Help need to transport a"naked" 5020 - AVS Forum | Home Theater Discussions And Reviews
Old 07-31-2014, 12:59 AM - Thread Starter
sleepyhollowtoo's Avatar
Is currently on its Pioneer oem stand. Speaker bar has been removed. Will use a van or suburban. Thought of covering it with soft cotton sheet or getting that soft packing thin spongy white foam from BB, then some bubble wrap and /or cardboard on face side, maybe a flat screen box over all that, then lash all of that to a flat 2nd or third row seat back "gently" just to keep it upright. Screen side away from seat. Drive easy, don't hit any potholes (yeah, right). Any other suggestions? All thoughts and ideas appreciated. Help me protect an "endangered" KURO.....THANKS
sleepyhollowtoo is offline
Old 07-31-2014, 04:08 AM
chunon's Avatar
Quoted: 2013 Post(s)
Liked: 1773
Amazon sells a plasma transportation box , little pricey but if you want to protect your set might do the trick.
chunon is online now
Old 08-01-2014, 08:29 AM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 499 Post(s)
Liked: 766
When my friend moved his 60" Kuro we installed the table stand (after covering it completely with a few layers of blue painters tape to protect it from scratches), then we covered the screen with a soft blanket to protect the surface of the glass, then laid a few layers of cardboard over that, then bubble-wrapped the whole TV tightly with packing tape. The movers were careful with it and it survived just fine.
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
Old 08-01-2014, 01:03 PM - Thread Starter
Thank you both for your replies. I looked at the shipping boxes, but that seems more work/cost/time for a 30 mile self move. This is only to move the 5020, not a whole house move. Randy, I like the painters tape idea, I assume it removed easily/neatly/completely? I'm tending towards an approach like yours...soft bed sheet to keep scratches down then movers blanket or other soft blanket, maybe bubble, then cardboard for stability and immobilize attached to a seat back. If anyone has any other ideas it would be greatly appreciated. TIA.
Old 08-01-2014, 03:06 PM
tom669's Avatar
Quoted: 149 Post(s)
Liked: 139
May sound like sacrilege, but I moved a PDP-LX5090 in the back of a Peugeot 206 (tiny car) by laying it down on about 3 layers of bedsheets and putting some padding on top of it. It survived the journey fine, and I've moved many other plasmas the same way hundreds of miles, and never broken a single one. You must always face the display up - never down - and pad it well.
tom669 is offline
Old 08-01-2014, 09:34 PM - Thread Starter
Tom: HA HA Got a good laugh when I looked up the Peugeot 206. Was hoping you didn't have to carry it vertical and across your lap! The 206 is about the size of a Honda Civic 2 door for those that don't want to look it up.
