Pioneer 8G 9G Kuro Reset Guide - Page 81 - AVS Forum | Home Theater Discussions And Reviews
 104Likes
post #2401 of 2408 Old 06-26-2017, 01:50 AM
Liked: 1
Thanks Makaveddie81,
With your help I was able to solve the magenta pixel problem.
My TV is as good as new!
makaveddie81 likes this.
Remco45 is offline
post #2402 of 2408 Old 06-29-2017, 05:08 PM
makaveddie81's Avatar
Quoted: 498 Post(s)
Liked: 277
Glad to hear that!
JVC DLA-RS4810
Pioneer Kuro KRP-500M
Pioneer Kuro PRO-141FD
Pioneer Kuro PRO-151FD
Pioneer Kuro PRO-111FD
Pioneer Kuro PDP-5020
makaveddie81 is offline
post #2403 of 2408 Old 07-26-2017, 12:57 AM
Liked: 0
Hi !
Can someone help me?
Cant understand why my KRP-600M wont save the setting i make in Voltage.
Using KuroControl i get in Service Menu. (Fay, FACS01) then down to
PANEL -1 ADJ (+) in there i make som settingchanges and the Picture get much better.
But the i hit ENTER on the remote an the Picture Changes back!?
Even tried to sen FACS00 Before the ENTER but it does not help.
The strange thing is when i reenter PANEL -1 ADJ (+) The Picture Changes again to the better and all my changed values are there!?
What am i missing?
toxodude is offline
post #2404 of 2408 Old 07-26-2017, 01:41 PM
Quoted: 498 Post(s)
Liked: 277
Originally Posted by toxodude View Post
Hi !
What am i missing?
This is normal. The change in picture has nothing to do with the adjustments you are making. When you access the service menu, your current picture mode settings are overridden by some sort of torch mode (via an automatic change in the drive mode, white balance and other settings), regardless of whether or not you make changes. So the picture is not getting better. In fact, it's getting worse lol. Once you exit the service menu, your picture mode settings take over, as they should.
To verify that your voltage setting change took, simply verify that the value of the setting reflects the change you applied.
JVC DLA-RS4810
post #2405 of 2408 Old 07-26-2017, 01:44 PM
Quoted: 205 Post(s)
Liked: 79
Hi !
What am i missing?
I don't think you're missing anything. If when you go back in and your changes are still there then it worked. I have the same TV and have done the same procedure. Here is what I set mine to:
VOL RSTP 1
VOL YKNOFS1D 51
S3D 61
S4D 108
The minimum voltages are this. I've gone just a hair below and can see no ill effects.
VOL YKNOFS1D 54
S3D 65
S4D 111
Where did you set yours?
Test Ickles is offline
post #2406 of 2408 Old 07-29-2017, 05:11 PM
Brettmckinney's Avatar
Hi guys! Sorry, just realised I had accidentally posted this in the 9g owners thread! Any tips on the below?
My Kuro LX5080 has started giving me yellow blobs across the left side to middle of the screen. It doesn't occur all the time however generally after a bit of use it starts to come up. Very noticeable on white backgrounds! Any ideas on what might be causing it? I have adjusted some settings in the service menu to combat red tint. Wondering if perhaps I've been a bit aggressive?
Also, does anyone have a Euro LX5080 that could give me their stock settings? Just so I confirm as I've lost some of my initial settings. Thanks!
Brettmckinney is offline
post #2407 of 2408 Old 07-30-2017, 10:41 AM
saprano's Avatar
Quoted: 552 Post(s)
Liked: 547
Which is why i use a blank input when i go into it. I think the TV is being over driven to have content on the screen when using the service menu.
home theater addict
saprano is offline
post #2408 of 2408 Old 09-05-2017, 09:14 AM
dsmudger's Avatar
Hello Kuro experts, would much appreciate a little help here..
Heartbreakingly my KRP-500A has developed a couple of issues:
1. one intermittently sticking pixel, it goes 100% green, most often when it's trying to display shades of grey: I'm hoping this can be fixed by adjusting voltages.
2. after an hour or so, alternating red/blue squares on the main panel (service menu says that's: "communication between the MR and the display cannot be established for any reason") or panel goes black and flashing blue power LED - I guess it's overheating, as the longer I leave it off to cool down the longer it lasts until the issue comes back.
I can see the info I need is probably in this thread, but would help a lot if someone in the know could give me some pointers so I don't make things worse, particularly for the stuck pixel.
I have a feeling a reset isn't necessarily what I need - black levels are probably elevated since stock but still ok for me, way better than any LCD, and no red tint at all.
I have a USB to serial cable, but haven't tried talking to the TV with it, in any case a LAN connection may be easier, also unsure if the service menu / KuroControl vs trimming POTs is the way forward on this one.
Also haven't checked if the internal fans are working and/or blocked with dust, thought best to check here before doing things I might regret.
Thanks a lot.
dsmudger is offline
Pioneer Elite Kuro Pro 1150hd 50 Inch Plasma Hdtv
