Pn64f8500 remote problem - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 08-14-2014, 02:21 AM - Thread Starter
Liked: 0
Hi , I got samsung plasma pn64f8500 today and it does not respond to both remotes it came with , I able to control it from tv itself only. called samsung and they said they gonna send me new remote. Doesn't make sense to me . It does not react to any of my universal remotes. Is there a way to reset tv , maybe? . gonna call samsung today . Just wondering if someone had this problem in a past . Hate to think it might be hardware problem .
Dmirva is offline
post #2 of 6 Old 08-14-2014, 03:38 PM
fierce_gt's Avatar
Quoted: 1628 Post(s)
Liked: 1570
assuming you haven't blocked the ir receiver on the tv in any way?
the 'fancy' remote needs to be sync'd to work correctly I believe, but that wouldn't explain why the other doesn't work, or your universal remotes. so to me it sounds like the tv is the issue, not the remotes.
Displays: Samsung PN64F8500/JVC X35
AVR: Pioneer VSX-1130K, 7.1/5.1.2 audio
Sources: HTPC(Enby), PS3, XBOX360, Wii
Control: Harmony One
fierce_gt is offline
post #3 of 6 Old 08-14-2014, 04:00 PM
hammerdwn's Avatar
Quoted: 169 Post(s)
Liked: 52
Does this work:
Instructions for pairing remote to tv
tried pairing and re-pairing?
XBR-65Z9D | AVR-X2200W | UBD-K8500 | JRMC HTPC w/9 cable tuners | Fluance SV 7.1 + eD A3-300
hammerdwn is offline
post #4 of 6 Old 08-14-2014, 04:20 PM
wxman's Avatar
Quoted: 3518 Post(s)
Liked: 2542
Sounds like an issue with the ir sensor on tv. I never paired up my standard remote. I just put the batteries in and turned the tv on. Worked ever since. Same with my universal remote. Try resetting your tv if the instructions from previous poster does not work. Also try completely unplugging tv by turning tv off, and removing power cord from back of tv. Wait a minute and plug back in, then try it.
LG 65EF9500
LG 65E6P
wxman is offline
post #5 of 6 Old 08-14-2014, 04:27 PM
wxman's Avatar
Liked: 2542
One way to reset without remote is to use toggle in back, go to menu, support, diagnosis and reset.
LG 65EF9500
LG 65E6P
wxman is offline
post #6 of 6 Old 08-16-2014, 09:30 AM - Thread Starter
Liked: 0
Got tech from samsung coming on wed
Dmirva is offline
