Pioneer 8G 9G Kuro Reset Guide - Page 56 - AVS | Home Theater Discussions And Reviews
post #1651 of 1663 Old Yesterday, 01:30 PM
all clear's Avatar
Quoted: 13 Post(s)
Originally Posted by lnarbi View Post
Everything might not be right you know, these are just quotes, and not necessarily truth. A possibility though.
I noticed when starting the TV that the gray box "starting up" was perfectly solid, without any dancing pixel even with the nose on it. Might explain the better overall sharpness.
And what if, FSAD and VSUS had to be set the same value ? It could even be as simple as that, who knows
yes thats why you need to do some testing to sort some of the suggestions out
i dont think VSUS and FSAD are linked.
nothing in the service manual points to that
VSUS controls the overall voltage to the panel and the effect is most visible on bright areas when high voltage is used.
FSAD is not a voltage on its own it just changes S1/S3/S4 but not in a linear way.
FSAD= interlocked settings for S1/S3/S4
all clear is online now
post #1652 of 1663 Old Yesterday, 01:42 PM
makaveddie81's Avatar
Quoted: 130 Post(s)
Liked: 157
Originally Posted by all clear View Post
bt1886 gamma is only optimal for displays that cant go down to 0 blacks so i dont use it.
i go for powerlaw gamma on my KRP
that one looks best with best shadow details.
if you want to use bt1886 do it
i dont trust gimmicks that tries to copy the behaviour from the old CRT tvs.
also most movies are mastered with powerlaw gamma at 2.22
I didn't say I use BT1886. I still use power law but gamma. My dilemma is that with RGB gamma setting for 10 IRE at 0, gamma readings for that point are around the 2.27 to 2.30 range. If I set it to +1, then the readings are around 2.17 to 2.19. I'm trying to decide which would be best for my needs. I don't want dirty blacks or loss of detail near black. It seems that setting it to +1 would give the results I am looking for.
makaveddie81 is online now
post #1653 of 1663 Old Yesterday, 01:46 PM
Quoted: 130 Post(s)
Liked: 157
Another interesting thing...
I checked the masks out of curiosity.
Masks CS06 CS07 and SS23 are perfectly clean, no misfires at all !
I NEVER saw that on a reset display, never, especially CS06 was impossible to get clean.
Combi mask 6 (the screen swipe on steroids) was not clean on my recently acquired 500M (only 1900 hours) and stock voltages (at the time).
I gave up using patterns when tweaking a non-reset display. A better way to gauge the tweak is with actual content.
post #1654 of 1663 Old Yesterday, 01:48 PM
Quoted: 130 Post(s)
Liked: 157
that sounds logical
X and Y
you need to change both not just one to have an effect.
lowering RSTP and VOL OFFSET with the MKCS01 (H Ramp) mask didnt have any effect att all
i also tried to power off and power on to see any changes.
it said that you should raise both to clear sparkles but i didnt get any sparkles even with RSTP at 001 and VOL OFFSET at 010
so that one goes off the list of potential fixes right away
the only voltage that has an effect on that mask is VOLSUS.
brightness test with VSUS and SAD with contrast at 35
default vsus and sad: 45fL
vsus 150: 46.6fL
vsus and sad at 155: 46.9
default vsus and sad but with xsus_b and ysus_b at 124 : 48fL
so no raising both VSUS and SAD to 155 here doesnt reduce brightness
Masks CS06 CS07 and SS23 are extreme
they are not clean here but i dont care.
i never see those misfires on real content so i let it go
i have some other fixes for mask problems here that i tested out about a year ago
they can be usefull
you was wondering how you got combi mask 6 clean
here is the answer.
you need to check both raster mask 15 and combi mask 6 as both are affected by the distance between the S3 and S4 voltages
You wouldn't happen to be pg_ice would you?
Your opinions/observations, writing style and setup are eerily similar to his.
craigyboy likes this.
post #1655 of 1663 Old Yesterday, 01:54 PM
Quoted: 130 Post(s)
Liked: 157
FSAD absolutely changes S1, S3 and S4 in a linear way, hence the "interlocked" designation.
FSAD was introduced in the 9th generation panels. The reasoning for it is right there in your screenshot - for easier adjustment of S1, S3 and S4. That right there tells me that those three must be adjusted by the same amount on non-reset panels.
post #1656 of 1663 Old Yesterday, 01:56 PM
lnarbi's Avatar
Quoted: 79 Post(s)
Liked: 24
I didn't adjust anything to get the masks clean, nothing at all except RSTP, VSUS and FSAD.
Before reset I have set everything to default, and RSTP to the card's default value (18), just after the reset I set back RSTP to 33 (my factory setting), VSUS and FSAD to 155, and then 30min of combi mask 1.
That's it
Well after that I activated ISF modes again, put previous settings in, and tweaked them because white balance changed.
