Samsung freezes when changing HDMI Port - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By dzrbenson
post #1 of 9 Old 06-29-2014, 02:33 PM - Thread Starter
dzrbenson's Avatar
Hi,
Added 2 more pieces to the home setup, Apple TV and Wii U and not sure my TV likes them, Occasionally, well 4 times over the weekend, when switching HDMI channels my TV will lockup, become unresponsive for around 1-2mins then restart itself and all is good.
Wondering if anyone has seen this? checked for updated firmware but none out, will do a full reset tonight, If I can figure out how.
Samsung PS64F5500
HDMI 1 – Apple TV
HDMI 2 – ARC to Sound bar (Wii u connected to sound bar HDMI)
Hdmi 3 – Xbox One
So If im using the Wii U and switch to Xbox One it has the potential to lock up,
Thanks for any replies
dzrbenson is offline
post #2 of 9 Old 06-29-2014, 02:41 PM
M Code's Avatar
Quoted: 816 Post(s)
Liked: 499
Major issue is the Samsung display is not HDMI certified...
Without being certified Samsung components typically have major interoperability issues with other brands of HDMI products. Best workaround is to just use Samsung brand HDMI components..
One other suggestion is to retry the power turn ON sequence..
1. Display
2. AVR
3. Source components
Just my $0.05...
M Code is offline
post #3 of 9 Old 06-29-2014, 02:46 PM - Thread Starter
dzrbenson's Avatar
Thanks for the reply,
A little confused, Il give you my power up process,
Also where you say I should use samsung certified only, does that mean Samsung HDMI cables, as xbox and wii u cant really do much? I am using a Samsung soundbar.
1. TV Turns on
2. Soundbar turns on with TV
3. Turn on Xbox, Wii u or Apple TV etc.
Should I book a call with Samsung, or is this something I need to live with? It did not occur before, however I only had the Xbox to begin with.
post #4 of 9 Old 06-29-2014, 08:10 PM
Straybeat's Avatar
Originally Posted by dzrbenson View Post
Hi,
Samsung PS64F5500
HDMI 1 – Apple TV
Hdmi 3 – Xbox One
I have had 1 Samsung TV (out of a bunch of them) seem to get it's logic chip scrambled if you press too many buttons at once, requiring a reboot to reset everything, then it's fine. My old 58B650 would do this once in awhile, none of my others have though. I would put a call in just to see what you get from it? If anything, there will be a record of the call, so if something else happens in a year you might be covered.
Straybeat is offline
post #5 of 9 Old 06-29-2014, 08:21 PM - Thread Starter
dzrbenson's Avatar
Got a tech coming Thursday, happy for them to come as wanted to enquire about something else, when the TV was off the other day, and off at the wall, I got a small amount of static charge from it.
Guessing its just dust + carpet but worth a shot
Straybeat likes this.
post #6 of 9 Old 07-03-2014, 04:13 AM - Thread Starter
dzrbenson's Avatar
Well tech came today and was able to replicate.
He went to check the TV and all of a sudden a vertical lines appeared!!! Wtf talk about timing.
So he will be back next week to replace the panel and main board.
Now to pray I get no dead pixels.
post #7 of 9 Old 08-24-2014, 06:17 PM
Straybeat's Avatar
Hey DZR,
Whatever happened with this? Did you get the panel replaced okay and everything work?
post #8 of 9 Old 08-24-2014, 07:17 PM - Thread Starter
dzrbenson's Avatar
Hi,
Yeah Samsung came out and replaced the panel and mainboard, All been running fine since then
post #9 of 9 Old 09-20-2015, 04:25 AM
stuntz0rZ's Avatar
Liked: 0
I'm having this same problem with Samsung LN46A500T1FXZA.
Purchased September 2008. Guess this is a common issue with these displays. I'm not sure what to do at the moment as it is always working after the tv reboots. I really don't want a new one but might need to. the warranty period was only 1 year.
stuntz0rZ is offline
