Pioneer 8G 9G Kuro Reset Guide - Page 80 - AVS Forum | Home Theater Discussions And Reviews
 103Likes
post #2371 of 2400 Old 02-02-2017, 02:33 AM
buttonsw's Avatar
Quoted: 41 Post(s)
Originally Posted by strangequark View Post
Still not clear at 230 FSAD (I'm a bit worried about going higher). Patrik seems to think I have a bad 5090 (his 5090 with 20K hours clears combimask 6 with only 150 FSAD and 20 RSTP).
But how exactly is combimask 6 suppose to look? Maybe it's clear and I don't know it...
On mine, it's white, but flashing different colours. even at 230 FSAD.
I should mention that I was didn't have any red-tint, I was just looking to get deeper blacks. Before the reset, I was getting 0.0049 cd/m2
It should be clear at 230 and I'm sure it is but you don't realise it.
COMBI MASK 6 is a very intense strobe flashing light and it can play tricks with your eyes as I'm sure looking directly at it is not good for us! My 10k hour 500A needs FSAD @ 171 to completely clear COMBI MASK 6 of Magenta misfires, and remember its only the Magenta misfires that you want to clear, it will always flash crazily. Having FSAD at 128 you will clearly see Magenta pixels all over the Mask, just raise FSAD until they are cleaned up.
I would lower XSUS_B and YSUS_B one or two more notches (124 or 123) as 20k hours is a lot and a full white field needs to be 100% clean
Pioneer KRP-500A | Sony STR-DH810 Receiver | Tannoy HTS101 Speakers
buttonsw is offline
post #2372 of 2400 Old 02-05-2017, 11:13 AM
strangequark's Avatar
Liked: 0
Thanks, buttonsw and makaveddie81.
My LX5090 turns itself off when I set FSAD to 200. Not immediately, but about 60 seconds after displaying an image.
When FSAD is set to 190, I'm not sure if COMBI MASK 6 is clear, but I still have some black rain. It's minimal when RSTP is set to 60.
strangequark is offline
post #2373 of 2400 Old 02-06-2017, 02:10 PM
makaveddie81's Avatar
Quoted: 485 Post(s)
Liked: 277
Is ABL at default on your set or did you raise it?
Pioneer Kuro KRP-500M
Pioneer Kuro PRO-141FD
Pioneer Kuro PRO-111FD x 2
Pioneer Kuro PDP-5020 x 2
makaveddie81 is online now
post #2374 of 2400 Old 02-07-2017, 03:30 AM
Liked: 0
I did raise ABL to 210, but the buzzing noise was too much for me, so I lowered it down to 125 (which is the default I think).
post #2375 of 2400 Old 02-07-2017, 08:04 PM
Quoted: 485 Post(s)
Liked: 277
I bet you didn't lower it on all the drive modes, and whatever drive mode you're using to display the mask still has ABL at 210.
You need to display a different mask (one that is not full on white so the TV doesn't shut off) using each drive mode to change the ABL setting for each mode.
post #2376 of 2400 Old 02-08-2017, 12:43 AM
Liked: 0
But Patrik gave me a list of commands to change ABL to 210 and I did all the commands again at 125 - I checked every command, so I don't think there's a problem here. I'll do them all again.
Don't suppose you know the commands to change ABL? xD
I don't have Patrik's messages anymore.
post #2377 of 2400 Old 02-08-2017, 02:24 PM
Quoted: 485 Post(s)
Liked: 277
you can change it using the service menu overlay / display
simply display a pattern using the desired drive mode
then navigate to the panel function menu (i believe) and change the ABL setting. wash rinse and repeat for the rest of the drive modes.
if the set is turning off when displaying combi mask 6, then it'sa good bet that ABL is still set to 210 for the drive mode used to display the mask.
this is why i don't touch abl on my sets.
post #2378 of 2400 Old 02-10-2017, 02:22 AM
Quoted: 31 Post(s)
Liked: 0
Hello to everybody friends:
i've resettted my krp-500a and i have a problem that i dont know how can i resolve it.
My new voltages are:
Vol_sus 158
Rstp 18
Sad 158
xsys and ysus 126
All others default.
In the black bezzel i can see now green sparkles and sometines magenta sparkles in image...could anyone tell me what im doing wrong please?? Thanks to all people for his patience with me.
A greeting
booleano is offline
post #2379 of 2400 Old 02-13-2017, 04:04 AM
buttonsw's Avatar
Quoted: 41 Post(s)
Vol_sus 158
Rstp 18
Sad 158
xsys and ysus 126
All others default.
