Samsung Plasma PN60F5350, installed in stand, some wobble ok? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 08-07-2014, 02:37 PM - Thread Starter
djb5f's Avatar
Quoted: 129 Post(s)
Liked: 62
The base itself does not move but you can easily wobble the TV front to back an estimated good 5 degrees each way. More than I thought anyway. I don't know what is typical/acceptable.
Should I be able to move it like this? It was only 8 screws; four for the base to stand mount and four for the TV to the stand mount. I also only hand -tightened until they were tight with the screw driver I was using and not stripping. Didn't want to over-tighten with a drill.
Should I re-install to the base or do TVs have some front to back wobble if you wobble it?
djb5f is offline
post #2 of 6 Old 08-07-2014, 05:17 PM
discopaul's Avatar
Quoted: 113 Post(s)
Liked: 50
I would re-install. It should be stable. No wobbles.
discopaul is offline
post #3 of 6 Old 08-07-2014, 10:58 PM
StinDaWg's Avatar
Quoted: 450 Post(s)
Liked: 214
Mine wobbles too, I'm assuming because you can tilt it side to side. It's a little more than I would like, but it's not going to fall off the stand or anything just sitting there.
I have to ask too, do you have the pink tint issue?
StinDaWg is offline
post #4 of 6 Old 08-08-2014, 02:06 AM
orion2001's Avatar
Quoted: 462 Post(s)
Liked: 311
Wobble is normal. The stand doesn't inspire a ton of confidence. It is perfectly fine for a stationary TV on a table/flat surface but you definitely do not want to transport it anywhere with the stand still attached.
orion2001 is offline
post #5 of 6 Old 09-14-2014, 08:12 AM
Jaerba's Avatar
Liked: 0
This is literally what happened to me 2 weeks ago so no, do not trust the stand.
The stand was re-installed about 4 months ago and the TV had been sitting in place on an entertainment cabinet since then. We were watching TV, and all of the sudden it just came crashing down. Now Samsung says the damage isn't covered under the warranty because it happened due to user negligence, for not noticing that the cheap ass stand was giving in over time. >.>
There's plenty of similar stories on other forums, so I suggest you find a more stable solution such as mounting or at least use straps, because the stand truly is a piece of crap and these plasmas are way too heavy for it.
Jaerba is offline
post #6 of 6 Old 09-14-2014, 10:40 AM
Dave in Green's Avatar
Quoted: 1003 Post(s)
Liked: 681
I've only had mine two days, but the first thing I noticed is that the stand is wobbly. My setup is in a stable location where it's never moved, so I'm not too worried about it. But I wouldn't trust it at all if it was in a place where it needed to be moved even infrequently. Disappointingly cheap design that could have been made much better with very little effort. If you over-tighten the screws I can see serious risk of stripping the threads. Just curious where the typical failure point is and if there's an easy fix?
Dave in Green is offline
