Any more info on LG PB6600 (or other 2014 model) plasma? - Page 20 - AVS Forum | Home Theater Discussions And Reviews
 179Likes
post #571 of 1764 Old 07-08-2014, 07:39 PM
dmtaub's Avatar
Quoted: 100 Post(s)
Liked: 34
Originally Posted by Shaoran View Post
I use this :
Expert1
Panel light: 99
Contrast: 96
Brightness: 53
H-Sharpness: 8
V-Sharpness: 8
Color: 50
Tint: G1
Expert Control
Dynamic Contrast: Off
Super Resolution : Off
Color Gamut: Wide
Edge Enhancer: Off
Color Filter: Off
Expert Pattern: Grayed Out
Gamma: 2.4
White Balance
Color Temp: Warm 2
Method: 2 Points
Pattern: Outer
Points: High
Red: - 8
Green: 0
Blue: + 6
Points : Low
Red : -1
Green: -3
Blue: +4
Color Management System
Yellow: 4,0,6
Red:-6,0,0
Green:4,0,6
Blue:3,0,0
Cyan:5,0,5
Magenta:4,-3,-7
Picture Options
Noise Reduction: Off
MPEG Noise Reduction: Off
Black Level: Low
Real Cinema: Grayed Out
Motion Eye Care: Grayed Out
True Motion: User 3/10
I just changed my settings to these. I am really impressed. It is much more natural looks, colors pop a bit more, and the whites are great (not real blue). I thought Taheer's settings were solid, but these are awesome!
dmtaub is offline
post #572 of 1764 Old 07-08-2014, 07:40 PM
dmtaub's Avatar
Quoted: 100 Post(s)
Liked: 34
Originally Posted by Bradley Balls View Post
I'm coming from a 60pk540, so plasma to plasma, my 60pk540 seemed brighter, also this tv doesn't seem as sharp. could be the source. ill test it over the next few days. just wish it was a little brighter.
What settings are you using? Try Sharon's posted above in my quote. They are pretty darn good!
dmtaub is offline
post #573 of 1764 Old 07-09-2014, 02:43 AM
simms23's Avatar
Dm, with those display settings, do you watch blu-rays with real cinema turned on? Do you see a benefit of turing it on?
simms23 is offline
post #574 of 1764 Old 07-09-2014, 06:56 AM
Liked: 0
I use this :
Expert1
Panel light: 99
Contrast: 96
Brightness: 53
H-Sharpness: 8
V-Sharpness: 8
Color: 50
Tint: G1
Expert Control
Color Gamut: Wide
Edge Enhancer: Off
Color Filter: Off
Gamma: 2.4
White Balance
Color Temp: Warm 2
Method: 2 Points
Pattern: Outer
Points: High
Red: - 8
Green: 0
Blue: + 6
Points : Low
Red : -1
Green: -3
Blue: +4
Yellow: 4,0,6
Red:-6,0,0
Green:4,0,6
Blue:3,0,0
Cyan:5,0,5
Magenta:4,-3,-7
Picture Options
Black Level: Low
Hi guys, I have had this TV for about a month now, and I am really happy with this set. For some reason I don't have access to edit Expert Pattern, Real Cinema, or Motion Eye Care. Does anyone know how to access these 3 settings?
cpmartinez49 is offline
post #575 of 1764 Old 07-09-2014, 09:48 AM
dmtaub's Avatar
Quoted: 100 Post(s)
Liked: 34
I don't have a blu-ray hooked up at the moment. I do have a PS3, but rarely watch blu-ray. Most of my movie collection is digital thru plex, which I use a Mac Mini to watch or through the SmartTV features (side loading Plex app). I really could not give you a good answer.
dmtaub is offline
post #576 of 1764 Old 07-09-2014, 12:23 PM
dmtaub's Avatar
Quoted: 100 Post(s)
Liked: 34
I use this :
Expert1
Panel light: 99
Contrast: 96
Brightness: 53
H-Sharpness: 8
V-Sharpness: 8
Color: 50
Tint: G1
Expert Control
Color Gamut: Wide
Edge Enhancer: Off
Color Filter: Off
Gamma: 2.4
White Balance
Color Temp: Warm 2
Method: 2 Points
Pattern: Outer
Points: High
Red: - 8
Green: 0
Blue: + 6
Points : Low
Red : -1
Green: -3
Blue: +4
Yellow: 4,0,6
Red:-6,0,0
Green:4,0,6
Blue:3,0,0
Cyan:5,0,5
Magenta:4,-3,-7
Picture Options
Black Level: Low
I know "Real Cinema" is for 2:2 pulldown, and only works if the tv senses a source that is capable (blu-ray). I am really not sure on the other items. Check the user guide in the help menu, it might have some information about both.