A greeting
It sounds like you have brightness too high
Lower brightness to -1 or -2 and look very carefully and closely at a black screen. Now raise the brightness until you see dithering/noise. When you see that turn the brightness down one click and then it is set
buttonsw is offline
post #2380 of 2400 Old 02-16-2017, 05:58 AM
RobMacLennan's Avatar
Quoted: 45 Post(s)
Liked: 101
Button!!!
RobMacLennan is offline
post #2381 of 2400 Old 02-16-2017, 02:09 PM
Liked: 0
What about VSUS? Should I leave this to the post-reset default? 128?
Inarbi posted a table sometime ago for values of VSUS at different hours.
Has anyone tried to contact a Pioneer service engineer? There's been some heated debates in this thread and it's hard to know what's good and bad.
post #2382 of 2400 Old 02-16-2017, 02:49 PM
Quoted: 485 Post(s)
Liked: 277
I don't touch it. If I see any sparkles on the AVSHD709 main menu AFTER adjusting SAD to clear combi mask 6 of misfires, then I lower xsus and ysus one tick at a time until the sparkles go away.
post #2383 of 2400 Old 02-17-2017, 03:34 AM
Quoted: 25 Post(s)
Liked: 2
I'm a (second )owner of Elite 101FD with around ~ 12,000 (panel) hours.
(Note that i'm using kuro-command. It allows real-time adjustment using your PC without displaying factory menu on screen)
Is there a potential downside in maxing out VSU ?
The setting that i currently use clears my set of intermittent subpixels and get pretty decent blacks without red tint and no crushed blacks.
VSU maxed (255)
VYF 108
V4F 169
XSB and YSB @ 124
(and RSTP is 1)
Note that i never power off my display. When i don't use it, it's just in standby mode.
Also note that i have the fan set constantly on
34-hfx-83 is offline
post #2384 of 2400 Old 02-18-2017, 11:03 AM
Liked: 0
You said in one of your posts that VSUS doesn't change with aging, which is very interesting.
What values do change with age?
post #2385 of 2400 Old 02-19-2017, 10:31 AM
Quoted: 485 Post(s)
Liked: 277
RSTP, VOL OFFSET and one of the XPOFS changes post reset. After reset, RSTP went down (which means it goes up over time), VOL OFFSET went up (which means it goes down over time).
The only difference that I saw between the 50 inch and 60 inch sets is that on the 60 inch sets XPOFS1 went down after reset (meaning it increases over time) while on the 50 inch set, XPOFS2 went UP after reset (meaning it decreases over time).
post #2386 of 2400 Old 02-22-2017, 01:44 PM
Liked: 0
COMBI MASK 7 and 6 are free of magenta misfires with FSAD at 168, RSTP at 48 and XSUB/YSUB at 124.
I'm not sure if my eyes are playing tricks on me, but I can see yellow pixels on both masks. On COMBI MASK 7, they're in the centre area.
post #2387 of 2400 Old 02-22-2017, 02:40 PM
Quoted: 485 Post(s)
Liked: 277
Your RSTP is way too high. If your pulse meter was reset, set it to 18, then use a black field to adjust and find a sweet spot. If you see red tint, lower it. If you see darker black blotches, raise it. If neither, leave it.
If pulse meter was not reset, set RSTP to 1.
post #2388 of 2400 Old 02-23-2017, 12:55 AM
Liked: 0
That's the only way I can get rid of the black rain. Raising FSAD helps, but not as much. I'll lower it to 28.
What about the yellow pixels I'm seeing? They make white fields look a bit dirty. As I said, they're mostly in the centre, but I can see them all over the screen if I look closely.
post #2389 of 2400 Old 02-23-2017, 11:40 AM
Quoted: 485 Post(s)
Liked: 277
I've never seen yellow pixels on white fields before, so can't help you there.
I prefer to have RSTP as low as possible (since it's the one voltage that goes up as the panel ages and most likely responsible for red tint) and just raise FSAD to get rid or at least reduce the black rain.
post #2390 of 2400 Old 02-25-2017, 02:42 AM
Liked: 0
Thanks, there's not much black rain with RSTP set to 28. I don't see any in real-world content.
