Samsung Black Optimizer and Black Tone Features - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By PlasmaPZ80U
  • 3 Post By ConnecTEDDD
post #1 of 19 Old 04-04-2014, 06:06 AM - Thread Starter
Big C's Avatar
Quoted: 62 Post(s)
Liked: 38
I always thought that the Black Optimizer was a panel adjustment like cell light (and backlight on LCD displays). While I don't have the same TV they are refering to, according to this article, it appears to handle things on the video processing end (like contrast, brightness, sharpness, color, tint, gamma, color space, and white balance), as opposed to changing the darkness and brightness of the panel itself. If I'm right, I know now to leave this off for purity, because isn't this similar to the Black Tone setting in advanced picture settings?
Big C is offline
post #2 of 19 Old 04-04-2014, 11:37 AM
PlasmaPZ80U's Avatar
Quoted: 1963 Post(s)
Liked: 559
black tone crushes blacks (like turning the brightness control too low)
black optimizer improves black levels in dark scenes (improving contrast and depth), but causes more visible fluctuations in black level which can be distracting at times
my Samsung F5300 has a MLL (black level on fully black screen) of 0.006 fL with black optimizer set to dark room and 0.009 fL with it off... the latter works best for me as while the blacks are a bit brighter, they look much more stable in dark scenes
ConnecTEDDD likes this.
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Cambridge S20 Surrounds, Rythmik LV12R; PS4, Xbox One, Xfinity X1 (CI CXD01ANI)
PlasmaPZ80U is offline
post #3 of 19 Old 04-04-2014, 01:13 PM
fierce_gt's Avatar
Quoted: 1628 Post(s)
Liked: 1570
imo, just from observations, I would say BO is the flat panel equivalent of a dynamic iris in projectors.
basically, it's a GOOD thing, if done well. sometimes it's action is noticeable, and that's when it's annoying, but 90% of the time all it does is make dark scenes look better while not affecting bright scenes at all
Displays: Samsung PN64F8500/JVC X35
AVR: Pioneer VSX-1130K, 7.1/5.1.2 audio
Sources: HTPC(Enby), PS3, XBOX360, Wii
Control: Harmony One
fierce_gt is offline
post #4 of 19 Old 04-04-2014, 01:16 PM - Thread Starter
Big C's Avatar
Quoted: 62 Post(s)
Liked: 38
Fluctuations? I don't think I'll be using it. I'm just curious. When set to Off, Bright Room, or Auto, does it make peak brightness any brighter?
Big C is offline
post #5 of 19 Old 04-04-2014, 05:24 PM
fierce_gt's Avatar
Liked: 1570
I didn't think it affected brightness at all. but I have not measured, nor have I wanted more brightness out of the set(it's too bright imo) so I can't say for certain.
MOST of the time, the 'fluctuations' work smoothly like with a CRT. it's only the rare cut scenes where it goes from bright to dark really quick, and the procession lags slightly behind. your personal sensitivity will definitely come into play, but I find I'm a lot more noticeable of the poorer black levels than I am of the occasional lag.
post #6 of 19 Old 04-05-2014, 03:10 AM
ConnecTEDDD's Avatar
Quoted: 1053 Post(s)
Liked: 1517
If you display a 110-Step Full Grayscale Pattern like the above you can check your various enhancements controls of your display; Advance Contrast, Black Tone, Black Correction, Advanced Contrast Enhancer, Auto Light Limiter, Clear White, Dynamic Contrast, Cinema Black, Smooth Gradationetc. to have a better view of the problems they introducing and to realize why you need to leave them untouched to prevent new problems. (no smooth color graduations, distortions, discoloration, clipping, banding, posterization, crushed shadow details, raised black levels etc.)
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is online now
post #7 of 19 Old 04-05-2014, 05:08 PM
Liked: 559
It's not always noticeable, but then the difference between 0.006 fL and 0.009 fL with a bias light or during the day isn't either.
Not in my tests, but I haven't checked it very thoroughly yet.
In certain cases it can be very obvious (when APL in right on the threshold where the floating blacks start happening). Other times, you can't tell. However, the black level isn't that much darker with BO On, so that difference is also minor.
post #8 of 19 Old 04-05-2014, 05:10 PM
Liked: 559
does your website explain what each of the patterns under the color reproduction section is specifically for?
post #9 of 19 Old 04-05-2014, 09:59 PM
mikkojokinen's Avatar
That sounds like an older LG set I saw where the brightness limiter kicked in at random, there was no remedy for that but your issue could be solvable with a software update
mikkojokinen is offline
post #10 of 19 Old 04-06-2014, 12:19 AM
Vic12345's Avatar
Quoted: 72 Post(s)
Liked: 29
What is the black level suppose too be on full/mostly white screens when the abl makes objects/things murky gray? Can it be too black,or is it suppose too be murky too?
