AVS Forum | Home Theater Discussions And Reviews
AVS Forum | Home Theater Discussions And Reviews (http://www.avsforum.com/forum/)
-   Plasma Flat Panel Displays (http://www.avsforum.com/forum/167-plasma-flat-panel-displays/)
-   -   Default settings for Windows ClearType text? (http://www.avsforum.com/forum/167-plasma-flat-panel-displays/1589145-default-settings-windows-cleartype-text.html)
StinDaWg 07-02-2014 10:36 PM
I was messing around with ClearType settings trying to get text to look a little better on my plasma. I wanted to go back to the default settings and compare but realized after the fact that there is no way to reset these and I can't remember which boxes are the default. I did a google search and found the default settings for Windows 7, but Microsoft changed it in Windows 8 and there are now 5 boxes rather than 4. If anyone is running Windows 8 and can tell me what the default settings are it would be greatly appreciated!
StinDaWg 07-02-2014 11:06 PM
Sorry, I actually meant to post this in the HTPC section, but if anyone here can still help I'd appreciate it, or a mod can move it!
TheronB 07-03-2014 02:58 AM
Are you using the 1080p direct option? That and the Chrome font fix made mine look pretty good.
I'll try to remember to check the default settings when I get home.
StinDaWg 07-03-2014 04:31 AM
Ya, I'm using 1080p, but I have a 60" tv, so the pixel density is kind of low.
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
