best there.
its almost that you get back the red tone (red color higher from the historgram) if you set RSTP to low.
over exposed 10% window from camera not post.
my eyes couldnt see any difference between 001 and 016 but the camera captured it
over 016 you could notice that the blacks got brighter
30sec exposure time on all images just different RSTP values.
Edit: this test was done after the first reset.
pg_ice is offline
post #735 of 2396 Old 02-22-2014, 01:30 PM
Quoted: 477 Post(s)
Liked: 273
same exposure on all images just different RSTP values.
I noticed a difference once i raised rstp over the 8 mark.
post #736 of 2396 Old 02-22-2014, 01:53 PM
Stu03's Avatar
Quoted: 69 Post(s)
Liked: 169
I can see the red clearly @ 1
Stu03 is offline
post #737 of 2396 Old 02-22-2014, 01:58 PM
Quoted: 477 Post(s)
Liked: 273
I guess all kuro's are different. No hint of red here... only inky blacks. Watched sinister last night - an amazing choice to showcase blacks - and my kuro handled it like a champ
post #738 of 2396 Old 02-22-2014, 02:15 PM - Thread Starter
pg_ice's Avatar
Liked: 179
yes thats why i think its impossible to use any "new" recomended settings after the reset.
it gets more complicaded than it needs to be.
Do the reset with the DEFAULT voltages. (from your advise)
IF you get problems after the reset or want to tweak MLL even more.
Adjust some voltages INSIDE the adjustments ranges.
when you are done do another reset.
i think that Every single problem that you could possible get after the reset has been talked about in this thread.
So no problem for new users to get rid of them with all the knowledge that we have here.
i still think your new workflow( -rstp maybe) and the new way of adjusting the voltages inside the adjustment ranges is the way to go to get the best result = less problems
pg_ice is offline
post #739 of 2396 Old 02-22-2014, 02:21 PM
Quoted: 477 Post(s)
Liked: 273
Which is why i firmly believe that the non reset method must be tried first. All kuros react differently after being reset, so there is no standard way of resolving post reset issues. I guess I was lucky enough to only have to adjust rstp.
post #740 of 2396 Old 02-22-2014, 03:35 PM - Thread Starter
pg_ice's Avatar
Liked: 179
semi off topic
was reading about buzzing problems for other brands.
has anyone noticed that you reduce the buzzing sound as soon as you set VOL SUS right while displaying a 100% white field?
if i set VOL SUS a tad lower it starts to scream
clean field= less buzzing
dirty field with magenta sparkles= higher buzzing
any theories why the buzzing sound is connected to VOL SUS?
i know that the right voltage to the transistors makes them more quiet.
can the magenta sparkles be connected with wrong voltages to the transistors?
pg_ice is offline
post #741 of 2396 Old 02-22-2014, 04:21 PM
VidPro's Avatar
Quoted: 88 Post(s)
Liked: 109
I just spent an hour in the SM trying to reset as discussed. I could not get a satisfactory balance between artifacts and black level. So I put everything back to defaults pre reset. I was happy with the way it looked before this last round of tweaking. The only variable that I can think of is hours collecting on the panel. I'm not going to make a judgement on my settings until the hours build up a bit.
VidPro is offline
post #742 of 2396 Old 02-22-2014, 05:16 PM
Quoted: 477 Post(s)
Liked: 273
Yeah. Im starting to think the low hours on my panel made my reset headache free.
post #743 of 2396 Old 02-22-2014, 10:39 PM
Quoted: 477 Post(s)
Liked: 273
I just reset my 101fd two more times with my method and got the same results. No artifacts post reset. Set rstp to 1 to get superb blacks and called it a day. I do have black rain (minor) but I can live with it.
I truly believe rstp is the cause for red tint, which is why i set it to 1 from the get go after the reset. I leave s1, s2 and s4 at default so I can have headroom if i need to make adjustments in the future.
post #744 of 2396 Old 02-22-2014, 10:52 PM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
If you adjusted the necessary values to remove the black rain artifact, would you still qualify your levels as "OLED blacks?" This is one reason why I stated previously that working outside of the specs necessarily results in compromise. The same would be true for service menu adjustment of any TV ever manufactured.
vinnie97 is offline
post #745 of 2396 Old 02-22-2014, 11:20 PM
Quoted: 477 Post(s)
Liked: 273
I was able to lower blacks even further by reducing s1, s3 and s4 to the point where I would classify them as oled blacks. However, black rain got worse. The difference in black levels didnt justify the increase in black rain, so I left s1, s3 and s4 at default. I think these settings will future proof my display against red tint (with rstp at 1) and black level rise, as i will have enough headroom to reduce s1, s3 and s4 if needed.
I wouldnt classify them as oled blacks with my current settings, as oled remains inky black even on a black field. They are pretty damn close though, especially when there is content on the screen.
Judging from the results posted on this thread, it seems that the higher the hour count, the more risky the reset.
vinnie97 likes this.
post #746 of 2396 Old 02-23-2014, 01:39 AM - Thread Starter
pg_ice's Avatar
Liked: 179
So you still think we must have the black rain effect to get OLED blacks on regular content. ?
I bet you think we are sitting and watching movies with huge black lag/ black rain pouring all over the screen into a total mess just to have these OLED blacks ? haha.
No way a Kuro owner would sacrifice picture quality to get these blacks.
I think i can speak for everyone.
You just sitting and speculating and drawing conclusions.
You should see these OLED blacks live instead!
pg_ice is offline
post #747 of 2396 Old 02-23-2014, 04:24 AM
VidPro's Avatar
Quoted: 88 Post(s)
Liked: 109
That too but I think that panel needs to accumulate some hours after the reset to start really seeing the benefit. That's been mentioned here. I also think we are all using different methods to check for black rain so I'm not sure how off my higher hour panel is to your lower hour panel.
Anybody know what the long term issues might be under-driving the panel in way that is showing black rain?
VidPro is offline
post #748 of 2396 Old 02-23-2014, 08:38 AM - Thread Starter
pg_ice's Avatar
Liked: 179
cant you get rid of black rain on regular content?
is it still Apple tv photos that is the problem?
pg_ice is offline
post #749 of 2396 Old 02-23-2014, 08:48 AM
VidPro's Avatar
Quoted: 88 Post(s)
Liked: 109
I've noticed it on credits this last reset. I'm not concerned with ATV photos anymore. smile.gif
VidPro is offline
post #750 of 2396 Old 02-23-2014, 09:10 AM - Thread Starter
pg_ice's Avatar
Liked: 179
Ok then you must be really underdriving it.
I dont see it on the credits here.
It sounds like raising S3 and S4 +10 should be enough for you.
You should still have the same blacks.
pg_ice is offline
Pioneer Elite Kuro Pro 1150hd 50 Inch Plasma Hdtv
