Replacing Screen on Panasonic VT60 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 03-05-2014, 10:46 AM - Thread Starter
socci's Avatar
Quoted: 41 Post(s)
Hey, I was just curious if anyone knew the work required to replace a cracked screen on a VT60, if even possible?  I can get a almost new VT60 with a cracked screen, and another new VT60 with a blue stripe going down the screen both for really cheap.  Can I take the screen from the one with the blue stripe (assuming the screen isnt the cause of the stripe) and put it on the good TV with the cracked screen? I can pretty much fix anything with instructions and the right tools, but do not have any experience with TVs, so any help is appreciated.
socci is offline
post #2 of 4 Old 03-06-2014, 07:21 AM
tomwil's Avatar
Liked: 26
The following documents might give you an idea of what is involved.
http://elektrotanya.com/panasonic_10th_gen_plasma_panel_replacement.pdf/download.html
http://elektrotanya.com/panasonic-chassis-gp8du_pdp-panel-1.pdf/download.html
http://elektrotanya.com/panasonic-chassis-gp8du_pdp-panel-2.pdf/download.html
That which may be known of God is evident within man, for God has shown it to them, so that they are without excuse. (Romans 1:19-20)
tomwil is offline
post #3 of 4 Old 03-06-2014, 05:12 PM - Thread Starter
socci's Avatar
Quoted: 41 Post(s)
That is extremely helpful, thank you.
socci is offline
post #4 of 4 Old 03-08-2014, 05:37 AM
AMartin56's Avatar
Quoted: 1740 Post(s)
Liked: 869
Maybe I'm missing something, but if the blue stripe is caused by one of the boards wouldn't it be easier to just swap boards from the set with the cracked screen? Or are some of the boards hard wired to the panel?
Home Theater: Sony 45ES, Denon AVR-S920W, NHT Super Ones/Zeroes w/Ten Sub,
Sony BDP-S6500, Sony UBP-X800, and Monoprice 130 inch 2.35:1 White Material Screen
Living room: Sony 60NX720, VIZIO SB4051-C0 Other: Samsung 51F8500
Displays calibrated with HCFR, i1DisplayPro, and Colormunki Photo.
AMartin56 is online now
Panasonic , Panasonic Tc P60vt60 60 Inch 3d Smart Plasma Hdtv
