Mounting Screw Size for PN60F5500AFXZA ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 02-19-2014, 06:16 PM - Thread Starter
bthornton's Avatar
2/20/2014 EDIT
Turns out the manual is indeed correct (duh) and the guy at Lowes gave me the wrong screw (even after I asked if he was sure).
Mods: Please delete this post if possible. Thanks.
Anyone know the screw correct screw size to wall-mount a Samsung 60" Plasma TV (PN60F5500AFXZA)? Manual says the screw size should be M8. It's not.
I went to Lowes and picked up some M8 screws, brought them home, and they ended up being the exact same diameter/thread as the screws that worked on my 47" LG. That's also the size my mount came with, but M8 is too small for the Samsung.
Just wondering if anyone here knows and can save me some back-and-forth to the hardware store. :)
bthornton is offline
Samsung Pn60f5500 60 Inch 1080p 600hz 3d Smart Plasma Hdtv
