Plasmas disappearing. Should this (aging 27" CRT) viewer get a 42" or 43" 720p soon? Pls comment. - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #91 of 97 Old 07-20-2014, 09:26 PM
FAUguy's Avatar
Quoted: 94 Post(s)
Originally Posted by ADU View Post
^ A lot of good advice above from Josh128.
The F4500 is going to do some scaling/resampling regardless of what signal you send it, because it's native 1024x768 resolution is not a precise match to either 720p or 1080p. My guess is that the Blu-rays would look best at 1080p, like Josh said, since that's the native rez of most Blu-ray content. The cable box is harder to guess on. You could set it to output native signal rez, 720p or 1080i/p, and see which looks best. It just depends on the type of content you watch, and which device does a better job deinterlacing and scaling to your eyes.
According to the manual, it supports Cinema Smooth, which only works with 24Hz inputs. So my guess is it does. That's another thing you'd probably want to experiment with though. Some prefer to leave everything at 60Hz for various reasons.
I disagree a little with Josh re the SDE on the F4500 series btw. SDE, dithering and color contouring* are all more pronounced to my eyes on the F4500 than on the 51F5300. It's sort of a moot point though, since you don't have space for a 51" TV, and will probably be watching a lot of SD and 720p. My main concern with the 43F4500 would be poor ventilation in such a tight space. (Maybe Josh could comment on that as well, since he's owned an F4500 for awhile.)
My 34" Sony 1080i CRT paid a visit to the CRT recycling center yesterday btw, and decided to stay there. Gonna miss all those nice dither-free colors, deep blacks and lagging Sony phosphors. I'm not exactly "CRT-free" though, since I still own 2 CRT monitors (one B&W), and a 24" SD CRT which still has a very good picture.
The Panasonic CRTs had a really nice picture. So I'd recommend keeping the TAU, until you're sure you've found a suitable replacement. I often wish I'd waited a bit and picked up one of the Panny 30" HD models, instead of the Sony 34XBR800. Water under the bridge though.
(*It's probably also worth noting that most decent 40-42" 1080p LCDs/LEDs would have none of these issues,... though they would have worse angle of view, motion and other PQ weaknesses compared to the plasma TVs. And a 1080p display would also be less forgiving to the SD content.)
Originally Posted by RandyWalters View Post
But that TV is not a 720p TV, it's native resolution is actually 768p so whether you set your cable box to output 1080i or 720p the TV will scale the signal to 768p anyway. It's been my experience on a number of 768p Plasmas and LCDs that setting the Cable Box/Sat Receiver/Tivo to 1080i fixed makes the picture noticeably more crisp and detailed than when using the 720p setting on both 1080i channels and 720p channels (i've actually tested both back to back). Most others here have seen the same thing.
If you can get basic cable straight from the wall, you can test how the 1080i Fixed setting affects 720p channels by tuning the TV's internal tuner to a 720p channel (like ABC and FOX) then switching back and forth with the same channel on your cable box via HDMI.
The Square Trade warranty is pretty good - i bought mine from Costco (5yrs/$99 IIRC) even though i bought my 55ST60 at Amazon, and if i'm not mistaken the one you buy at Amazon is allowed on TVs bought elsewhere.
Here's the way it is set up now....
Living Room:
Motorola DCX3400M box.
For watching SD channels, I use a RCA Composite Cable, and for HD I use Component.
This way I can change inputs on the Panasonic TAU between SD 480p and HD 1080i.
The Mits SVHS VCR is connected from the cabke box with S-Video and to the Panasonic using S-Video cable. I only use this if I tape record or play at tape, which is rare. I don't use S-Video for watching SD Cable channels from the cable box since there is some dot-craw that is eliminated when using Composite input, since the Panasonic has a 3D Y/C Comb Filter for Composite only.
For BluRay it uses Component at 1080i.
Bedroom:
Two years ago in replaced both bedroom's 1992 27" Sony Trinitron with a Toshiba 32TL515U LED/LCD since it was the best 32" unit on the market. It has a nice image when viewed straight on, and the edge-lit local dimming is OK for a bedroom set.
It is connected with HDMI to a Motorola DCX3200M (it's part of the AnyRoom DVR that can access recordings on the main DCX3400M box in the living room).
The settings on these Motorola boxes are:
HDMI Output: 1080i, 720p, 480p, 480i, and Native.
4:3 Override: Stretch, Off, 480p, 480i.
Native Mode settings (only is Native is selective above) : 1080p 30fps, 1080p 24 fps, 1080i, 720p, 480p, 480i.
I have tried all those different settings with the Toshiba and found the best to for the Motorola box to be set on HDMI Output of 1080i and 4:3 Override of Stretch. That way all sampling is done by the box to 1080i for all SD and HD, and it will horizontally stretch 4:3 SD to fill the screen.
I did try using Native, which didn't make a difference for HD channels, but for SD sending it to the TV at 480p, then having the TV upsample it to 1080 and stretch it didn't look as good as if the cable box did it.
So chances are, if I get a 43F4500 for the living room, I may start with it the same way, have the Motorola box do all the HD and SD upsampling to 1080i and have it stretch the SD 4:3. But if it doesn't look good, then can try setting it to 720p, or use the Native settings. Too bad you can't force these boxes to output at 1080p.