dmtaub is offline
post #577 of 1764 Old 07-09-2014, 01:54 PM
Shaoran's Avatar
Quoted: 27 Post(s)
Thanks for the compliment
Oh, and for the settings
Real Cinema = available on 24p content
Motion eye Care = only available in eco mode
Expert Patterns = i don't know
Shaoran is offline
post #578 of 1764 Old 07-09-2014, 04:15 PM
simms23's Avatar
Shaoran, thanks! Do you find that the Real Cinema makes a difference when detecting a blu ray? Also, if the BD player gives the option of outputting at 24hz or 60hz, which would you recommend, and also if you choose 60hz will the Real Cinema work even though it is not at 24hz?
Thanks for the assistance.
simms23 is offline
post #579 of 1764 Old 07-09-2014, 04:52 PM
Shaoran's Avatar
Quoted: 27 Post(s)
I would choose 60hz, because the black level is way better on 60hz content than on 24p/50hz
And Real Cinema isn't working when choosing 60hz
Shaoran is offline
post #580 of 1764 Old 07-10-2014, 02:41 PM
TangoAlphaLima's Avatar
Does anyone have a good picture setup on Game Mode? It doesn't use all the same types of fields as expert control. I tried to set mine up to match as close to Shaoran's expert settings as I could, but I wanted to see what other people were using for their Game settings.
Also, regarding Shaoran's settings, the "True Motion" field is grayed out for me. Not sure that I'd want to use it anyway, but I'd at least like to try it out. What am I doing wrong?
TangoAlphaLima is offline
post #581 of 1764 Old 07-10-2014, 08:55 PM
Shaoran's Avatar
Quoted: 27 Post(s)
Change the HDMI Input to PC (Input Button, Red Button, HDMI Input you use for gaming and change to PC) and use Expert 1 for gaming, in PC Mode the Input Lag is a little lower (52-53ms) as in normal game mode (55-56ms) and you can use my settings also for gaming, as i do
In game mode TruMotion is always grayed out, and HDMI Input labeled as PC also, for gaming trumotion should always be off
Shaoran is offline
post #582 of 1764 Old 07-10-2014, 11:46 PM
seikon's Avatar
Quoted: 24 Post(s)
so i was using the disney wow calibration disc blu-ray today (which is pretty great actually) and noticed that my tv's aspect ratio was set to 16:9. the disc showed that with this setting there is a decent amount of overscanning and it was blurring the lines in the 'sharpness' testing.
what do you guys use? 16:9 or 'just scan'. just scan allowed me to calibrate the disc's sharpness perfectly.
...i did however just read online somewhere that this may effect the orbiter as when it shifts it has no extra pixels to shift over. is that right?
seikon is offline
post #583 of 1764 Old 07-11-2014, 03:41 AM
Shaoran's Avatar
Quoted: 27 Post(s)
I use just scan and have no problems with the orbiter mode
Shaoran is offline
post #584 of 1764 Old 07-11-2014, 06:40 AM
Liked: 0
Has anyone watched hockey on this set? I want to know how aggressive the ABL is. I realize it might get a little greyed out but on the Samsung F5300's, the ABL can cause flickering while watching hockey and I want to know if anyone has experienced that on the new LG's.
MSteve5 is offline
post #585 of 1764 Old 07-11-2014, 07:55 AM
I watched some of the NHL playoffs on this set. Not a lot, since I got it at the end of May. But I'm sure I watched at least a few Stanley Cup Finals games on it. Didn't notice any problems with ABL, but I also had power-saving mode turned off, so that might have had something to do with it.
post #586 of 1764 Old 07-11-2014, 08:07 AM
dmtaub's Avatar
Quoted: 100 Post(s)
Liked: 34
Yeah, use "just scan" for all settings. It will eliminate the overscan. Once you are done calibrating, please post your settings so we can all try it out too!
dmtaub is offline
post #587 of 1764 Old 07-11-2014, 08:16 AM
Liked: 0
Thanks. From what I've read no amount of tweaking could eliminated the flickering on the F5300, although it could be reduced and only happened on some games. But since we are few months from hockey season I didn't want to take the chance.
