Kuro Kapture Program - AVS | Home Theater Discussions And Reviews
 2Likes
post #1 of 61 Old 03-12-2014, 12:56 PM - Thread Starter
makaveddie81's Avatar
Quoted: 139 Post(s)
Liked: 160
I have developed a nifty little program that automatically generates a report of all service menu (and regular) settings in a matter of seconds.
The program works with the below Kuro models:
101fd
141fd
500m
600m
111fd
151fd
5020
6020
Non-US model equivalents to the above
It should also work with non US models, as long as it has a US equivalent and you select the correct model when prompted by the program.
The program will not make any changes to your Kuro.
Simply unzip the attached .zip file, and run one of the two below versions. The report will be saved in the same location as the executable.
  • kuro_kapture_automatic.exe - Only works with serial connection. Automatically issues commands, gathers and parses command output to generate report.
  • kuro_kapture_manual.exe - Use this if you connect to your Kuro via Ethernet. You have to manually input the commands in KuroControl and paste their output in Kuro Kapture. Kuro Kapture will then parse the command output to generate the report.
It took almost 3000 lines of code (plus manual template and definition creation) for each version. Thank you's are greatly appreciated!
UPDATE
Since some people have been having issues due to wrong cable and/or adapter, below are links to the hardware I used during development.
? USB to RS232 Adapter
http://www.amazon.com/TRENDnet-RS-232-Serial-Converter-TU-S9/dp/B0007T27H8/ref=sr_1_1?ie=UTF8&qid=1389882111&sr=8-1&keywords=straight+rs232+serial+cable
? Straight through RS232 Serial Cable (not a null modem cable). Make sure to get the right gender.
Male to Female
http://www.amazon.com/StarTech-com-10-Feet-Straight-Through-Serial/dp/B000A7NROO/ref=sr_1_2?ie=UTF8&qid=1389886710&sr=8-2&keywords=straight+rs232+serial+cable
Female to Female
http://www.amazon.com/gp/product/B00066HP2E/ref=oh_details_o01_s00_i00?ie=UTF8&psc=1
I will be issuing this program after a $25 paypal donation is made to edwardrafii@gmail.com and PLEASE INCLUDE YOUR EMAIL ADDRESS IN THE PAYPAL NOTES SECTION.
Please check out my other program, Kuro Command, which allows you to send commands to the same model Kuros supported by Kuro Kapture. Among other commands, you can send commands to access the service menu and alter voltages to lower black level / fix red tint.
Kuro Command Program
makaveddie81 is online now
post #2 of 61 Old 03-12-2014, 02:16 PM
tubby497's Avatar
Quoted: 85 Post(s)
Liked: 348
Great job! and thanks!
makaveddie81 likes this.
5.1 Setup
Display - Pioneer KRP-500M (Tweaked)
A/V Processor - Mcintosh MX121
Sources - Mcintosh MVP881, Oppo BDP-103, Apple TV, Xbox One
Amp/Controller - Mcintosh MC303, MC207, MPC1500, SurgeX SA-82
Speakers/Subwoofer - B&W 803D2, HTM2D, 805D2, JL Audio Fathom 112
tubby497 is offline
post #3 of 61 Old 03-12-2014, 04:04 PM
jdbimmer's Avatar
My Antivirus flagged both executable files as Trojans:
“TR/Crypt.ZPACK.Gen”
Not sure if that is a false positive or not.
Edit: Per Malwarebytes it is clean. Most likely a false positive from my Avira AV.
jdbimmer is offline
post #4 of 61 Old 03-12-2014, 04:27 PM - Thread Starter
Quoted: 139 Post(s)
Liked: 160
Yep, totally clean.
post #5 of 61 Old 03-12-2014, 04:36 PM
ShockFett's Avatar
Quoted: 12 Post(s)
Liked: 122
Nice bro! Have to give you props man gj!
ShockFett is offline
post #6 of 61 Old 03-12-2014, 09:38 PM
tpaxadpom's Avatar
Once again, thank you for the app. It makes it easy to go back to capture all SM settings in less than a minute.
tpaxadpom is offline
post #7 of 61 Old 03-12-2014, 11:23 PM
lnarbi's Avatar
Quoted: 93 Post(s)
Liked: 25
Works great with LX5090H using 111FD profile :)
lnarbi is online now
post #8 of 61 Old 03-12-2014, 11:28 PM - Thread Starter
Quoted: 139 Post(s)
Liked: 160
Originally Posted by lnarbi View Post
Good to hear. I know the qs1 command on the non-monitors is not accurate on the last 6 values, as there is a discrepancy in the service menu regarding the total number of characters in the output. The service manual states theres 117 total characters in the commands ouput, but adding the characters from each individual setting output by the command turns up with 123 total characters. This is why the last setting (cs or checksum) is empty.
post #9 of 61 Old 03-13-2014, 02:02 AM
Zimbalo's Avatar
Quoted: 26 Post(s)
Liked: 238
I used your program on my KRP-500A (European model) by automatic-exe with 500M profile.
I sent you PM.
Plasma TV: Pioneer Kuro KRP-500A - Pioneer Kuro LX-508D - Panasonic TX-P50VT30E
Sources: Oppo BDP-93 - Popcorn Hour A210 - Video Processor: TruVue eeColor
Probe: i1Display Pro profiled by JETI Specbos 1211-L - Software: Calman 5 Enthusiast
Zimbalo is online now
post #10 of 61 Old 03-13-2014, 08:53 AM - Thread Starter
Quoted: 139 Post(s)
Liked: 160
I sent you PM.
