Is the PN60F5300 pentile? plz need answer. - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By RandyWalters
  • 1 Post By Xbone89
post #1 of 24 Old 08-10-2014, 10:44 AM - Thread Starter
Quoted: 12 Post(s)
Liked: 2
Hey everyone I'm new to the site and I'm in need of help.. I have one day left to place an order on a samsung plasma set. I was thinking of getting the F5300 60 inch but I hear that size of panel is pentile.. is this true... thanks in advance.
Xbone89 is offline
post #2 of 24 Old 08-10-2014, 11:32 AM
LJ25's Avatar
Quoted: 60 Post(s)
The 60f5300 is indeed a pentile display.
LJ25 is offline
post #3 of 24 Old 08-10-2014, 11:52 AM - Thread Starter
Quoted: 12 Post(s)
Liked: 2
ah okay thank you for the reply.. I guess 51 inch it is then.
Xbone89 is offline
post #4 of 24 Old 08-10-2014, 03:11 PM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 520 Post(s)
Liked: 775
Why? In the variious pentile discussions wasn't it determined that it's not an issue at normal viewing distances? Are you sure it would be a problem for you at your viewing distance? Others have said it is not.
StinDaWg likes this.
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #5 of 24 Old 08-10-2014, 11:33 PM - Thread Starter
Quoted: 12 Post(s)
Liked: 2
well I will be sitting about 9 feet away.. and will be using it 90% for gaming on xbox one.. I've been gaming on a LED for the last 4 years and the last thing I want is a 60 inch blurry tv hehe..
Xbone89 is offline
post #6 of 24 Old 08-11-2014, 12:11 AM
locomo's Avatar
Quoted: 69 Post(s)
Liked: 40
9' away, get the 64F5300.
locomo is offline
post #7 of 24 Old 08-11-2014, 02:19 AM
StinDaWg's Avatar
Quoted: 451 Post(s)
Liked: 217
I watch a 60F5300 from 8' away and it's clearer than the 5 year old 50" Panasonic plasma it replaced. It would be stupid IMO to get the 51" when the 60" is barely any more expensive. There is a big price jump from 60" to 64" but almost nothing between 51" and 60".
StinDaWg is offline
post #8 of 24 Old 08-11-2014, 08:04 PM - Thread Starter
Quoted: 12 Post(s)
Liked: 2
so you guys are basically saying that at 9 feet the 60 is a better choice, and picture clarity wise it will be the same as the non PenTile 51''?
Xbone89 is offline
post #9 of 24 Old 08-11-2014, 08:32 PM
KOF
KOF's Avatar
Quoted: 270 Post(s)
Liked: 225
Those guys are saying it in terms of movie contents. For games, pentile will be more troublesome, I would also grudgingly recommend the 51 inch one if the 64 inch one is too expensive for you. I'm personally going to buy a pentile display (Samsung H5000) myself though. (Ironic, yes) Happy with the current Panasonic S60 plasma, but I want to go brighter. Games can always use less aggressive ABL.
KOF is offline
post #10 of 24 Old 08-11-2014, 08:33 PM
BenDB's Avatar
Ugh. Tough call.
At seven feet, I can easily see the pentile effects, and they drive me batty. When I was in store, I was watching ESPN, and one place it was really visible was the edge of white lettering on the screen. So small text, like the left column showing what topics are coming up on SC, or scores, showed the effect. Instead of a smooth(ish) edge to the letters, it was a bit jagged, sort of like the edge of a postage stamp.
Would you see it at 9 feet? Tough to say. That is beyond ideal viewing distance anyway, and for gaming I like to be even closer. Note that Samsung is careful to not say it isn't visible at suggested (THX sort of suggested) viewing distances - they always say 'typical' distances, which tend to be huge in America for various reasons.
Would the picture be better than a 51" at that distance? It will be a lot bigger, at least. I would probably go with the 60, myself. Can you find one in a store?
Can you swing the 64"? How about a used 64" or a used 65" panny off of craigslist?
Good luck
BenDB is offline
post #11 of 24 Old 08-11-2014, 08:51 PM
locomo's Avatar
Quoted: 69 Post(s)
Liked: 40
At that distance get the 64". It's a non-Pentile.
locomo is offline
post #12 of 24 Old 08-11-2014, 10:28 PM - Thread Starter
Quoted: 12 Post(s)
Liked: 2
Thanks for all the feed back guys I really appreciate it, I'm ordering this TV through my work at the Brick.. the two size options are 51'' and 60'' inch models.. I live in a small city in Canada so it's much harder to get good tv's here that wont cost an arm and a leg, but maybe the 51 inch wont be so bad.. going from a 40 inch to 51 will be a difference, but 60 just sounds beasty
Xbone89 is offline
post #13 of 24 Old 08-12-2014, 02:41 AM
StinDaWg's Avatar
Quoted: 451 Post(s)
Liked: 217
I think what you are just seeing is poor upscaling by the tv and/or the stores feed. I have some 720p ESPN content that I play with madVR, and when using NNEDI3 upscaling text looks nearly perfect, with bicubic or lanczos it is jagged.