MSteve5 is offline
post #588 of 1764 Old 07-11-2014, 09:39 AM
seikon's Avatar
Quoted: 24 Post(s)
so just to confirm...you guys use 'just scan' and have the orbiter set to ON?
until being made aware of the aspect ratio (via the wow disc) i didn't even realize that when the orbiter is on (in 16:9 or just scan) there's a faint black bar on the right hand side to make room for any shifting. i'm sure that's normal and i never noticed before, it's just kind of funny how before the disc i never even gave it any thought.
seikon is offline
post #589 of 1764 Old 07-11-2014, 10:05 AM
seikon's Avatar
Quoted: 24 Post(s)
though the disc is very very very thorough (and recommended), i am far from a videophile, so a lot of the settings i looked into but didn't really put much time on them.
funny thing is, the main settings are very similar to what has been discussed here earlier.
i originally had 'shaorons' settings in expert 1 and 'nseriessagas' in expert 2. i've had the tv for about a month and a half or so, so i'm not even sure i have enough hours into it that i should of used the disc/calibrated just yet. but i was curious about the disc and am not incredibly picky. i'm somewhat picky, but not incredibly.
i actually liked 'nseriessaga' settings at first. i also like medium tones as opposed to the warm ones. so colour wise i used his white balance and left the colour management system untouched as he did. to be honest...as long as the colour match looks fine to me, i am not really concerned about having the exact right (experts) colour scheme's so i didn't get too deep into the wow colouring section. i am more concerned about brightness, sharpness and contrast for shadows and stuff.
i was very aware of the issues that plasma's can have with the colour white. my set doesn't even get white enough to pass the wow disc contrast test. it still looks pretty white, but it doesn't matter what setting i change i cannot get it white enough for the testing it includes. it's pretty close i think, like when i go into some advanced settings the white brightness isn't that far off, but officially it could not get white enough for a couple of the test.
so after the long preamble, here's the settings i am using.
panel light 98
contrast 98
brightness 50
sharpness V 10
sharpness V 10
***the sharpness test on the disc is amazing. 10 seemed to be the exact number, no question. with anything else, or with 16:9 (overscan) on there was noticeable pixel blur.
colour 55
tint 0
dynamic contrast off
super resolution off
colour gamut standard
edge enhancer off
colour filter off
gamma 2.2
***there is a gamma test as well. i think the not true white's played tricks with this one as well. the disc said that 2.2 is a good number to leave it at, so that's what i did. i tried changing the gamut to wide and the gamma to the 3 different options in the actual test, but i honestly couldn't see much of a difference.
colour temp med
method 2 points
pattern outer
points high
red 3
green 0
blue -1
colour managament: untouched
noise reduction off
mpeg reduction off
black level low
that's about it!
any questions, feel free to ask.
seikon is offline
post #590 of 1764 Old 07-11-2014, 01:01 PM
wish's Avatar
Ever since my 60" Toshiba DLP died I've been looking for another similar sized set. I picked up the 60PB6650 (the one with internal WiFi) at MicroCenter last week for $599 and am so far I'm very pleased. My only complaint is that the TV is very unforgiving on ANY kind of light. However to be fair I knew going in that the screen was very reflective and this is in an unfinished basement so bare bulbs and gray walls tend to accentuate the light. Used in the dark with bias lighting behind the TV the picture is impressive. I've tried several different settings but so far the ones posted by Shaoran in post 551 provide the best and most natural results.
wish is offline
post #591 of 1764 Old 07-12-2014, 03:32 PM
laserjock II's Avatar
Quoted: 765 Post(s)
Liked: 425
Anyone know if this set is still $599 at Microcenter?
laserjock II is online now
post #592 of 1764 Old 07-12-2014, 04:52 PM
wish's Avatar
Tried Blu-ray for the first time & have an issue with serious flicker. I'm not talking about small lag or jutter but it appears it's interference of some kind. Initially I didn't have the ferrite core attached so I clipped one on the hdmi cable. At first it didn't work but after plugging & unplugging the hdmi several times & rerouting the cable to the Yamaha receiver it worked. Turned it on today & same issue. The setup is 3 sources going to the receiver & one output to the TV. No other input (Satellite or Roku) have this problem & I've swapped out the hdmi cables. Anyone else experience this? If so what was the resolution?
wish is offline
post #593 of 1764 Old 07-12-2014, 09:15 PM
wish's Avatar
Interface issue resolved. I forgot I had the Blu-ray going thru a switcher. As soon as I took the switcher out of play the problem went away. I think the hdmi going from the switcher to the receiver and is lower quality and is unshielded.
wish is offline
post #594 of 1764 Old 07-13-2014, 08:20 PM
dmtaub's Avatar
Quoted: 100 Post(s)
Liked: 34
Looking for a bit of help. Noticed that on a black screen, most notably when my directv goes to orbit, I catch a blue or green pixel. I'm assuming this is not normal. Any input would be appreciated. My PB6600 is about 60 days old.
