lg 60pv450 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 02-23-2014, 08:52 PM - Thread Starter
ja3hawk's Avatar
Hi guys. Set is about 2 years old. Recently noticed a purple or green flicker on certain scenes. Typically brighter scenes with sky. Anyone else ever see anything like this? If necessary I'll see if I can snap a picture.
ja3hawk is offline
post #2 of 2 Old 03-02-2014, 07:43 AM - Thread Starter
ja3hawk's Avatar
Seems to be getting worse. Any chance this can be fixed by replacing 1 of two circuit boards inside this TV? Its 600 dollar TV so I don't want to spend a ton of time and resources on it. Is there any easy way to tell if its the panel vs one of these boards? I figured if the panel was the problem the issue would be constant. Instead it depends on what else is on the screen.
ja3hawk is offline
Lg 60pv450 Plasma Hdtv
