This Is A Longshot But... - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By tom669
Old 07-25-2014, 02:44 PM - Thread Starter
Rudester's Avatar
I have a Philips plasma 50PF9731D/37 and I just realized that this tv has the Ambilight surround feature but the lights(left,right, top) don't turn on .
How can i figure out whats preventing the feature from functioning correctly?
Does anyone know where i can get the ambilight parts?
Rudester is offline
Old 07-25-2014, 03:45 PM
tom669's Avatar
Quoted: 149 Post(s)
Liked: 139
Ambilights will probably be available from used parts dealers.
First, try check ambilight menu option and try fixed colour, see if those options work.
Do you have a digital multimeter?
tom669 is offline
Old 07-25-2014, 07:32 PM - Thread Starter
Rudester's Avatar
I have a multimeter. None of the options turn the feature on...
Rudester is offline
Old 07-26-2014, 02:52 AM
tom669's Avatar
Quoted: 149 Post(s)
Liked: 139
You will have to open the set up and provide pictures of the parts inside, I have fixed a Philips amblight TV but not this one.
tom669 is offline
Old 07-28-2014, 07:36 PM - Thread Starter
Rudester's Avatar
alright have the setup opened. will upload pics Laptop is about to run out of juice.
Rudester is offline
Old 07-30-2014, 02:57 PM - Thread Starter
Rudester's Avatar
Quick update. Since putting the tv back together...I have observed the ambilight on the left side turn on twice randomly. It's on for about 2 or 3 seconds and then it turns off. Ambilight mode was on color.
Still won't turn on via the tv menu...
Rudester is offline
Old 08-01-2014, 01:23 PM - Thread Starter
Rudester's Avatar
bump anyone?
Rudester is offline
Old 08-01-2014, 02:10 PM
tom669's Avatar
Quoted: 149 Post(s)
Liked: 139
Is it me or does your PSU have a few popped capacitors on it?
Rudester likes this.
tom669 is offline
Old 08-01-2014, 07:44 PM - Thread Starter
Rudester's Avatar
Looks like two of them on the lower left side of hue psu....yup....
Might have to open her up again to check the capacitor model.
Think I can use the same capacitor that the people of the 9631 thread used?
Rudester is offline