Xbone, get the 60" or you'll be kicking yourself. I game some on it and it looks awesome. I upgraded from a 50" to 60" and the size difference is huge.
StinDaWg is offline
post #14 of 24 Old 08-12-2014, 10:31 AM
BenDB's Avatar
Possible, I suppose, but I am not sure it matters.
What I can tell you is that the same text on televisions next to it, including a 51" plasma, were not at all jagged.
So it would need to be an combination of a certain upscaling algorithm along with the Pentile display.
In any case, it means there is source material that 'shows off' or 'exposes' the weakness of the Pentile display. Whether you see it in day-to-day use would be a matter of the source material.
And don't forget, I was viewing the 60" from five to seven feet. If you are seeing it from further back, the difference is (literally) too small to see.
BenDB is offline
post #15 of 24 Old 08-12-2014, 01:08 PM
EchoOne30's Avatar
Liked: 32
I have the 60F5500, which is also pentile, and let me assure you it is not noticeable in the very least. Maybe once you get to about 3' away you can see it. But we sit 9' away on the couch, and the picture is razor sharp. If you're paranoid about it you can probably convince yourself it's noticeable (as evidenced in this thread), but if you forget it, you can't see it whatsoever.
EchoOne30 is offline
post #16 of 24 Old 08-12-2014, 05:36 PM - Thread Starter
Quoted: 12 Post(s)
Liked: 2
well gents I went ahead and got the 60 inch.. I'm fairly convinced the Pentile panel wont be an issue from the sound of things. I just want to thank each and one of you for the feedback
EchoOne30 likes this.
Xbone89 is offline
post #17 of 24 Old 08-12-2014, 07:25 PM
imawheel's Avatar
As I'm considering this set, I'd love to hear your thoughts on it. Especially as it relates to blu ray and gaming. Also, where did you get it?
imawheel is offline
post #18 of 24 Old 08-12-2014, 08:11 PM - Thread Starter
Quoted: 12 Post(s)
Liked: 2
for sure I will give my thoughts when it arrives on the 22nd I will be playing ps4,xbox one and a few blu ray movies.. and I bought it through my work place at the brick.
Xbone89 is offline
post #19 of 24 Old 08-12-2014, 09:10 PM
skidawgz's Avatar
Quoted: 24 Post(s)
Liked: 45
I have a ZT and a dreaded pentile 60F5300. It is really not a big deal.... i have hooked the TVs up to the same source simultaneously before.
As everyone reasonable states, once you are 4'+ back you cant see the pixel structure well.
AVR: Marantz 7008 Phono: Pro-Ject Debut III Speakers: BW CMC2 + 2xCM9 (front) + 2xCM5 (rear)
TV: Panasonic 65ZT60, Samsung 60F5300
skidawgz is offline
post #20 of 24 Old 08-12-2014, 09:14 PM
skidawgz's Avatar
Quoted: 24 Post(s)
Liked: 45
Bought the 60F6300 specifically for gaming. The ZT's one and only weakness is IR and I use that for TV/movies/gaming. The Samsung seems lovely for gaming so far. Played Destiny beta on it and lots of Borderlands 2. The diff between the two sets is black level and color depth. The colors are much deeper on the ZT.
I played color slides for 200 hours and then started gaming. Not even a slight trace of IR to be found. Even if there was, I'd not care. The TV gives so much for the money.
skidawgz is offline
post #21 of 24 Old 08-12-2014, 09:30 PM
imawheel's Avatar
What about input lag? Noticeable? Thanks for the response!
imawheel is offline
post #22 of 24 Old 08-12-2014, 09:51 PM - Thread Starter
Quoted: 12 Post(s)
Liked: 2
I think the F5300 has slightly higher input lag, but I seen input lag as low as 38 on the f5500 on display input sites.
Xbone89 is offline
post #23 of 24 Old 08-13-2014, 12:31 AM
StinDaWg's Avatar
Quoted: 451 Post(s)
Liked: 217
Of course the 51" looked sharper right next to it. The pixel density is much higher on the smaller set.
StinDaWg is offline
post #24 of 24 Old 08-13-2014, 12:18 PM
skidawgz's Avatar
Quoted: 24 Post(s)
Liked: 45
seems to be good to me. I put it in game mode and I don't notice anything especially delayed. I don't look for issues and I have not had any glaring problems with it.
I am both a PC and console gamer. PC is hooked up to a PC monitor not a TV. PS3 and PS4 hooked to plasma. Considered a Sony W800 but I'm just too hooked on plasmas value for the $$.
skidawgz is offline
