Official Samsung PNxxF8500 "Bugs" Thread - Page 13 - AVS Forum | Home Theater Discussions And Reviews
 22Likes
post #361 of 596 Old 07-12-2014, 07:56 PM
KONICA TECH's Avatar
Quoted: 25 Post(s)
Liked: 54
[QUOTE=airgas1998;25695865]lower left hand corner back side it's a joystick press in to turn on/off[/QUOTE
Thanks, I have been pulling the power cord after I put in stand-by.
KONICA TECH is offline
post #362 of 596 Old 07-13-2014, 12:48 AM
cooknl's Avatar
Quoted: 23 Post(s)
Liked: 25
Well sorry to say this, but when mine has the RED light LLC on in the standby mode, if I then press the little joystick in the rear of the panel I can NOT turn OFF the set, it comes ON no matter what I do.
So in my case it is not an ON/OFF switch, in my case its a STANDBY/ON switch.
Please let me know if I am doing something wrong. I was also told by Samsung that the unit does NOT have an ON/OFFswitch as such.
But then again maybe I am missing something and if thats the case please enlighten me because I would love tobe able to turn the TV OFF at nite.
Rob
cooknl is offline
post #363 of 596 Old 07-13-2014, 09:31 AM
Quoted: 25 Post(s)
Liked: 54
Rob
Same here! This does not power off the set for me.
cooknl likes this.
post #364 of 596 Old 07-13-2014, 10:26 AM
p5browne's Avatar
Quoted: 2793 Post(s)
Liked: 2110
Back to pulling the plug!
cooknl likes this.
p5browne is offline
post #365 of 596 Old 07-13-2014, 04:19 PM
Quoted: 25 Post(s)
Liked: 54
This is why people are having HDMI problems when they do factory resets, they are not clearing the HDMI cables that with certain inputs to the TV have power and signal in them.... therefore they do not reset properly.
post #366 of 596 Old 07-13-2014, 10:13 PM
p5browne's Avatar
Liked: 2110
Video Equalizers, Satellite Receivers, etc, that are still sending out a signal. Like the Sat Revrs - Telling you to turn it on.
p5browne is offline
post #367 of 596 Old 07-17-2014, 04:03 PM
jojoxl's Avatar
Just had the "no input" error. Tried everything to get it back. Finally had to unplug the HDMI cable, pull the power on the TV, plug power back in and power on, then plug in HDMI cable.
This is with the new v1200 firmware, BTW.
jojoxl is offline
post #368 of 596 Old 07-17-2014, 07:05 PM
Quoted: 25 Post(s)
Liked: 54
No wonder you are having problems.....
post #369 of 596 Old 07-22-2014, 09:42 AM
jojoxl's Avatar
Meaning what, exactly?
jojoxl is offline
post #370 of 596 Old 07-22-2014, 10:49 AM
Stereodude's Avatar
Quoted: 3085 Post(s)
Liked: 2236
I think he was trying to blame the firmware, but I'm not 100% sure.
Stereodude is offline
post #371 of 596 Old 07-22-2014, 07:19 PM
Quoted: 25 Post(s)
Liked: 54
You stated you reapplied power to the Samsung and then connected the HDMI cables. To be safe you should always disconnect the AC before changing HDMI cables. Sure, many people get away without having problems but it can happen. By re-applying power you reset the HDMI communication between components. Good Luck
Reference:http://www.avforums.com/threads/is-h...pable.1229098/
p5browne likes this.
post #372 of 596 Old 07-25-2014, 06:25 AM
Stereodude's Avatar
Liked: 2236
Originally Posted by wxman View Post
CS works great 99% of the time. However since it basically using 4 identical frames in 96hz (4x24hz) to give the movie a smoother flow, every once in awhile it will hiccup and you can see an extra frame, or brief stutter.
