Gamma setting Samsung? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 03-13-2014, 06:38 PM - Thread Starter
Vic12345's Avatar
Quoted: 72 Post(s)
Liked: 29
Right now I'm using -2.Just wondering why I never hear anyone use this.Most calibrators use 0, and sometimes -1. The blue is always too high in the brightest areas on my tv which is one of the reasons I've had difficult time getting things right on this tv, and i also have the pinking white screen thing too.Does anyone use -2?
Vic12345 is offline
post #2 of 9 Old 03-13-2014, 09:05 PM
wxman's Avatar
Quoted: 4333 Post(s)
Liked: 2997
I had mine calibrated with a gamma at +1. It was the most accurate gamma OOTB. Almost perfect, and I had it calibrated set to that.
LG 65E6P FW 05.30.02
LG 65EF9500
wxman is online now
post #3 of 9 Old 03-13-2014, 10:03 PM - Thread Starter
Vic12345's Avatar
Quoted: 72 Post(s)
Liked: 29
Mine at + 1 would look really washed out in high abl shows.Reduced from -1 to -2 after I made whbal more green.I think gamma and luminance is more stable however it's dimmer and pastel color like.Really have too know how the controls interact with each other on plasmas.End up crazy after fiddling with it.
Vic12345 is offline
post #4 of 9 Old 03-14-2014, 12:29 AM
wxman's Avatar
Liked: 2997
The gamma settings seem to be a little different on each tv. When I lower to -1, the image is too dark. In essence you are raising gamma closer to 2.5 or higher. When raising the gamma adustment to +2, you wash out image as you lower gamma closer to 2.0. At +1, my gamma was close to 2.2.
LG 65EF9500
wxman is online now
post #5 of 9 Old 03-14-2014, 12:45 AM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4780
My PN59D8000 I have at 0 but just changed to +1 for the heck of it,, although it might be a bit light.....and probably doesn't mean much as a brand alone, wouldn't be surprised to variance from model to model if not within a model range based on manufacturing point....on a given day of the week smile.gif
lovinthehd is offline
post #6 of 9 Old 03-14-2014, 02:37 AM - Thread Starter
Vic12345's Avatar
Quoted: 72 Post(s)
Liked: 29
I'm back at -1......-2 would be good In a dark room but I have some lights on.and some shows are way too dim on-2... I haven't decided if the pastel soft color look is better or the high contrast pop.Right now Im leaning too the softer look,maybe because it's more stable gamma /luminance,and It does work better in a bright room for SOME stuff.
Vic12345 is offline
post #7 of 9 Old 03-14-2014, 03:07 AM
chunon's Avatar
Quoted: 2446 Post(s)
Liked: 2195
Get a meter!
65C6 OLED
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is offline
post #8 of 9 Old 03-14-2014, 03:43 AM - Thread Starter
Vic12345's Avatar
Quoted: 72 Post(s)
Liked: 29
if I had more money,tv with10pt and cms then I'd check into getting one.
Vic12345 is offline
post #9 of 9 Old 03-15-2014, 04:21 PM - Thread Starter
Vic12345's Avatar
Quoted: 72 Post(s)
Liked: 29
On photography site I read when using a brighter gamma(like2.0) than use a lower(more yellow/red)color temperature,and a darker gamma (2.4)use cooler temperature(more blue)....I'm finding when I reduce blue(making it more yellow) in order too get the white point more accurate I'm having too use a darker gamma......That's the opposite of what they said...Now I'm not sure what the point of the article was.I know it's the abl causing this.
Vic12345 is offline
