Pre-purchase Question regarding Samsung 8500 Buzzing/Return Policy.... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 06-16-2014, 07:26 AM - Thread Starter
atwnsw's Avatar
Quoted: 20 Post(s)
I would like to buy the Samsung PN60F8500 and have heard the only possible complaint is the buzzing sound.
My plan is to buy it online however all of the companies say that you have to inspect the TV upon delivery/arrival and no returns accepted after delivery.
If you buy this TV and you are unfortunate enough to get a buzzing TV, what do you do? What does Samsung do? Make you pay the cost to mail it back? Send a tech to your house?
I want to understand what people who have this problem do?
Thanks in advance.
atwnsw is offline
post #2 of 8 Old 06-16-2014, 08:18 AM
hammerdwn's Avatar
Quoted: 169 Post(s)
Liked: 52
Your Tv comes with a one year warranty from Samsung. You can extend that another three months by registering the Tv on the Samsung support website. To obtain warranty service you will contact Samsung (see Samsung website). They will work with you on choosing a local authorized repair shop to do the work, this is when you need to speak up and request an shop that does in-home service. There is no charge (unless the repair shop has a policy that if they find no problem there is a charge for the trip - time and gas costs money). As for the buzzing- can be loose screws holding a board, could be a board, could be the panel. The shop will determine.
XBR-65Z9D | AVR-X2200W | UBD-K8500 | JRMC HTPC w/9 cable tuners | Fluance SV 7.1 + eD A3-300
hammerdwn is offline
post #3 of 8 Old 06-16-2014, 10:46 AM
Stereodude's Avatar
Quoted: 3093 Post(s)
Liked: 2239
And tell you it's in spec pretty much regardless.
Stereodude is online now
post #4 of 8 Old 06-16-2014, 10:51 AM
fierce_gt's Avatar
Quoted: 1628 Post(s)
Liked: 1570
buy from a good retailer. all the local ones here have 'no questions asked' returns within the first 30days or something.
I had no issues with the f8500, but the last tv I bought I tried to go for an LED, and I returned 3 TV's within that 30day period before I 'settled' on a CCFL lcd instead.
fierce_gt is offline
post #5 of 8 Old 06-17-2014, 04:18 PM
gus738's Avatar
Quoted: 59 Post(s)
Liked: 32
excellent tvBuy it at bb and be prepared to wow yourself with an excellent tv .Lcd led or not will have host of defect
Pioneer Elite PRO-111
Samsung 60PnF5300 af
panasonic px75u(r.i.p)Samsung 51f4500
XBL x117x831
PS4 gusx831
gus738 is offline
post #6 of 8 Old 06-17-2014, 09:57 PM
wxman's Avatar
Quoted: 3531 Post(s)
Liked: 2548
I got one of these and the buzz on my 64 was gone. Clean power maintained at 120v will help reduce buzz. Also the higher your altitude, the grater your chance at buzzing. Plasma is optimized for sea level.
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
LG 65EF9500
LG 65E6P
wxman is offline
post #7 of 8 Old 06-18-2014, 07:39 AM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 499 Post(s)
Liked: 766
If you receive a TV that buzzes abnormally loud, Samsung will probably not repair it under warranty. Their official stance over the years in response to customers requesting warranty repair for a buzzer is that "It's normal to hear buzzing at 15 feet" and they will not fix it.
The safest thing would be to buy from a reputable company that allows you or the delivery driver to power up the TV and make sure it's working properly before accepting it (like Cleveland Plasma or Amazon etc). DO NOT Accept the TV if it buzzes beyond a few feet, that is not how a TV should operate. Don't listen to owners who claim that it's normal because it is not.
Just connect the power cord and plug in a USB drive with bright break-in slides and see if it buzzes or not after powering it up.
A few years back i was present when my friend received his Plasma TV (from Amazon) and it buzzed right out of the box (we could hear it at about 5 feet away) and even the driver said "that's not normal, it should be quiet" so we boxed it up and the driver took it back. The replacement TV they sent a week later had zero buzz at 1 foot away and was a keeper.
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #8 of 8 Old 06-18-2014, 10:13 AM
fierce_gt's Avatar
Liked: 1570
I think saying 'zero buzz' is just as misleading as saying 'buzz at 15feet is normal'
ppl hear differently, and I don't expect any electronics to emit zero buzz. I definitely wouldn't consider my f8500 a 'buzzer'. it's not annoying, it's not noticeable when watching, but it's not 'zero buzz' either. truth be told, if I manipulate the install in the wrong way, I can actually make it sound worse, almost to the point that it is noticeable while viewing content.
anyway, I just think if you expect the tv to be 100% silent, you're going to end up sending back good units. there's a difference between detecting buzz at 15feet, and hearing buzz at 15feet while watching the tv. I definitely would not accept the latter, but I am able to tell whether or not my tv is on by the 'buzz' it makes as soon as I walk into the room, in some cases before. I could do this easily with crt's, the plasmas I've owned have actually been much quieter.
I would compare it to the buzz of an incandescent light bulb, or the background static of a midrange a/v receiver. it's there if you hunt for it, but you HAVE to hunt for it. it shouldn't be as loud or obvious as the buzzing you'd hear from fluorescent lights or a cheap dimmer switch
