Is the TC-P65ST60 worth $500 mote than a TC-P65ST50? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 04-02-2014, 01:42 PM - Thread Starter
Slash's Avatar
Is the ST60 worth $500 more than a ST50? All I care about is image quality, I will NOT be using any of the 'smart' features
Without looking far, I found a TC-P65ST50 for $1800+, and the TC-P65ST60 for $2400+..
While I'm at it what about the VT50 vs VT60... Is the VT60 significantly better than the VT50 (image quality is my only concern)
Steve Russell
Slash is offline
post #2 of 5 Old 04-02-2014, 02:43 PM
KOF
KOF's Avatar
Quoted: 269 Post(s)
Liked: 225
Seeing as the ST60 is at least equal to or better than the VT50 black level-wise, it should be a considerable upgrade over the ST50. The VT60 also does have better black level than the VT50 and using 96hz should help widen that lead.
Calibration-wise, the ST60 should have a little limited options compared to the VT50, but still respectable.
KOF is offline
post #3 of 5 Old 04-02-2014, 02:50 PM
chunon's Avatar
Quoted: 2013 Post(s)
Liked: 1774
St60 moderate upgrade over st50
St60 close to vt50 but give slight nod to vt50
Vt60 minor to moderate upgrade over vt50
Owned vt50 st60 and vt60
65C6 OLED
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is online now
post #4 of 5 Old 04-02-2014, 04:01 PM - Thread Starter
Slash's Avatar
Sounds like I should be going for the ST60... can anybody recommend a reliable authorized dealer that would ship to WA
Steve Russell
Slash is offline
post #5 of 5 Old 04-04-2014, 10:53 PM
StinDaWg's Avatar
Quoted: 451 Post(s)
Liked: 216
Good luck finding one.
gus738 likes this.
StinDaWg is offline
Panasonic Tc P65st60 65 Inch 3d Smart Plasma Hdtv
