Samsung F8500....Is now the time to buy?? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 33 Old 04-01-2014, 07:56 PM - Thread Starter
luvmypioneer's Avatar
I had it narrowed down between Cleveland and Value Electronics. Spoke to both of them on the phone and they were both very helpful and knowledgable. I just had to listen to my gut and go with the one I had the best connection with. Do I wish my set was being delivered tomorrow....sure I do. But I trust that VE gave me the best deal he could and will provide service to me for many years to come. Did I make the right decision...who knows, only time will tell. But I must say, even though I am disappointed that I have to wait a little longer for this set, I am still confident in who I purchased it from.
luvmypioneer is offline
post #32 of 33 Old 04-02-2014, 07:52 AM
dsskid's Avatar
Quoted: 268 Post(s)
Liked: 257
Originally Posted by RandyWalters View Post
Actually the 5080 is indeed a KURO - i almost bought the 42" version back in 2007 and they were definitely marketed as KURO (i didn't know what it meant back then). It's Kuro-ness was a big deal on the forums back then.
While the old tank-like Pioneers admittedly had better build quality than the Samsungs (or any other current or recent brand and model for that matter), as long as the Sammy is functioning normally it should last as long as any other brand.
Yes indeed. I believe it had a black level of .006.
ISF Calibrator
Samsung PN64F8500
Pioneer Kuro Elite Pro-111FD
Pioneer Kuro BDP-320
Displays are like 100% cotton t-shirts. Always buy a size larger than you think you'll need, as they tend to shrink over time.
dsskid is offline
post #33 of 33 Old 04-04-2014, 08:17 AM
Plasmalvr60's Avatar
Since plasma technology is on the way out it would be unrealistic to expect there to be a dramatic drop- $1000 or more-  in the price of the 8500.  It's more likely that you won't be able to find one in the future.  Read the posts from folks who waited for the price to drop on Panasonic plasmas- they stopped making them and they became less available so the price actually went up: simple supply and demand equation on price.  Might the price for the 8500 go down a couple hundred dollars- maybe.  Is saving a couple hundred dollars that important to you when you're looking to buy a $2500 TV?
I paid $6000 for my Pioneer Elite 1120 9 years and have no regrets.  It was the best TV on the planet at the time.  The price of a slightly better plasma 2 years later cost $2000 less.  I received 2 years of enjoyment during that time- well worth it!
Please don't be one of those guys that beats themselves up because someone else bought the same product you bought for $100 less.
gus738 and luvmypioneer like this.
Samsung PN64F8500 Smart TV (64" Plasma-2013); LG BD 390 Blu-ray Player; Denon AVR-1709; Nakamichi MB CD Player; Verizon FiOS Motorola 7 Series Cable Box (500GB Hard Drive).  Pioneer Elite 1120 (5th Generation Plasma- 2005); Denon AVR 2800 (2000); Oppo Blu-ray 103 w/Roku Stick; Sony Carousal CD;...
Plasmalvr60 is offline