dmtaub is offline
post #595 of 1764 Old 07-14-2014, 08:58 AM
dmtaub's Avatar
Quoted: 100 Post(s)
Liked: 34
Has anyone tried these settings. I found them on an Amazon review. They look like they might produce a pretty good picture. They are for a PK550 and also use a 20pt white balance:
Settings:
Picture Mode: ISF Expert 1
Contrast 98
Brightness 55
H Sharpness 46
V Sharpness 43
Color 53
Tint R8
Expert Controls:
Dynamic Contrast OFF
Noise Reduction OFF
Gamma MEDIUM
Black Level LOW
Color Gamut WIDE
Edge Enhance3er OFF
White Balance WARM
Method 20 Point IRE
Pattern Outter
White Balance:
IRE Red Green Blue
100 50 50 -50
95 11 5 -50
90 -20 29 -50
85 9 45 -30
80 -9 35 -50
75 5 30 -25
70 -16 11 -49
65 0 31 -25
60 -14 0 -49
55 -33 0 -30
50 -7 0 -24
45 -21 0 -16
40 -7 0 -24
35 9 0 -13
30 -17 0 -17
25 -14 0 24
20 -29 0 -17
15 -27 -5 12
10 -28 0 -17
5 0 0 0
Gamut
Color Tint
Red 0 -10
Green 8 4
Blue -1 0
Yellow -4 -11
Cyan -3 8
Magenta 2 -1
dmtaub is offline
post #596 of 1764 Old 07-14-2014, 10:56 AM
Taheer19's Avatar
Quoted: 69 Post(s)
Liked: 24
Settings:
Contrast 98
Brightness 55
H Sharpness 46
V Sharpness 43
Color 53
Tint R8
Expert Controls:
Noise Reduction OFF
Gamma MEDIUM
Black Level LOW
Color Gamut WIDE
Edge Enhance3er OFF
White Balance WARM
Method 20 Point IRE
Pattern Outter
White Balance:
IRE Red Green Blue
100 50 50 -50
95 11 5 -50
90 -20 29 -50
85 9 45 -30
80 -9 35 -50
75 5 30 -25
70 -16 11 -49
65 0 31 -25
60 -14 0 -49
55 -33 0 -30
50 -7 0 -24
45 -21 0 -16
40 -7 0 -24
35 9 0 -13
30 -17 0 -17
25 -14 0 24
20 -29 0 -17
15 -27 -5 12
10 -28 0 -17
5 0 0 0
Gamut
Color Tint
Red 0 -10
Green 8 4
Blue -1 0
Yellow -4 -11
Cyan -3 8
Magenta 2 -1
The sharpness seems way to high to me. As well as having to much color in the image as well as a lot of red push.
Taheer19 is offline
post #597 of 1764 Old 07-14-2014, 11:41 AM
lemming9's Avatar
How is the 3D on this TV?
I'm hoping to choose a new TV with 3D capability and wanted to get an idea of if Active/Passive and Plasma/LCD would be better for me. I'm leaning towards Active 3D Plasma and since one of the models in this thread covers that I'm hoping some people could help me and provide their views on my concerns.
The main reason I'm thinking Active and Plasma is for the wider viewing angles and faster refresh rates.
My main concerns are:
1. Do the inherent wider viewing angles for Plasma also include being able to watch 3D at a wider viewing angle? I know the overall effect is diminished being off axis but how far to the side would I be able to go on this TV? Would it be around/over 60 degrees? And how would this compare to a Passive 3D Plasma or an Active/Passive LCD?
2. Although not as important, some leeway on Head Tilt would be nice. Given the way Active Shutter works I would have thought this would be better on an Active set rather than a Passive. Is anyone able to lay all the way down and still get some sense of the picture on the TV?
3. Is a Plasma set better at reducing crosstalk than an LCD? How is the crosstalk on this set?
4. Is the native refresh rate on this set 120Hz? Seems like it would need to be to handle Active 3D properly but all I'm able to find out is that it has a 600Hz subfield rate.
I have some other questions about supported media formats but I'll leave them for now.
If people could give their opinions on the above it would be appreciated.
lemming9 is offline
post #598 of 1764 Old 07-14-2014, 12:15 PM
Taheer19's Avatar
Quoted: 69 Post(s)
Liked: 24
The TV that this thread is about isn't a 3D TV.
Taheer19 is offline
post #599 of 1764 Old 07-14-2014, 12:19 PM
dmtaub's Avatar
Quoted: 100 Post(s)
Liked: 34
Update: Definitely a blue stuck pixel. I can see it up close, within a couple of ft, on any screen. Calling LG today to see what my options are.
dmtaub is offline
post #600 of 1764 Old 07-14-2014, 12:39 PM
B T C's Avatar
Location: Lansing, MI via Kentucky, Georgia & Tennessee
Quoted: 466 Post(s)
Liked: 146
Slickdeals has the 60" 6650 for $699, plus free shipping, from Fry's
Taheer19 likes this.
B T C is online now
pb6600