It sure seems to me that the hiccups are a lot more frequent than "every once in a while" when playing 1080p23.976 (24/1.001) content. I'm going to make a few test pattern videos (at different frame rates) with a moving white box (or similar) to hopefully figure out what the problems is. From what I've seen so far I'm surprised there isn't a crowd of people lined up with pitchforks and torches screaming at Samsung because the current implementation sure seems close to unusable. In my attempts to use the feature, there are tons of stutters on what seem to be a pretty frequent periodic basis and I know my playback source (HTPC) isn't dropping any frames and I know the source material I'm sending to the TV is real 1080p23.976 (IVTC'd 1080i60).
post #373 of 596 Old 07-25-2014, 05:39 PM
Stereodude's Avatar
Liked: 2236
So, I made some test clips and I'm not entirely sure what to make of my results so far. Basically, the F8500 doesn't seem play either 24.000Hz or 23.976Hz (24/1001) content from the HDMI port perfectly regardless of the settings. There are hiccups in the playback if Cinema Smooth is on or off. There are hiccups if the Motion Judder Canceller is set to off, standard, or smooth. The best results with the least hiccups seemed to be with 24.00Hz and Cinema Smooth turned on. My testing so far shows the set seems to favor 24Hz over 24/1.001Hz. Of course that's not what is on a Blu-Ray disc...
Also, the hiccups are not on a predictable periodic basis.
Edit: I still need to do more testing where I take the HDMI splitter and receiver out of the playback chain as well as try a second PC with a different graphics chipset.
post #374 of 596 Old 07-25-2014, 07:49 PM
p5browne's Avatar
Liked: 2110
Spears and Munsil 2 Blu-ray Video Motion Tests - the F8500 will never pass any of them except 60. 24 and 30 will fail every time.
p5browne is offline
post #375 of 596 Old 07-25-2014, 08:49 PM
Dianabol5mg's Avatar
Quoted: 305 Post(s)
Liked: 233
I have no motion hiccups anymore. There are 3 things that I have changed since I got mine in April. 1) I turned off all wi-fi and internet capabilities as well as motion control and voice recognition. 2) Went to custom color space instead of native. 3) and more hours everyday have this thing hummin'. I have no idea if 2 is helping, but I'm leaving it. I went through every single configuration I could and this is what is working for me.
KONICA TECH likes this.
Dianabol5mg is online now
post #376 of 596 Old 07-25-2014, 09:33 PM
wxman's Avatar
Quoted: 3520 Post(s)
Liked: 2542
To be fair, I have not seen any plasma pass the 24 and 30p motion tests. The mighty Kuros fail all but the 60p test.
LG 65EF9500
LG 65E6P
wxman is online now
post #377 of 596 Old 07-25-2014, 09:36 PM
Stereodude's Avatar
Liked: 2236
I tried bypassing the receiver and HDMI splitter and I'm not sure anything improved.
I'm not familiar with those motion tests. Can you describe the test / how it works?
My tests don't rely on any sort of deinterlacing or IVTC. They're progressive files that have smooth consistent motion in a test pattern. The test is simply playing the file with the refresh rate matching the file and look for hiccups, jumps, jerkiness, etc. in the motion. Here's the 24/1.001FPS one:
1080p23.976 (24/1.001) mkv
I will upload more of my motion tests at other frame rates and post links to them later. I need to generate a few more files.
post #378 of 596 Old 07-25-2014, 10:08 PM
p5browne's Avatar
Liked: 2110
Please note Posting above yours. #376
p5browne is offline
post #379 of 596 Old 07-25-2014, 10:17 PM
Stereodude's Avatar
Liked: 2236
Yeah, I saw that. I'm unsure why the sets would have issues with 24 or 30Hz. 24Hz should work perfectly with Cinema Smooth enabled since it's a multiple of 96 which you get with Cinema Smooth enabled. Proper 30Hz playback is just a matter of showing each frame twice at 60Hz. However, as I mentioned I'm not familiar with the S&M motion tests so they may be attempting to test something other than what I'm testing.
post #380 of 596 Old 07-26-2014, 04:17 AM
saru360's Avatar
Hi your problem is the HTPC, PC cpus and graphic Cards have problems showing properly 24p, see this topic:
Let's set this straight - No one can do 24p consistently well
saru360 is offline
post #381 of 596 Old 07-26-2014, 08:12 AM
Stereodude's Avatar
Liked: 2236
I'm extremely skeptical that it's caused by slight frame rate variances from the HTPC. Yes, the typical HTPC 24/1.001 frame rate is typically ever so slightly off, but at least on my HTPC only to the tune of around 2 repeated or dropped frames over the length of a 2 hour movie. The F8500 has a lot more than 2 hiccups in 24/1.001Hz Cinema Smooth playback over the course of a 2 hour movie. It's several noticeable glitches per 10 minute interval. I wouldn't be complaining about 1 glitch per hour. Heck, I probably wouldn't even notice that. Besides, it's possible to test your slight frame variance explanation and rule it out. MadVR reports dropped or repeated frames. If you see a hiccup / hitch in the motion, check madVR's stats, and see the counters haven't increased from before the motion glitch, then it seems rather unlikely that the HTPC is responsible (due to the minute frame rate variance).
