Pioneer 8G 9G Kuro Reset Guide - Page 34 - AVS Forum | Home Theater Discussions And Reviews
 105Likes
post #991 of 2441 Old 03-07-2014, 12:43 PM
ShockFett's Avatar
Quoted: 22 Post(s)
Liked: 128
Originally Posted by makaveddie81 View Post
It's been reported that reset panels improve over time. Mine has about 6 hours after this last reset.
I remember a post where you specifically stated you could only see bar 20 and up and called it "good enough". Correct me if I'm wrong.
Ed, where did you see that it improves over time just curious?
ShockFett is offline
post #992 of 2441 Old 03-07-2014, 12:44 PM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
Judging by your endless support for the ZT on Kuro threads, seems like you needed a refresher.
BTW, what type of Kuro did your ZT replace? Just curious.
Well, I wasn't asking if it was an upgrade either. I pretty much already stated it was since I had an untweaked 111FD.
And so sorry for misusing the OLED blacks phrase. I should have used the more appropriate bezel-blending.
vinnie97 is offline
post #993 of 2441 Old 03-07-2014, 12:46 PM - Thread Starter
pg_ice's Avatar
Liked: 179
I think I'll go by what I see with the GetGrey calibration disc, which is what most pro's use. .
i heard that D-Nice uses real world content when setting shadow details not patterns
Mine are all set to 4 (when using KuroControl)
is that the 9 point gamma settings or the usual ones?
pg_ice is offline
post #994 of 2441 Old 03-07-2014, 12:49 PM
ShockFett's Avatar
Quoted: 22 Post(s)
Liked: 128
Was your 111 pro calibrated if so by whom? Is your ZT 65?
We know you feel it's a upgrade. Again glad you are enjoying the zt it's a great panel.
post #995 of 2441 Old 03-07-2014, 12:52 PM - Thread Starter
pg_ice's Avatar
Liked: 179
you can see that after one week
i can see it already.
less black rain in the menus.
still the same blacks.
remember that the voltages is driven by algorithms and meters that changes over time
pg_ice is offline
post #996 of 2441 Old 03-07-2014, 12:53 PM
ShockFett's Avatar
Quoted: 22 Post(s)
Liked: 128
Oh ok thanks. I guess these are the meters volts we can't see in the menu?
post #997 of 2441 Old 03-07-2014, 12:53 PM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
111FD was calibrated by David Abrams of Avical fame. The latter hasn't been yet.
vinnie97 is offline
post #998 of 2441 Old 03-07-2014, 12:59 PM
makaveddie81's Avatar
Quoted: 514 Post(s)
Liked: 279
Then yes, I would consider that an upgrade. Not sure why there are some that bash you for your replacement.
JVC DLA-RS4810
Pioneer Kuro KRP-500M
Pioneer Kuro PRO-141FD
Pioneer Kuro PRO-151FD
Pioneer Kuro PRO-111FD
Pioneer Kuro PDP-5020
makaveddie81 is offline
post #999 of 2441 Old 03-07-2014, 01:00 PM
ShockFett's Avatar
Quoted: 22 Post(s)
Liked: 128
Ok good then at least you were able to have a better contrast between the two.
Yeah I'm excited to get my zt calibrated. I really feel this will make a significant improvement. Zt moves so much otb. I really don't care for the pre sets. Glad you enjoy the ZT bro. So do I.
post #1000 of 2441 Old 03-07-2014, 01:01 PM
Quoted: 514 Post(s)
Liked: 279
9 point. Not sure what he uses, as I walked out the room when he calibrated. I do know that he disconnected the ps3 from my sound projector and said something along the lines of "I'll just run it off the sound projector". Pattern generator?
JVC DLA-RS4810
post #1001 of 2441 Old 03-07-2014, 01:02 PM
ShockFett's Avatar
Quoted: 22 Post(s)
Liked: 128
I think because he loves to push buttons. It's a love hate relationship lol!
post #1002 of 2441 Old 03-07-2014, 01:03 PM
Quoted: 514 Post(s)
Liked: 279
I noticed an improvement on one of my many resets that lasted more than a week.
JVC DLA-RS4810
post #1003 of 2441 Old 03-07-2014, 01:04 PM
ShockFett's Avatar
Quoted: 22 Post(s)
Liked: 128
You have submitted to the dark side. Let your reseting flow! 😄
post #1004 of 2441 Old 03-07-2014, 01:05 PM
Quoted: 514 Post(s)
Liked: 279
I'm pretty sure the service manual makes a differentiation between adjustment values and actual volts. What you see in the service menu is most likely adjustment values. Actual voltages can only be acquired by measuring with a voltmeter.
JVC DLA-RS4810
post #1005 of 2441 Old 03-07-2014, 01:06 PM
Quoted: 514 Post(s)
Liked: 279
I actually enjoy the back and forth bantering between Stu and Vinnie. Admittedly, I love Vinnie's writing style.
JVC DLA-RS4810
post #1006 of 2441 Old 03-07-2014, 01:09 PM
ShockFett's Avatar
Quoted: 22 Post(s)
Liked: 128
Instead of the itchy and scratchy show. It's the Stu and Vinnie shooooooow! 😀
Stu03 likes this.
post #1007 of 2441 Old 03-07-2014, 01:20 PM
tubby497's Avatar
Quoted: 149 Post(s)
Liked: 395
Simply tweaking voltages and not doing the reset, will that improve black level without any issues?
tubby497 is offline
post #1008 of 2441 Old 03-07-2014, 01:33 PM
ShockFett's Avatar
Quoted: 22 Post(s)
Liked: 128
It may or may not. Really depends on your panel. All you can do is try. You will not hurt your panel by trying. Just make sure you record all your volts before hand. Let us know what you come up with.
tubby497 likes this.
post #1009 of 2441 Old 03-07-2014, 01:39 PM
-Hitman-'s Avatar
Quoted: 168 Post(s)
Liked: 121
If voltages are tweaked lower, certainly the levels (black) will improve it did for me, I haven't reset and not had red tint but have bezel blacks in low light, in a pitch black room I have a slight dark grey glow with a 0% feed!