It turns out there's something wrong with my eyes. I'm seeing yellow patches on light-coloured surfaces. I see them on my monitor too. Thank god there's nothing wrong with my Kuro xD
post #2391 of 2400 Old 02-27-2017, 12:50 PM
CHUCKCHILLOUT's Avatar
Quoted: 35 Post(s)
Hello everyone,
I just picked up a pro-151 that had the 8 blinks issue and the main board was fixed. It works great now, but has a bit of a reddish blacks. At the very beginning it's stated that it is not wise to try the fix on a tv that has newer parts, is this still the case? I want to give it a try, but the picture does look good enough where I don't have to do it, I mean I could definitely live with it as is. Any thoughts?
CHUCKCHILLOUT is online now
post #2392 of 2400 Old 02-28-2017, 11:46 AM
Quoted: 485 Post(s)
Liked: 277
Originally Posted by CHUCKCHILLOUT View Post
Hello everyone,
The first post on this thread is extremely outdated and inaccurate and that new parts provision was made with a gut feeling by the initial poster. I've performed the reset and tweaked voltages on multiple sets with replaced parts. No issues whatsoever.
I'd lower RSTP to 1 and SAD from 128 to 118 as a start. Pulse meter reset should be your absolute last resort on a 60 inch set.
post #2393 of 2400 Old 03-01-2017, 11:08 AM
Quoted: 35 Post(s)
Is there a recommended post or page I should look at to get up to speed? I guess I need a rs232 cord and controlcal on a pc--I have a mac, so that would mean I would need to get vmware fusion and install windows.
post #2394 of 2400 Old 03-04-2017, 11:48 AM
davethestalker's Avatar
Quoted: 56 Post(s)
My son decided to "adjust" all of the colors on one of the HDMI to look like a bad acid trip and then lock the remote out of the menu system!!!!
Samsung 65ks8500
Pro-Ject Debut Carbon w/Acryl-It platter, Phono Box S
DENON AVR-X7200wa, Paradigm Monitor 90p v1
Def Tech system: CLR2300 SM450 surrounds, BP1.2x rear surrounds, Polk PSW-505
Previous AVRs: AVR-4520ci, RX-A710, RXV-2200
Instagram: DaveTheStalker, PSN ID: DaveTheStalker GT fan since day 1.
davethestalker is offline
post #2395 of 2400 Old 03-04-2017, 05:27 PM
leggoslave's Avatar
Need more info. What exactly are you locked out of?
If it's Parental Control..the default password is 1234 or;
If you forget your password: When “Please Input Your Password” appears at Step 4, press and hold the ENTER button for three or more seconds. The password reverts to the default password, 1234.
If the remote doesn't work at all then sometimes unplugging the power chord from the wall and leaving the set off from between 15-30 minutes works. A faulty TV tuner card in one of my KUROs used to cause this when the TV/DTV button was pressed. Careful as this sometimes factory resets the panel.
leggoslave is offline
post #2396 of 2400 Old 03-04-2017, 05:49 PM
leggoslave's Avatar
Probably better installing Windows on a drive partition via Boot Camp.
Even better buy a second-hand Windows laptop with a serial port. <$100
If you go with either you'll need a Serial Straight-Through Cable (DB9 F/F). If you go with the Mac-only, then you'll also need a Serial to USB converter. I'm not sure if any of the all-in-one cables work.
I would go with KuroControl over ControlCal for now. It's easier to use and free.
post #2397 of 2400 Old 05-06-2017, 09:44 AM
Tiptoe32's Avatar
Liked: 0
Hi all,
I buy a 508D and i want to know if it possible to reset it ?
Thank you
Envoyé de mon SM-T210 en utilisant Tapatalk
Tiptoe32 is offline
post #2398 of 2400 Old Today, 04:42 AM
Liked: 0
Magenta sparkles on white background LX5090
@makaveddie81
Hi,
After my European LX5090 starting to display the mentioned problems, searching led me to this site.
Unfortunately not 15 posts yet, so I'm hoping makaveddie81 could help me out.
I've read you have a program called KURO COMMAND and that with this it is possible to tweak certain voltages to mitigate / solve this.
Could you help me out on this?
Best regards,
Remco45 is online now
post #2399 of 2400 Old Today, 10:49 AM
Quoted: 485 Post(s)
Liked: 277
Originally Posted by Remco45 View Post
@makaveddie81
Hi,
Best regards,
Sure, check your PMs.
post #2400 of 2400 Unread Today, 11:15 AM
Liked: 0
Thanks, email sent.
Pioneer Elite Kuro Pro 1150hd 50 Inch Plasma Hdtv