Further, I'm highly skeptical that the 24/1.001Hz output from standalone blu-ray players is any better. They just don't have any means to show you the exact frame rate they're outputting so no one notices 1 or 2 glitches over a 2 hour movie and basically no home user has any means of precisely measuring the frame rate of a standalone Blu-ray player it to know it's off.
post #382 of 596 Old 07-26-2014, 09:00 AM
saru360's Avatar
If you can try a blue ray player, or a media player like the mede8er, dune, etc.
Try also a factory reset and disconnect all hdmi cables. And leave it disconnected from the power for 10min.
saru360 is offline
post #383 of 596 Old 07-27-2014, 09:37 PM
Stereodude's Avatar
Liked: 2236
I created a thread with all my motion test clips. There are 24/1.001 (23.976), 24, 25, 30/1.001 (29.97), 30, 50 , 60/1.001 (59.94), & 60Hz files.
post #384 of 596 Old 07-31-2014, 10:20 AM
Stereodude's Avatar
Liked: 2236
What do you mean by "add the Xbox to the mix"? Turn it on? Plug it in? Change to its input on the receiver?
And, which Xbox?
post #385 of 596 Old 07-31-2014, 10:28 AM
ParityBit's Avatar
Quoted: 112 Post(s)
And, which Xbox?
I would plug in the HDMI cable and turn on the Xbox. I would then change to it's input on the receiver. If that happened to work, I would swap inputs on the TV, and that would never work. Always get a flash of the Xbox menu and then black.
I did a complete power off one time too, but I had someone tell me I need to unplug the power to all devices, which I did not try but makes sense. In addition, I found out I could damage things to pull/plug the HDMI wires as things are on, so I will no longer be doing that!
This was with both the Xbox One and the Xbox 360.
ParityBit is offline
post #386 of 596 Old 07-31-2014, 10:34 AM
Stereodude's Avatar
Liked: 2236
Did you try plugging either Xbox directly into the TV or use a different HDMI port on your receiver?
post #387 of 596 Old 07-31-2014, 10:41 AM
saru360's Avatar
sounds like a HDMI handshake problem.
Try to connect the xbox directly to the tv, and see if it does the same.
I would connect the receiver to the tv HDMI3 since it's ARC enabled, with this you can play the sound of the tv through the receiver.
saru360 is offline
post #388 of 596 Old 07-31-2014, 10:47 AM
ParityBit's Avatar
Quoted: 112 Post(s)
I did not try plugging it directly in, but I can try that too. All 4 components work fine if I only have one HDMI cable going from the receiver to the TV.
I will also do the ARC HDMI 3 input.
post #389 of 596 Old 08-02-2014, 07:31 AM
stanjohn123's Avatar
Quoted: 22 Post(s)
I have no idea what just happened to my tv. Was playing medal of war and other games just fine for a week in PC mode and all of a sudden one night there was crazy lag. I never updated the tv after purchase so I'm not sure what led to this lag issue , now the lag just does not go.
How has everyone fixed their lag issues in gaming ?
stanjohn123 is offline
post #390 of 596 Old 08-02-2014, 12:39 PM
wxman's Avatar
Liked: 2542
I have an odd glitch with Redmere cables. I don't think it's the F8500. My setup is DirecTV>Oppo103D>Samsung F8500>to Onyko via HDMI 3 (ARC) all with Redmere cables. When using a standard HDMI cable from tv via HDMI3 (ARC), and with Anynet CEC turned on, I have no problems and ARC works just fine. I can turn on and off the receiver with tv remote and I get sound. However, when I use a redmere cable the final leg, I can turn receiver off and on with tv remote, but get no sound. I even switch the ends of the cable, and still no sound. I know the cable work fine as I tested it with another device directly to tv. Does the redmere cable require both the video and audio to pass through, and not just the audio?I have tried with another Redmere cable and get same result. Bizarre that a $3 HDMI cable works with ARC, but the Redmere doesn't.
LG 65EF9500
LG 65E6P
wxman is online now
Samsung Pn51f8500 51 Inch 3d Smart Plasma Hdtv