ShockFett and tubby497 like this.
-Hitman- is offline
post #1010 of 2441 Old 03-07-2014, 02:10 PM
qwknuf6's Avatar
Quoted: 168 Post(s)
Liked: 189
I have not done a reset , I did have D-Nice tweak both my 101 and 151 before i made any other adjustments , I can lower the S1 S3 S4 until i cannot see the black bars no matter how low the APL , think the Croods cave scene.
, Master and Commander below deck scenes , I am not sure i can even see the screen with 100% black content , looks the same off and on , my room is blacked out ,black walls ceiling ect ect , does it match an OLED display? I don't know , I read a measurement of .00004 MLL from an OLED test (Chad B???), I can only estimate my 101 would measure near there as it was .0002 after D-Nice tweaked it and there is a HUGE difference between D-Nices setting and what I can lower it to with the S1 S3 S4 adjustments , I must say my 151 will not take any adjusting without misfires so it gets to stay @.0006 MLL .
Plus I can always return to D-Nice settings @ any time,takes 10 seconds , If you reset your panel it will always be out of sync
HTH
pg_ice and tubby497 like this.
qwknuf6 is online now
post #1011 of 2441 Old 03-07-2014, 02:17 PM
Quoted: 514 Post(s)
Liked: 279
Originally Posted by toddrain1 View Post
I left the sad at 128
Did you reduce s1 s3 and s4 below factory minimum BEFORE losing headroom?
JVC DLA-RS4810
post #1012 of 2441 Old 03-07-2014, 02:24 PM
toddrain1's Avatar
Quoted: 62 Post(s)
Liked: 53
yes
toddrain1 is offline
post #1013 of 2441 Old 03-07-2014, 02:28 PM
tubby497's Avatar
Quoted: 149 Post(s)
Liked: 395
HTH
Thanks! I'm going to adjust the voltage. Controlcal with rs232 cable is needed to get into factory menu correct?
tubby497 is offline
post #1014 of 2441 Old 03-07-2014, 02:37 PM
qwknuf6's Avatar
Quoted: 168 Post(s)
Liked: 189
What panel do you have ? I use a service remote so someone else will have to help you with control cal , make sure you record all of your factory settings before you make any changes , the only settings you should have to change are S1 S3 S4 and RSTP
post #1015 of 2441 Old 03-07-2014, 02:45 PM
-Hitman-'s Avatar
Quoted: 168 Post(s)
Liked: 121
You can use Kurocontrol, which is free, uses rs232 on a Krp.
Just start the program, press connect to link with the panel and type ..
FAY (press send)
then
FACS01 (press send)
You will then be in the SM and you can use your normal remote to navigate through the SM.
Kurocontrol
http://www.avsforum.com/t/1240606/kurocontrol-program-for-pioneer-krp500m-600m-and-elites
-Hitman- is offline
post #1016 of 2441 Old 03-07-2014, 02:49 PM
Quoted: 514 Post(s)
Liked: 279
yes
Then there you go. Those are the two things I did before I lost headroom. Seems like lowering s1 s3 and s4 below factory minimum throws off algorithms.
Im afraid youre gonna have to reset. Follow what I did before restting. Hopefully it works for you.
For all those who have not reset, stay within factory ranges.
JVC DLA-RS4810
post #1017 of 2441 Old 03-07-2014, 02:56 PM
Shawn1's Avatar
Quoted: 21 Post(s)
Liked: 27
I performed another reset on my 500M about two weeks ago, but this time I left all the voltages at factory default, with the exception of VOL SUS, which I raised from 128 to 150, in order to eliminate all traces of the tiny purple dots on an all-white field.
I gotta say... My 500M now looks better than ever. No more red-tinted elevatated blacks. The black level is significantly deeper now compared to when it was brand new. Even better, when looking at black level test patterns, I see no sign of black crush.
The reset is just what my 500M needed.
Shawn1 is offline
post #1018 of 2441 Old 03-07-2014, 03:16 PM
ShockFett's Avatar
Quoted: 22 Post(s)
Liked: 128
yes
What exactly do you mean you lost head room?
post #1019 of 2441 Old 03-07-2014, 03:37 PM
ShockFett's Avatar
Quoted: 22 Post(s)
Liked: 128
HTH
50" vs 60" is totally different. A 50" will alway reach deeper mll. What hitman and I see on the 60" is normal. Very minimum glow at complete black.
Yeah if the 60" doesn't take the tweak there seems to be hardly any wiggle room. My 141b took the tweak very easily.
post #1020 of 2441 Old 03-07-2014, 03:59 PM
toddrain1's Avatar
Quoted: 62 Post(s)
Liked: 53
Once I dropped the voltages below the factory min it was harder and harder to remove the reddish tint. I have to drop s1 and s3 into the 30s to get my mll to an acceptable level. So when the internal clock raises it again I have no more room to move it down.
Pioneer Elite Kuro Pro 1150hd 50 Inch Plasma Hdtv
