help me Fix my SAMSUNG PN51E530A3FXZA - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By tom669
  • 1 Post By mikejoins
post #1 of 5 Old 07-24-2014, 06:28 PM - Thread Starter
Liked: 1
So my TV wont turn on. absolutely nothing, no standby light. So I figured it would be the power supply, yet all the contact points VA, VE, VS, VSC had the correct voltage, none the less I replaced it... and still same results.
So now I'm thinking it could be the main board or the Y-Main that makes a buzzzing noise. The LED light on the logic board blinks every second, but when I unplug the Y-Sustain, it blinks slower... I could really use a techy individual to lead me through my diagnosis.
I've searched on the internet, but can't find a manual to follow. Any suggestions?
Please and Thank you
mikejoins is offline
post #2 of 5 Old 07-25-2014, 04:45 AM
tom669's Avatar
Quoted: 149 Post(s)
Liked: 139
Sounds more like a main board fault to me.
On the logic board, there's a little 4 pin header. Take a piece of wire, a crocodile clip, or a jumper that is used on hard drives (0.1", 2 pins) and connect the pins marked 3 and 4 together. Then carefully disconnect the flat ribbon cable linking the main A/V board and the logic board. Then plug in the TV, and check if you get cycling test patterns on the display.
RyanHomsey likes this.
tom669 is offline
post #3 of 5 Old 07-27-2014, 06:27 PM - Thread Starter
Liked: 1
Alright, took a step forward tonight! I shorted pin 3& 4 and forced the tv into its cycling test patterns... went through the colors with no dead pixels or black bars!
So this means main board should be replaced?! I will order the main board and tell you of my results!
Thank you!
post #4 of 5 Old 07-31-2014, 09:26 PM - Thread Starter
Liked: 1
It worked! The main board needed to be replaced, $20 shipped and my tv is working again. Thank you!!
post #5 of 5 Old 08-01-2014, 02:43 AM
tom669's Avatar
Quoted: 149 Post(s)
Liked: 139
Great to hear you fixed it, I had a D450 series with same fault.
tom669 is offline
plasma , pn51e530a3fxza , Samsung
