60"+ Plasma as PC monitor(input lag/burn in a concern?) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 07-12-2014, 03:27 PM - Thread Starter
stunaz's Avatar
So looking around for a new TV that i mostly use with an HTPC (gaming/web browsing/etc) and its always been LCD. But LCDs have their own problems so i'm trying to figure out if a plasma would do. Every time i see one the picture quality (to me) is easily 2x better than any LCD. Just never bought it due to burn in.
So question is who's used one with a PC and what kind of problems were you running into. Was input lag an issue? how about burn in from the constant windows/browser stuff ?
stunaz is offline
post #2 of 7 Old 07-12-2014, 06:07 PM
chrisherbert's Avatar
Quoted: 17 Post(s)
I wouldn't get a plasma as a PC monitor. Because of the way they work, full screen whites will be dinner than content with less white (some plasmas are dimmer than others). This isn't necessarily a big concern with video content because it's pretty rare to have any scene that's that bright. Web browsing, however, involves a LOT of white.
If it's going to be used for video content 90% of the time, sure, go for plasma. I would specifically look at the samsung f8500, as it's the brightest one available. If it's more like 50-50, LCD is probably a better choice.
chrisherbert is offline
post #3 of 7 Old 07-12-2014, 06:36 PM
ChadThunder's Avatar
Quoted: 84 Post(s)
Liked: 63
I use one daily its a 42" Panasonic professional monitor built in 2012, only use it because my CRTs are aged and I refuse to use LCD after years of problems/dissapointments, despite not having any issues I would probably not recommend someone to use a plasma in that way, all products have a life span and it is pretty wasteful to do everything on the plasma despite how nice it looks keep the thing for gaming and movies and you will appreciate even more when you do use it
Input lag varies from set to set but all the monitors I have tried have been around one frame(16ms) and should beat out the fastest televisions by a fraction because you can easily disable all processing
I would recommend the Panasonic 65PB2U which is unbelievably cheap at the moment and might actually best the 65ST60 as it was based on that model, worst case it matches it but my gut says it is an upgrade
edit: if you are paranoid about burn-in here are some advice from another post of mine
Originally Posted by .
1) download a few wallpaper packs and have the background change often (every 5-10 minutes)
2) hide the taskbar
3) use the televisions built in pixel orbiter
4) do not max out contrast when web browsing and similar things (you are just aging the panel for really no good reason)
5) run in the panel for 10-20 hours before using as a monitor
ChadThunder is offline
post #4 of 7 Old 07-12-2014, 08:14 PM
StinDaWg's Avatar
Quoted: 451 Post(s)
Liked: 217
Since when is $2200 unbelievably cheap?
StinDaWg is offline
post #5 of 7 Old 07-12-2014, 08:30 PM
Quoted: 84 Post(s)
Liked: 63
I saw $1800 somewhere, that is cheap in my book considering pro models can go brighter, are built to last and come with a 2 year warranty
Vendors are selling the same model for $5000 in other regions
post #6 of 7 Old 07-13-2014, 02:25 AM
StinDaWg's Avatar
Quoted: 451 Post(s)
Liked: 217
Why does it weigh almost double that of the 65ST60? Is the touchscreen really that heavy?
StinDaWg is offline
post #7 of 7 Old 07-13-2014, 02:53 AM
Quoted: 84 Post(s)
Liked: 63
double front glass adds alot of weight, I assume there is no touch screen it should work by light detection like the other models
