Kuro Command Program - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #1 of 50 Old 06-23-2014, 10:40 PM - Thread Starter
makaveddie81's Avatar
Quoted: 348 Post(s)
Liked: 245
After developing Kuro Kapture (http://www.avsforum.com/forum/167-pl...1522255?page=1), I have now created a program that allows the user to run commands on any of the below Kuro models:
101fd
141fd
500m
600m
111fd
151fd
5020
6020
Non-US model equivalents to the above
8th generation sets
What does this mean? For starters, service menu access (by executing the proper commands) on any of the above models in one simple program.
Below are links to the required hardware.
? USB to RS232 Adapter
http://www.amazon.com/TRENDnet-RS-23...2+serial+cable
? Straight through RS232 Serial Cable (not a null modem cable).
Female to Female
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
I will be issuing this program after a $25 paypal donation is made to edwardrafii@gmail.com and PLEASE INCLUDE YOUR EMAIL ADDRESS IN THE PAYPAL NOTES SECTION.
UPDATE: Added 8th generation sets to compatibility list
ChuckZ and tubby497 like this.
makaveddie81 is online now
post #2 of 50 Old 06-24-2014, 05:51 AM
ShockFett's Avatar
Quoted: 17 Post(s)
Liked: 126
I really like this one. Super fast, easy to use, doesn't crash and doesn't mess up the display button like the other one lol! Also great its works on all displays. This is definitely my go to for services menu access!
Thanks Ed!
ShockFett is offline
post #3 of 50 Old 06-24-2014, 01:22 PM - Thread Starter
Quoted: 348 Post(s)
Liked: 245
Thanks Ed!
The program was your idea though... not sure why I didnt listen the first time you proposed it.
post #4 of 50 Old 08-08-2014, 08:16 PM
CherokeeMan's Avatar
Quoted: 62 Post(s)
Just wanted to say a big thanks to makaveddie81 for this program!
Had to replace the main assy in my 111FD & couldn't access the service menu
to run the auto adjust & final setup process per Pioneer Manual.
With the Kuro Command program it took me about 5 minutes to be up &
running. Now I've got my Kuro back!!
CherokeeMan is offline
post #5 of 50 Old 08-27-2014, 01:33 PM
buttonsw's Avatar
Quoted: 28 Post(s)
Hi Ed,
Does this program work in the same way that controlcal does?
Can I unlock the ISF modes and calibrate through the SM?
Cheers
Steve
Pioneer KRP-500A | Sony STR-DH810 Receiver | Tannoy HTS101 Speakers
buttonsw is offline
post #6 of 50 Old 08-28-2014, 01:50 PM - Thread Starter
Quoted: 348 Post(s)
Liked: 245
The program sends commands to the TV, so it can be used to unlock the ISF modes and adjust picture settings. Problem is, I dont know what the required commands are to accomplish this. If you do, simply issue the appropriate commands.
post #7 of 50 Old 08-02-2015, 01:24 PM
ke6dcj's Avatar
Please advise that with this program I can do both the "8.7 Execute 4-5 Auto Adjustment of 6.2 [4] Initialize and the FINAL SETUP" when I replace the AWW-1371 (main board) on my PDP-5020FD ?
If so, expect a donation soon.
Thanks in advance,
:-) neil
ke6dcj is offline
post #8 of 50 Old 08-02-2015, 09:45 PM
Quoted: 62 Post(s)
Thanks in advance,
:-) neil
Yes, you can, that's why I purchased it about a year ago.
post #9 of 50 Old 08-03-2015, 11:26 AM - Thread Starter
Quoted: 348 Post(s)
Liked: 245
Thanks in advance,
:-) neil
What symptoms was your 5020 experiencing prior to main board replacement? Were any of the lights blinking?
You can use the program to send any valid commands to the display, so yes the program will do the trick.
post #10 of 50 Old 08-11-2015, 02:45 PM
ke6dcj's Avatar
No lights blinking from the front. Can't see from the rear.
The TV's internal digital tuner isn't working, and even with a fresh reset, it doesn't work, and the menu option to scan for channels is greyed out.
Using the Kuro command software the error is: DTUNER PS/RST
Attached is a screenshot.
Service Manual for the 5020FD states time to replace main board: Pioneer AWW1371
:-( neil
Name:	5020FD tuner issue.jpg
ke6dcj is offline
post #11 of 50 Old 12-03-2015, 02:57 AM
Liked: 0
Hi,
would this work on the UK model? LX-5090?
narmi47 is offline
post #12 of 50 Old 12-03-2015, 08:33 AM - Thread Starter
Quoted: 348 Post(s)
Liked: 245
Originally Posted by narmi47 View Post
Hi,
Yes, just select the equivalent US model (111fd I believe) when prompted.
Even if you select the wrong model, no harm will come to your TV as the program does not send any commands that make changes to the TV's configuration. It sends read only commands.
post #13 of 50 Old 02-29-2016, 10:49 AM
Shawn1's Avatar
Quoted: 17 Post(s)
Hi makaveddie81,
The past few years I've been using a program called Kuro Control to reset my KRP-500M. Kuro Control is compatible with Windows only. Recently, my Windows XP laptop died, so I'm no longer able to use the program. I just bought a MacBook Air. Will your program work on my Mac? If so, are the commands that I use to reset my 500M using Kuro Control, the same for Kuro Command? Thank you.
