AVS Forum | Home Theater Discussions And Reviews
AVS Forum | Home Theater Discussions And Reviews (http://www.avsforum.com/forum/)
-   Plasma Flat Panel Displays (http://www.avsforum.com/forum/167-plasma-flat-panel-displays/)
-   -   Samsung pn51f5300 loses hdmi connection? (http://www.avsforum.com/forum/167-plasma-flat-panel-displays/1530416-samsung-pn51f5300-loses-hdmi-connection.html)
Plasma5300 05-05-2014 12:22 AM
Every once in awhile the connection between my ps4 and plasma tv will lose connection for a second then come back. Like a black screen will appear then it comes back on showing HDMI1/1920x1080/60p top bar. Weird. I have two ports and both do it. Any suggestions? Thanks guys i appreciate it
gus738 05-05-2014 06:42 AM
its normal changes resolution in that instance .
Plasma5300 05-05-2014 09:37 AM
Yea but it happens in the middle of a movie watching netflix. Or it happens in the middle of a game?
PlasmaPZ80U 05-05-2014 10:09 AM
1095 Attachment(s)
Is the PS4 connected directly to the tv?
Also, are you using a high speed HDMI cable and is it plugged fully in on both connectors?
Sometimes HDMI compatibility issues can occur like this, but it hasn't happened in my setup, which involves an avr in between the PS4 and this tv.
Plasma5300 05-05-2014 12:14 PM
Ps4 is directly connected to tv. Im using Monster Cable MC ISF750 HD-9 EFS 9-Feet high speed HDMI Cable. Very snug fit.
Plasma5300 05-05-2014 03:47 PM
So it could be the hdmi cable? It happened again 3 times back to back today while playing rayman legends ps4 disc. Now watching netflix and has happened in two hours. It seems like it happens when it starts warming up? Im confused
PlasmaPZ80U 05-06-2014 09:56 AM
1095 Attachment(s)
no, I don't think it's the cable (but if you have another length/brand lying around, try it just to be sure)
It could be a compatibility issue between the TV and PS4. Does the issue happen with other HDMI devices hooked up to the TV (like another game console, BD player, or set top box)?
gus738 05-06-2014 02:29 PM
No that cant be it . i have ps4 and 60 inch 5300
Plasma5300 05-07-2014 01:26 AM
I unplugged the hdmi cable from the ps4 and tv and switched ends. Thats all i did. Hasnt messed up yet. Hmmmmm. But i am seeing white sparkles every now and then but only while watching netflix so i think its in the source. So not sure but Monster is sending me a new cable anyways.
gus738 05-07-2014 09:43 PM
i see white sparkles too from only mp4 file weeds it may be because its settings is too high . anyone else know what are these sparkles or dots that are white?
PlasmaPZ80U 05-08-2014 05:53 PM
1095 Attachment(s)
sounds like the cable then
try a simple monoprice.com $5 one
PlasmaPZ80U 05-08-2014 05:54 PM
1095 Attachment(s)
I thought that too since I have the PS4 and 51 inch F5300, but there could be variances between sets plus in my setup an AVR is involved.
gus738 05-08-2014 07:45 PM
yeah it may be a bad hdmi cable . is the mono price deal including shipping?
Plasma5300 05-14-2014 08:21 PM
I have to turn the ps4 on first then the tv. Its the only way i dont get sparkles in the picture. Weird.
PlasmaPZ80U 05-15-2014 09:19 AM
1095 Attachment(s)
Yesterday, I was calibrating my TV and when setting brightness (black level) on a black clipping pattern, there were dispersed white dots flickering and moving around (some kind of weird dithering effect) when viewing the TV from very close (nose up to screen for setting brightness precisely).
thisisichriss 07-05-2014 12:04 PM
**Bump**
I have been running into the same problem, where the video cuts out for a second. It cant be the HDMI because i tried it with my ChromeCast, and it does the same thing. The chromecast is plugged into the wall for power, so it couldnt be a power thing. Anyone know, or have any experience fixing this?
Plasma5300 07-05-2014 01:06 PM
Mine is the same way! I see it.
ctrlhomer 07-21-2014 01:30 PM
I have the pn60f5300 b panel, same exact issue. Seems to happen more on port 2 than port 1. But port 1 does experience the white artificating like affect with ps4/ps3 games, with slightly less cutouts.
I have tried 6 different cables...
Original ps4 one, 2 older cables, 2 Amazon basic hdmi cables, and my raspberry hdmi one that was originally plugged into port one no issues before using devices plugged into port 2.
The raspberry pi cable has been swapped around, when I use it in port 2 it only seems to cutout at the home screens, once the games load its may cut but not as much.
I am using those calibration settings, I just swapped to standard color instead of warm2
http://www.avsforum.com/forum/167-pl...using-ps3.html
I have had similar issues with bad hdmi cables before, but to have 6 bad cables is not realistic, could it be a bad hdmi controller card? Could it be the movie preset, I have it configured the same way for both ports, and that's the only thing they have in common. This is very strange. I almost want to get some kind of hdmi switch.
djsketchie 07-21-2014 01:45 PM
I've had this happen on my 51" F5300 recently as well. I had just mounted it on the wall, plugged the Roku stick in, and when the Roku finally booted up, the picture would cut out every 5-10 seconds, show the resolution bar at the top, then come back. This was happening with both HDMI ports, and I eventually unplugged everything, plugged everything back up, and voila, no more problem. It doesn't exactly inspire confidence, but it hasn't happened since, so I'm crossing my fingers it's just a software glitch that's corrected by a restart.
beergut1 10-12-2014 04:56 PM
I'm having the same problem with my hdmi coming from my HTPC.
Has anyone figured out a fix for this problem?
My Panasonic 42" 720p never had this problem.
I have tried a number of different cables and it still happens.
I'm getting quite annoyed by it and am thinking about returning an otherwise good TV.
Yaemish 10-24-2015 04:21 PM
My 60PN5300B is doing this on HDMI2 with PS4 plugged in. It happens every 2 min. I've seen the problem less frequently with my PC in the same port. Over the summer, I noticed it happened when the central air started up. Right now the air isn't on.
I haven't used PS4 in months, but it is the device that seems to cause the problem. I have yet to experience the problem in source1. Has anyone figured it out yet? I took my surround receiver out of the mix. I want to get it fixed under warranty of it is a known problem.
Yaemish 10-24-2015 04:24 PM
My 60PN5300B is doing this every few minutes with PS4 directly plugged in to HDMI2. I've seen my PC have the same problem inn the same port, but only when the central air kicked on. Right not it is too cold so the AC isn't a factor.
I plugged the ps4 in to HDMI1 and haven't had the problem yet. Has anyone figured this out yet and can it be something to do with the card in the TV? I would like to have it replaced before the warranty expires.
PhilipsPhanatic 10-24-2015 09:10 PM
Is everybody's firmware/software updated ? :confused: For both the Samsung 5300 and the PS4 ?
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
