Do PDPs output multiple refresh rates unlike LCDs? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 05-04-2014, 03:46 PM - Thread Starter
el pablo's Avatar
Quoted: 20 Post(s)
I know that LCDs refresh rate outputs are fixed i.e. a 120hz unit with always output at 120hz despite being fed a 24, 30, or 60hz signal
It seems this wouldn't be true with PDPs since they can output at 96Hz but accept a 30/60Hz signal which isn't evenly divisible.
If this isn't true and a 96Hz PDP is fixed then wouldn't it require an additional type of telecine to display 30/60Hz signals to make it evenly divisible?
Someone please school me, thanks!
el pablo is offline
post #2 of 12 Old 05-04-2014, 04:25 PM
LarryInRI's Avatar
Quoted: 18 Post(s)
Liked: 190
Movies traditionally are made at 24 frames per second and shown using double shutter at 48 fps. Double that and you get your 96 fps.
Larry
LarryInRI is offline
post #3 of 12 Old 05-04-2014, 04:40 PM - Thread Starter
el pablo's Avatar
Quoted: 20 Post(s)
Larry
Thanks for your response Larry. I'm aware of that but am assuming a PDP that can output 96Hz isn't fixed at that refresh rate because it wouldn't be evenly divisible for 30 or 60hz input. This would lead me to believe that a PDP that can output 96Hz can also output 60Hz opposed to LCDs which have fixed refresh rate output which are evenly divisible. (i.e. 120Hz vs 96Hz)
Can anyone else please chime in? Thanks again!
el pablo is offline
post #4 of 12 Old 05-04-2014, 04:47 PM
LarryInRI's Avatar
Quoted: 18 Post(s)
Liked: 190
Yes, a plasma indeed can display at 60 or 96 Hz. BluRay disks store movies at 24 Hz. I'm not sure what is confusing you.
Larry
post #5 of 12 Old 05-04-2014, 05:52 PM - Thread Starter
el pablo's Avatar
Quoted: 20 Post(s)
So I was correct that PDPs can output multiple refresh rates opposed to LCDs that are always fixed.
It seems that explaining my rational for coming to this conclusion only led to confusion based upon your first response. I was only doing so someone could explain how PDP refresh rates work if I was incorrect. Thanks for taking your time to answer my question!
el pablo is offline
post #6 of 12 Old 05-04-2014, 05:55 PM
whipit's Avatar
Quoted: 101 Post(s)
Liked: 86
The only way you can use the 96hz mode is when you feed the tv 24p. Feeding it 30 or 60hz will get you 60p output.
whipit is offline
post #7 of 12 Old 05-04-2014, 06:09 PM - Thread Starter
el pablo's Avatar
Quoted: 20 Post(s)
Thanks for your input.
That is what lead me to believe that PDPs can output at different refresh rates i.e. 60 and 96hz etc vs LCDs which only output at a rate of 60, 120, or 240hz all the time based on the model.
el pablo is offline
post #8 of 12 Old 05-04-2014, 10:49 PM
KOF
KOF's Avatar
Quoted: 270 Post(s)
Liked: 227
Consumer plasmas can output in 60hz and multiples of 24hz. For a typical upper model Panasonic plasma, it can thus output in 48hz, 72hz, and 96hz with various levels of flickering. However, those multiples of 24hz can only accept 24hz as input. 48hz,72hz, and 96hz can't be accepted natively. That's why judders are still present on those modes.
Now, a professional Panasonic plasma can behave closer to LCDs. It can even accept 120hz natively, something not possible with consumer plasmas without hacking.
KOF is offline
post #9 of 12 Old 05-04-2014, 11:12 PM - Thread Starter
el pablo's Avatar
Quoted: 20 Post(s)
Wow, I didn't think an output of anything over 96hz was possible on a PDP!Thanks for the info!
How does plasma technology allow for the output of different refresh rates while LCD technology does not? Thanks again!
el pablo is offline
post #10 of 12 Old 05-05-2014, 12:02 AM
KOF
KOF's Avatar
Quoted: 270 Post(s)
Liked: 227
48hz and 72hz isn't too useful because of flickers, but at least it's there.
So here's how it goes. My Panasonic plasma for example can output in either 60hz or 48hz. When running at 60hz, it can accept 24hz, 30hz, and 60hz. When running at 48hz, it can only accept 24hz. BTW, movies aren't the only ones plasmas can accept at 24hz. My Geforce for example can output 24hz natively so it's possible to display games at 48hz. It's not terribly useful because of flickers, but there you go.
I'd love to play games on one of those professional Panasonic plasmas someday. It will natively support both 60hz and 120hz, just like CRTs, yum.
KOF is offline
post #11 of 12 Old 05-05-2014, 04:24 AM
whipit's Avatar
Quoted: 101 Post(s)
Liked: 86
If the tv has a d-sub connector it can accept higher rates at reduced resolutions. The official max in the list for my G10 is 85hz @ 1024x768. It also states that the refresh can go from 48 to 120hz and the resolution max is 1280x1024. So it looks like there's some options with that kind of input. In the same list HDMI and Component had shown standard resolutions/rates.
whipit is offline
post #12 of 12 Old 05-06-2014, 04:08 PM - Thread Starter
el pablo's Avatar
Quoted: 20 Post(s)
As far as I can see there are only a few PDPs confirmed to input/output 120hz and they are all Panasonic models:
http://www.avsforum.com/t/1438092/list-of-hdtvs-with-120hz-native-refresh-ability-forcing-1080p-120hz-via-dvi-or-hdmi-from-computer
It seems this is possible because the way these panels display 3D Bluray at 60fps (120hz). With other input I don't believe they output 120hz without connecting a compatible 120hz PC GPU:
http://www.blurbusters.com/overclock/120hz-pc-to-tv/
It would be interesting to see Bluray output from one of the compatible GPUs to see if it appears any different than 96Hz. There may be no difference between 24p 96hz and 120hz (difference between repeating the frame one more time) and the only benefit with 120fps PC games.
I shouldn't have explained my rational for believing why PDPs can output variable refresh rates. I should have just asked the question if they can (the post subject title) because I led people to believe I was asking something different. If PDPs did have a fixed refresh rate (i.e. PDPs that can output 96hz were fixed at 96hz) I was trying to understand how they could output 30 or 60hz because not evenly divisible. If these panel did have a fixed 96Hz rate then the only way I thought 30/60hz input could be displayed is some special type of telecine to convert to 96Hz.
Of course I was way over thinking everything and should of already known the answer (they do both so 30/60hz input output at 60hz and 24hz at 96Hz which is what made sense) Because I knew LCDs use a fixed refresh rate I was questioning myself and thinking maybe PDPs were the same because why could one and not the other? (Which I'm still trying to figure out) Of course not having variable refresh rates on a 120Hz LCD isn't an issue because 24, 30, and 60Hz are all evenly divisible. Then there are those that don't care about 24P to begin with.
el pablo is offline
