Panasonic 42" 1080p Models - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 06-03-2014, 12:26 PM - Thread Starter
IFrederickI's Avatar
I am looking for a 42" TV needs to be 1080p I sit really close to it. It seems there are quite a few 1080p releases over the years. I know I will be buying a used TV but I want the best PQ I can find.
TC-P42S60 (2013)
TC-P42UT50 (2012)
TC-P42ST30 (2011)
TC-P42S30 (2011)
TC-P42G25 (2010)
TC-P42S2 (2010)
TH-42BT300U (2011) Does not have audio
EscapeVelocity likes this.
IFrederickI is offline
post #2 of 7 Old 06-03-2014, 01:42 PM
ChadThunder's Avatar
Quoted: 84 Post(s)
Liked: 63
Hi Frederick, if you sit at monitor distance you can still buy a monitor brand new
Panasonic TH-42BT300U (2011)
It is based on the VX300 with dual subfield design, power supply comes from VT20 and the board designs are quite beefed up from the ST30
ChadThunder is offline
post #3 of 7 Old 06-03-2014, 10:31 PM - Thread Starter
As far as picture quality what would the BT300U be closest to?
post #4 of 7 Old 06-04-2014, 07:45 AM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 501 Post(s)
Liked: 768
The BT300U uses the same core plasma panel module as the ST30 series but it has a different black filter on the panel, and the outer Anti-Reflective Filter is completely different.
The Pro monitors all use a conventional non-directional AR Filter since these are basically electronic signs used in a business environment and are viewed from all angles and are also sometimes mounted vertically, where the consumer model TVs use a Louver Filter that is designed to reject light from above.
Here's a related thread with a link to a nice review of it:
http://www.avsforum.com/t/1433087/panasonic-th-42bt300u/0_60
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #5 of 7 Old 06-04-2014, 09:05 AM - Thread Starter
I would be connecting a ps3/directv to it. It has no audio anything else I would need?
post #6 of 7 Old 06-04-2014, 09:18 PM
Quoted: 84 Post(s)
Liked: 63
Sorry I forgot to mention no speakers or stand or tuner included.
The official stand is called TY-ST20-K but other stands which attach to the wall mounting holes can possibly work as I have done on my 42PF30(below) just make sure it support the weight
The closest thing picture wise is the PF30 and VX300, all the guts are the same except for the dual subfield drive which doubles the number of displayable shades (only in Cinema and Monitor modes) and you will have alot more finer control over color.
For your future reference here is a list of compatible accessories and also the the RJ45/serial command list
https://panasonic.ru/upload/professional_displays/Compati_Emodel.pdf
https://panasonic.ru/upload/professional_displays/PEJ_C025_R2_BT300VX300_serial_command.pdf
post #7 of 7 Old 06-10-2014, 08:42 AM - Thread Starter
I found a P42S60 on craigslist with 230 hours on it. Very pleased