I remain confident they're somewhat connected, in the aging algorithms pov at least.
lnarbi is offline
post #1657 of 1663 Old Yesterday, 02:01 PM
Quoted: 130 Post(s)
Liked: 157
That's it
That sounds like a good approach... keep it simple.
I got my reset 101fd closest to stock by only raising SAD until combi mask 7 was clear. Kept SUS and RSTP at default.
post #1658 of 1663 Old Yesterday, 02:09 PM
lnarbi's Avatar
Quoted: 79 Post(s)
Liked: 24
You could try to find the right balance between VSUS and FSAD, who knows maybe it's even better that way.
It would be nice for once to find a pettern to this that work everywhere.
PS : my panel now has 15k hours, so it's not a matter of too many hours or not.
VSUS is the main voltage for the panel, and the voltages from the y board (400V+) are raised from vsus as a source, so a small change in vsus is that much bigger on the y board side.
lnarbi is offline
post #1659 of 1663 Old Yesterday, 02:13 PM
all clear's Avatar
Quoted: 13 Post(s)
thats just pure luck
all it needs its a slight adjustment of the S3 and S4 voltages.
that space was probably correct on yours already from the factory.
good for you anyway.
if you get misfires already on a stock kuro with low hours on the masks,you can wonder how the voltages was setup up from the beginning.
you can also guess its some wearout problems or hardware failure that wasnt there when it was new.
should you do a reset then?
probably not
is it important for you to know?
post #1660 of 1663 Old Yesterday, 02:21 PM
lnarbi's Avatar
Quoted: 79 Post(s)
Liked: 24
I remember checking these patterns before buying this one, they were clean. I also calibrated the ones of some people in my area, checked too, clean everytime. I didn't check on my very first Kuro though, but I recall some people saying on theirs these patterns weren't all clean so it's probably a matter of luck on the panel you get.
Tazz28 on HCFR studied the kuro official patterns and from his understanding the aging algorithms are meant for the worse possible scenario, rather than being specific to each panel, and are therefore too agressive to many panels. If they were specific, the red tint problem may never have happened, but how much would these sets have cost if it was the case ?
RSTP might be the value that sets the aggressiveness of these algorithms, being set different all the time from factory, that's why I want to keep it to its original value.
lnarbi is offline
post #1661 of 1663 Old Yesterday, 03:27 PM
Quoted: 130 Post(s)
Liked: 157
Because pure luck is not part of the equation when stabbing blindly in the dark to "fixi" a reset Kuro.
probably not
Only mask that had misfires was combi 6 and it was very minor. Not going to stress over it or fall into the reset trap again.
I guess it got quiet in the European forum eh?
Say hi to Stu for me
post #1662 of 1663 Old Yesterday, 03:34 PM
Quoted: 130 Post(s)
Liked: 157
Yeah it was very minor misfires on combi mask 6, which is the most intensive/aggressive of the internal patterns. Nothing to worry about, since the tweak will induce more misfires in the patterns (but not on content if done right) anyways.
I always set RSTP to 1 on my Kuro's as a preventative measure (or as a possible delay) against red tint.
post #1663 of 1663 Old Today, 05:34 PM
all clear's Avatar
Quoted: 13 Post(s)
i have done alot of testing right now
probably one hour with a few shutdowns due to a too high abl value.
these combi masks probaly uses more power than a regular white field does so thats why i got the shutdowns.
the problem was that the tv was shutting down with one of the combimasks running.
so as soon as i plugged in the power cable and powered on the tv that mask was displayed for one second.
then the tv shut down again.
i know that some users have had this problem before and i know that turbe has a patch for it with controlcal.
but the good news is that no patch is needed to get rid of the mask.
if you got this problem
just hit the "MASK OFF" command for that mask you was using from controlcal.
in this case it was MKCS00
just send the command to the tv right away after you turn it on and the mask will go away.
if you are stucked with the ABL mask then it will be MKRS00 instead
back to the combi masks with magenta misfires on them
i have found a solution to get all combimasks clean on this KRP while keeping the same low blacklevel.
if someone can test it it would be great just to see if it works on other models.
from the last picture i posted from the combi mask 6 i wroted that you must increase the distance between S3 and S4.
you can do that but if you increase the distance to much you will get IR on black backgrounds.
put up a black window from your PC and move the mouse cursor over it
if you see a green line of pixels behind it you have increased the distance between S3 and S4 to much.
Set the distance between S3 and S4 as high as possible without getting any IR on black backgrounds.
after that you probably still have misfires on combimasks 6 and 7/8
to clean the remaining misfires raise both S3 and S4 at the same amount.
in my case that was +10 for both.
blacklevel is the same as before with no raise at all
clean combi masks with no IR.
i think im done with this KRP now
Pioneer Elite Kuro Pro 1150hd 50 Inch Plasma Hdtv
Gear in this thread - 1150hd by PriceGrabber.com