I'm glad floating blacks has not been very obvious on mine.Pne450.I never even notice it,but I'm 12ft back often.
Vic12345 is offline
post #11 of 19 Old 04-06-2014, 06:24 AM
Liked: 1517
There no informations in my site for each pattern, what to look for or example of what is good or bad by viewing each pattern.
As you have see each Color Reproduction Pattern of my disk has so many uses to various types of testings.
I don't recomment my disk for newcomers to calibration world because the patterns are more complicated and it will be more difficult from them to understand what to notice for each pattern and for what reason.
I want the users that will come to my disk solution to come after using 1-2 other calibration disk first or have spent money to hardware pattern generators, these users will understand better the value of my disk. smile.gif
post #12 of 19 Old 04-06-2014, 12:11 PM
fierce_gt's Avatar
Liked: 1570
I would agree that the action of the BO is seldom noticeable, and even more rarely distracting. but in my room and my viewing conditions(the less light the better) the difference between Dark room and Off is obvious with a dark scene.
I'm a little annoyed that I didn't know what it did exactly before buying the f8500. because it's the BO that makes the f8500's blacks comparable to the vt60's, without it on, it's really not quite there. and that knowledge probably would have me looking harder at a vt/zt before purchasing.
that's not to say I think the BO is a bad thing, I mean, what I'd love to see is the vt/zt with a black optimizer on top of their awesome blacks cool.gif
post #13 of 19 Old 04-06-2014, 02:00 PM
KOF
KOF's Avatar
Quoted: 269 Post(s)
Liked: 225
It would also have been a boon to the LCDs as well. Too bad none of the LCDs got dynamic contrast ratio right. biggrin.gif Unlike the F8500, LCDs must suffer from auto dimming. Maybe Dolby VIsion may prove different.
KOF is offline
post #14 of 19 Old 04-07-2014, 03:14 PM
If black optimizer worked on a linear or gamma trajectory it might be worth something but as it is now I wonder what Samsung was even thinking , it is so completely arbitrary
post #15 of 19 Old 04-07-2014, 03:21 PM
fierce_gt's Avatar
Liked: 1570
well, it vastly improves black levels. so there's that.
honestly, it's just like a dynamic iris on a projector. but without any moving parts, I'm surprised it doesn't work better than a DI does. and at the end of the day, it's as easy to turn off as dynamic contrast, so where's the harm in having it?
like I said earlier, I wish I knew what it did before I bought the tv, as it may have pushed me towards a panny as I have no need for the extra brightness. but that was an issue with nobody really testing what it does, not with the feature itself. as a similar example, I upgraded my projector as well, and was deciding between a jvc x35 and Epson 5020, ultimately the fact the jvc did not 'need' a dynamic iris to achieve the results persuaded me to buy it instead of the Epson. the Epson is still a very good, and well reviewed projector, but I knew I was going to be more likely to use the Epson without the DI, and in that case the jvc was definitely better. just like how I think the vt is definitely better in a dark room than the f8500 with BO off. with BO on, it's close
post #16 of 19 Old 04-07-2014, 03:44 PM
Good analogy with the iris, another thing nobody talks about is the solidity of above black tones which I think fares a bit poorly on the samsungs compared to lg and panasonic, its not something you can measure with a meter but you might see with your own eyes, ultimately I don't place alot of importance on black levels but the black optimizer is interesting.
post #17 of 19 Old 04-07-2014, 05:36 PM
fierce_gt's Avatar
Liked: 1570
are you talking about dithering?
post #18 of 19 Old 04-10-2014, 07:05 AM
dont think so, I am talking about modulation
panasonic on, off, on ,off, on, off
lg on, off, on ,off, on, off
samsung on, off, off, off, off, on (more space between pixels and loss of shadows)
you can test that yourself by looking at one pixel or the spacing between 'on' pixels, panasonic behaves the same in dynamic mode
post #19 of 19 Old 04-11-2014, 03:16 PM
Vic12345's Avatar
Quoted: 72 Post(s)
Liked: 29
Tv ive here the darkest black levesl is much darker on shirts/suits than the reflection from the room lighting on side black bars.Seems I may notice the blacks crushed more on some shows in a dark room vs lighted.So maybe the darkening features work better in lighted rooms.
Vic12345 is offline