FAUguy is offline
post #92 of 97 Old 07-22-2014, 11:07 PM
FAUguy's Avatar
Quoted: 94 Post(s)
Originally Posted by Josh128 View Post
Straight up, I wont pretend to know much about the LG, but I have the 51" version of the Sammy 4500, and let me tell you it puts out a drop dead gorgeous picture, whether in 480p, 720p, or super-sampled 1080p. Being a fellow CRT fan, you will appreciate this set, because it puts out a very CRT-like picture-- much moreso than the 1080p plasmas. For a 720p set, it cant possibly get much better, so go with the Sammy while you still can. Plus, you can get the 51" for just $399 right now, you simply cant beat that deal.
Dont be afraid of the 51" size for the 720p plasmas. I have two of them and they both look great, but the Samsung beats the Panasonic by a good margin, believe it. You hear all this talk about SDE (screen door effect) and stuff about the 720p plasmas, but dont buy into it. The pixel density of the 51" will be at least equal to, and most likely better, than your 36" Tau. If you are used to and like the look of your Panasonic 36" CRT, you will LOVE the picture of the PN51F4500. Im afraid the 43" will be a bit small for you, coming from a 36" 4:3 CRT. The 51" will give you about 2" more vertical real estate than what you have now and a lot more horizontal. The 43" will give you an inch or two less than what you have.
I did some measurements tonight, and the distance is 15-17 feet from the TV to the couch or love seat.
I measured the screen size on my Panasonic. First used the composite input with a SD channel and the visible image was 28.5" W x 21.5" H. Then when changing over to Component with a 1080i channel (which activates the TV's ID-1 mode) gave a visible image of 28.5" W x 16" H. So I'm not sure what the visible screen image would measure on the 43F4500.
The specs say it's 39.8" wide total. I'm not 100% sure if it will fit in my cabinet, as it's hard to measure the opening width the the Panasonic in there, and a pull-out door on each side (that I don't even use and would have to be removed). I think with the doors removed, the total width may be 40", which would only give 1/10" clearance on each side of the TV.
Eventually, I know I'd need a new type of cabinet, preferred a flat top so any size TV can be used.
FAUguy is offline
post #93 of 97 Old 07-23-2014, 01:41 AM
Marc Wielage's Avatar
Quoted: 234 Post(s)
Liked: 131
Ultimately, that's the best solution. Anytime a piece of furniture dictates the size of the component, it winds up being a major compromise in quality. My advice is generally to avoid having anything at the front of the room except the display and the speakers, and keep your components off to the side if possible, out of your direct line of sight. That way, there's no blinking lights and all that stuff.
Cabinets made for 4x3 TV sets unfortunately have no place in the new world order. Maybe you can relegate it to a bedroom or hand it off to a friend or relative or something.
Marc Wielage is offline
post #94 of 97 Old 07-23-2014, 08:19 AM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 499 Post(s)
Liked: 766
Here's a handy screen size calculator - http://cavecreations.com/tv2.cgi
By upgrading to a 43" widescreen TV, your standard def 4:3 content will actually be a little smaller, and full screen HD content will only be larger in width but not height so in the end you're only gaining 9 inches of screen width when watching DVDs and full screen HD. Not much of an upgrade if sticking with a little 43" screen size so is it really worth it? At 15-17 feet, i'd be looking for a 60" or larger Plasma (and an appropriate TV table/credenza).
36 inch 4:3 Set
4:3 picture - Your viewing area is 28.8 in(w) x 21.6 in(h)
16:9 picture - Your viewing area is 28.8 in(w) x 16.2 in(h)
43 inch 16:9 Set
4:3 picture - Your viewing area is 28.1 in(w) x 21.1 in(h)
16:9 picture - Your viewing area is 37.5 in(w) x 21.1 in(h)
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #95 of 97 Old 07-23-2014, 09:42 AM
FAUguy's Avatar
Quoted: 94 Post(s)
36 inch 4:3 Set
43 inch 16:9 Set
Though when watching SD content, I would have it stretched to fill the screen, which would then have it at the 37.5 W x 21.1 H.
FAUguy is offline
post #96 of 97 Old 07-23-2014, 03:24 PM
Josh128's Avatar
Quoted: 259 Post(s)
Liked: 104
Im no large screen snob, just purchasing my first non-CRT about 7 months ago, but I can definitely tell you that at +12 feet away, the 51" size is put to the test when coming from a 36" 4:3 in the same room. We had to shell out for new furniture, but yeah, 43" 16:9 would have looked disappointingly small. I say this because again, even the 51" doesnt look all that much bigger.
For sure it means more money, both for a bigger set and a new TV stand, but if you want a plasma, nows the time to get what you REALLY want. The #1 regret about TV purchases is supposedly "I wish I would have went bigger", supposedly.
Josh128 is offline
post #97 of 97 Old 07-23-2014, 07:08 PM
Super Eye's Avatar
Quoted: 46 Post(s)
Liked: 34
Here is a better screen size calculator
http://www.displaywars.com/36-inch-4x3-vs-43-inch-16x9
It generates an image comparing the sizes.
Super Eye is offline
Panasonic Tc P42x60 42 Inch Plasma Hdtv , Samsung Pn43f4500 43 Inch Plasma Hdtv
