Need Plasma Wall mount recommendation for 58" Samsung and 42" Panasonic - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 07-03-2014, 05:17 AM - Thread Starter
Rockstead's Avatar
Quoted: 14 Post(s)
I don't know if I need to provide specific model #s of the plasmas or if mounts are universal enough, the Samsung is already 6 years old and the Panasonic about 4 or so. I could come back with model #s if required.
Is there a general consensus on which is the best mount (doesn't have to be cheapest), I don't mind ordering from ebay/Amazon, etc.
I know there are different options when it comes to mounts, I figure the ones that go flushe against the wall are nicest? Or do people end up regretting not being able to change angles?
Rockstead is offline
post #2 of 2 Old 07-03-2014, 08:34 AM
BobRiff's Avatar
Quoted: 12 Post(s)
I just used one of these to mount my Samsung 43".
I got it from Amazon for $29.
I was quite happy with the quality and I believe their claim that it would hold up to 165 lbs. when properly installed.
Cheetah Mounts APTMM2B Flush Tilt (1.3" Profile) TV Wall Mount Bracket for 32-65 inch LED, LCD and Plasma Flat Screen TVs Up To VESA 684x400 and 165lbs
BobRiff is offline
