Opinion of P65ST50 Problem (black bar down right side) - AVS Forum | Home Theater Discussions And Reviews
Old 01-10-2014, 09:38 AM - Thread Starter
jacemace's Avatar
I have the opportunity to pick up a P65ST50 for a great deal but it has a screen problem. I'd like to try to fix the problem myself but before buying parts, I'd like the opinion of the group.
Here's a pic of the problem. Note the vertical black bar going down the right side of the tv.
I'm thinking this might be related to a bad C board but I'm not entirely sure. Would appreciate feedback and ideas.
jacemace is offline
Old 01-12-2014, 10:24 AM
pk4
pk4's Avatar
Hi jacemace,
if you are willing to enter into service menu, you can check it there with mirroring function. It is in the section OPTION - MIRROR.
Hint : If the defective symptom (e.g. Vertical bar or Horizontal bar) is moved by selection of this mirror, the possible cause is in A-board.
jacemace likes this.
pk4 is offline
Panasonic Viera Tc P65st50 Plasma Tv