In looking at the output, the 500A only accepts the commands for the non-minitors. Select 111fd as the model and try again, it should work.
post #11 of 61 Old 03-13-2014, 10:10 AM
Zimbalo's Avatar
Quoted: 26 Post(s)
Liked: 238
Thanks, that's OK.
post #12 of 61 Old 03-18-2014, 02:52 PM - Thread Starter
Quoted: 139 Post(s)
Liked: 160
394 views and only 10 comments lol... I'm guessing no one's had issues with the program?
rabah.aouni likes this.
post #13 of 61 Old 03-21-2014, 02:10 PM
Zimbalo's Avatar
Quoted: 26 Post(s)
Liked: 238
What is the difference between "Hour meter" and "Total HR meter" (QS3 command output)?
post #14 of 61 Old 03-21-2014, 02:17 PM
lnarbi's Avatar
Quoted: 93 Post(s)
Liked: 25
Hour meter + Total Hour Meter gives you the real hours of your panel.
When you do a reset, the hour meter adds to total hour meter, and then hour meter is reset to 0.
It's a good way to know if the tv has once be reset, if total hour meter is greater than several hours.
post #15 of 61 Old 03-21-2014, 03:25 PM
Zimbalo's Avatar
Quoted: 26 Post(s)
Liked: 238
So what does that mean?
post #16 of 61 Old 03-21-2014, 03:28 PM
lnarbi's Avatar
Quoted: 93 Post(s)
Liked: 25
3982 hours :)
post #17 of 61 Old 03-21-2014, 03:52 PM
Zimbalo's Avatar
Quoted: 26 Post(s)
Liked: 238
If Hour meter is 3981.52, why Total HR Meter is 45?
I did not reset.
post #18 of 61 Old 03-21-2014, 09:21 PM - Thread Starter
Quoted: 139 Post(s)
Liked: 160
I did not reset.
Pioneer did. Before I reset mine, my hour meter was at 2. Perhaps its the testing done at the factory.
post #19 of 61 Old 03-22-2014, 03:59 AM
Grifone1893's Avatar
Hi makaveddie,
I have the same model as Zimbalo (KRP-500A european) and I don't understand why the program doesn't works for me (but it works for him).
I have the right cable (it perfectly works with Hyperterminal and let me to access the SM), I select the auto.exe and the right profile (N° 5- pro 111fd), after selecting the right COM port, the program says "working..." and it generates the report, but all the values are empty.
Grifone1893 is offline
post #20 of 61 Old 03-22-2014, 12:06 PM - Thread Starter
Quoted: 139 Post(s)
Liked: 160
You are most likely picking the wrong com port or there is a break in the communication between your computer and the kuro. The program doesnt know if you picked the wrong port. It will still run, unless you pick a non existent com port.
post #21 of 61 Old 03-22-2014, 03:16 PM
It's strange. The com port shoul be the right one (according to Windows), in fact if I try to enter SM using the same port and Hyperterminal, I have no problem...bho
Thanks anyway.
post #22 of 61 Old 03-22-2014, 03:20 PM - Thread Starter
Quoted: 139 Post(s)
Liked: 160
Yeah, idk. You can always use the manual version. Issue the commands on kuro control and paste in kuro kapture.
post #23 of 61 Old 03-22-2014, 04:04 PM
As far as I know I can't use Kuro Control on KRP 500A (EU model). Ethernet port on this model is only for HMG (home media gallery).
post #24 of 61 Old 03-22-2014, 04:25 PM - Thread Starter
Quoted: 139 Post(s)
Liked: 160
Kuro control has the ability to connect via serial... just click the serial bullet and select the com port in the dropdown.
post #25 of 61 Old 03-22-2014, 04:35 PM
I've tried right now...it says "connected" but I receive a timeout issue with every command.
I don't understand why I can access SM with Hyperterminal using the same cable...I think I will surrender.
Thanks anyway
post #26 of 61 Old 03-23-2014, 01:26 AM - Thread Starter
Quoted: 139 Post(s)
Liked: 160
Thanks anyway
These are the items I use to connect with Kuro Control and Kuro Kapture. Might be worth the try.
• USB to RS232 Adapter
• Straight through RS232 Serial Cable (not a null modem cable). Make sure to get the right gender.
Male to Female
Female to Female
post #27 of 61 Old 03-23-2014, 09:04 AM
Thx for your help makaveddie, but this are exactly the items I use.
Without You can't access SM with Hyperterminal.
post #28 of 61 Old 03-29-2014, 09:59 AM - Thread Starter
Quoted: 139 Post(s)
Liked: 160
Wait, are you unzipping the file before using the program?
Have a strong suspicion you might not be unzipping it.
post #29 of 61 Old 04-08-2014, 08:23 AM
Yes I have unzipped it...otherwise how could I see the blank report? biggrin.gif
post #30 of 61 Old 04-08-2014, 02:34 PM - Thread Starter
Quoted: 139 Post(s)
Liked: 160
Then you are using the wrong COM port or wrong equipment. Though my program will report if it CANT connect to the specified COM port, it has no way of knowing if it's actually communicating with a KURO. It could very well be communicating with your mouse or printer, and the devices simply do not respond to the commands that Kuro Kapture is sending.
Below are links to the hardware I used during development.
Male to Female
Female to Female