Shawn1 is offline
post #14 of 50 Old 02-29-2016, 11:42 AM - Thread Starter
Quoted: 348 Post(s)
Liked: 245
Originally Posted by Shawn1 View Post
Hi makaveddie81,
The program works on Windows PC's only. Yes the commands are the same as both programs are merely a way to interface with the TV.
post #15 of 50 Old 03-04-2016, 04:06 PM
Liked: 0
I take it this program is still available? I'd like to get into the service menu of my 9G and I have a serial cable available.
Some quick questions; Any particular version of Windows required? Does it come with the command needed to enter the SM, or do I need to look this up?
Cheers.
TheGhorun is offline
post #16 of 50 Old 03-04-2016, 04:35 PM - Thread Starter
Quoted: 348 Post(s)
Liked: 245
Cheers.
I've tested it on Windows XP, 7, 8 and 10 and it worked flawlessly.
The commands can be found in the service manual for your specific Kuro model, but I can provide the commands needed to accomplish your task.
I'll send download link once you provide payment to my email address and walk you through service menu access.
post #17 of 50 Old 03-04-2016, 04:42 PM
Liked: 0
Thank you for the quick reply. It's in the middle of the night over here in Europe, I'll get back to you tomorrow.
post #18 of 50 Old 03-04-2016, 04:45 PM - Thread Starter
Quoted: 348 Post(s)
Liked: 245
Sounds good to me!
post #19 of 50 Old 03-05-2016, 07:34 AM
Liked: 0
Sounds good to me!
Back in front of a computer now, have some additional questions just to make sure this works.
Long story short; I bought a used PDP-LX5090H (the H-model, yes) reasonably cheaply, but it suffers from slight red tint to blacks. Thought I might as well give following the guides to fix this a go. I assume the program will work for this model? Not sure which US model is the equivalent.
I have an older PC with Windows XP installed that has a serial port, hence that question. Using a program called KuroTime (by ChelseaFan over at Avforums) there seemed to be no issues communicating with the TV through the cable I have. I would guess this means sending commands should also work?
post #20 of 50 Old 03-05-2016, 08:17 AM - Thread Starter
Quoted: 348 Post(s)
Liked: 245
Yes the program will definitely wkork with your computer. It is also fully compatible with the European models.
I can walk you through the red tint removal process via voltge tweaks.
post #21 of 50 Old 03-05-2016, 03:06 PM
Liked: 0
Thanks to makaveddie81 for the help with the correct commands to do the voltage tweaks using Kuro Commands. I can no longer see any red tint in the blacks of my LX5090H and the black levels are visibly improved.
The majority of my time was spent setting up one of my old PCs to get access to a serial port, the actual procedure of entering commands through the program was very easy.
For reference this TV has done 14-15000 hours according to the previously mentioned KuroTime.
post #22 of 50 Old 03-06-2016, 02:37 AM
raymen's Avatar
Hello makaveddie81
I have the same problem, and hope you can help me solve this.
also i have little dots in black aray`s and the purple snake.
But i love this tv so much, i want too keep it for a longer time
I have done almost everything too solve it.
And it didn`t help anyrthing
Thanx already
btw, i am from holland
Mvrg,
Raymen
raymen is offline
post #23 of 50 Old 03-06-2016, 09:46 AM - Thread Starter
Quoted: 348 Post(s)
Liked: 245
I appreciate the positive feedback.
post #24 of 50 Old 03-06-2016, 09:47 AM - Thread Starter
Quoted: 348 Post(s)
Liked: 245
Originally Posted by raymen View Post
Hello makaveddie81
Thanx already
Mvrg,
Raymen
What model kuro do you have?
Do you already have the cable and adapter necessary to communicate with the Kuro?
post #25 of 50 Old 03-06-2016, 12:40 PM
raymen's Avatar
I have the pioneer 600m
I have a laptop with windows 10 and a pc with windows 10
I have the cable
Mvrg
Raymen
raymen is offline
post #26 of 50 Old 03-06-2016, 09:34 PM - Thread Starter
Quoted: 348 Post(s)
Liked: 245
I have the cable
Mvrg
Raymen
My 141fd had the same two issues as your 600m so I will be able to help you resolve it.
Send payment to my email so I can send you the download link and we can tackle the problem.
post #27 of 50 Old 03-07-2016, 07:12 AM
xlc210's Avatar
Can this connect to my 101fd over LAN? That is one feature I love about Kuro Control.
xlc210 is offline
post #28 of 50 Old 03-07-2016, 07:45 AM - Thread Starter
Quoted: 348 Post(s)
Liked: 245
Unfortunately, no. I may try to add the feature in the future, though I'd have to do some research before implementing it.
post #29 of 50 Old 03-07-2016, 07:48 AM
raymen's Avatar
Okay,
I can not send an pm too you for now,
Have too do 5 more post
Mvrg,
Raymen
raymen is offline
post #30 of 50 Old 03-07-2016, 12:02 PM - Thread Starter
Quoted: 348 Post(s)
Liked: 245
Okay,
Mvrg,
Raymen
I just replied to your PM.
taboola here
