Samsung Plasma PN60E550D1FXZA no picture - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 06-28-2014, 09:15 PM - Thread Starter
Liked: 0
So, tonight I was watching the news and everything ws playing grey on my Samsung, 60" Plasma, 3D TV, model PN60E550D1FXZA, TS02
Went to take a shower and when I came out, the picture was black but I still had the news voice. I tried to re-boot the TV and then the picture and sound was gone and has not come back.
Can someone please help???
Thank you very much
Dennis
dgignac is offline
post #2 of 9 Old 06-29-2014, 01:21 PM
tom669's Avatar
Quoted: 149 Post(s)
Liked: 139
Thank you very much
Dennis
Check the panel very carefully around the edges for cracks. (Samsung plasma panels are known to spontaneously crack.)
Block out all light in the room and turn it on. Confirm if you see a brief flash from the screen or a slight glow from it while it is running.
tom669 is offline
post #3 of 9 Old 06-29-2014, 02:51 PM - Thread Starter
Liked: 0
I did what you have suggested and saw no light at all. Here is a little more info...
Samsung PN60E550D1FXZA
No picture, black screen
Replaced the Y-Main and buffers, X-Main and SMPS board with no luck.I measured the voltage on the Va, Vs, Vsc, and the Ve test pins. Upon startup of the TV, the voltage spikes to the required TV label voltage but very quickly degrades to 0 volts.
The Vs and Va test pins were measured on the SMPS board. The Vsc was measured on the Y-main board, the Ve was measured on the X-main.
Any thoughts?
dgignac is offline
post #4 of 9 Old 07-22-2014, 10:55 PM
Liked: 0
Any luck from here?
DiscoSteve is offline
post #5 of 9 Old 07-23-2014, 11:48 AM
Quoted: 14 Post(s)
Liked: 2
I had this happen four times under warranty and all 4 times the technician replaced the "A" board. This seemed to work for awhile, but eventually the same problem came back. I recently replaced the "A" board myself(no warranty) and it didn't correct the issue. As a work- around, I now turn the TV on until the sound is heard(no Picture). Once I hear it, I cycle power. When it turns back on, I have video and sound. I'm not sure if it's a "lazy" cap in a power supply or something else. When I see the brief flash, it comes on 100% of the time.
mprowland is offline
post #6 of 9 Old 07-23-2014, 11:52 AM
tom669's Avatar
Quoted: 149 Post(s)
Liked: 139
Do you have a digital multimeter available?
tom669 is offline
post #7 of 9 Old 07-23-2014, 12:16 PM
Quoted: 14 Post(s)
Liked: 2
I'm not sure about the (OP) dgignac, but I have everything from a voltmeter to a spectrum analyzer. I'm guessing the troubleshooting steps will apply to both of us.
post #8 of 9 Old 07-23-2014, 05:09 PM
tom669's Avatar
Quoted: 149 Post(s)
Liked: 139
Here is one thing you can try to see if it is a main board issue:
tom669 is offline
post #9 of 9 Old 07-24-2014, 04:05 AM
Quoted: 14 Post(s)
Liked: 2
Thanks a bunch! I'll try this in the next few days, seems fairly straight forward. I'm already guessing it's a SMPS but we'll see soon enough, Thanks again!!
black screen , no picture , plasma , Samsung
