Can Someone Explain What Each of the Parts in a Plasma TV Do? - AVS Forum | Home Theater Discussions And Reviews
 5Likes
  • 1 Post By PlasmaPZ80U
  • 4 Post By tom669
post #1 of 17 Old 08-19-2014, 12:45 PM - Thread Starter
PlasmaPZ80U's Avatar
Quoted: 2289 Post(s)
Liked: 705
I just got the service manual for my Samsung PN51F5300AFXZA Plasma TV. I've included a link to the wiring diagram, which labels all the parts on the back panel. Can someone explain what each part does and whether, for example, this layout is consistent with other plasma TVs like recent Panasonics, recent LGs, and other recent Samsungs.
http://api.viglink.com/api/click?for...Fusp%3Dsharing
RyanHomsey likes this.
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
SVS Prime Bookshelf and Prime Center
Sony SS-CS5 Surrounds and Cambridge S20 Rear Surrounds
Rythmik LV12R
PlasmaPZ80U is offline
post #2 of 17 Old 08-19-2014, 03:31 PM
tom669's Avatar
Quoted: 150 Post(s)
Liked: 140
Y-buffer: scans the rows of the panel to select which line to program with pixel data, also passes sustain current from Y-drive during sustaining period (making the panel light up in each subfield ~600Hz) If failed = No image or brief flash when panel turned on (can also be a cracked panel.)
Y-drive: develops the complex Y-drive sustain waveform including line selection and panel drive. If failed = Mal-discharge or no image.
X-drive/X-buffer: provides opposite sustain waveform and erase/initialisation periods. If failed = Pink image or no image.
Logic/Main Board: control of plasma panel, and conversion of video inputs to acceptable panel format.
SMPS: provides power for it all at approx 205V & 55V
E-buffer/F-buffer: connects to panel address drivers to pass data signals to panel, as part of addressing phase.
Layout is more or less identical to modern panels. LG & older Samsungs separate the panel control onto a different board.
tom669 is offline
post #3 of 17 Old 08-20-2014, 11:13 AM - Thread Starter
Liked: 705
thanks, that's very helpful
would it be correct to assume the logic board and main board on this set are on the same PCB?
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
Rythmik LV12R
post #4 of 17 Old 08-20-2014, 01:10 PM
tom669's Avatar
Quoted: 150 Post(s)
Liked: 140
Yes.
tom669 is offline
post #5 of 17 Old 08-21-2014, 01:20 PM - Thread Starter
Liked: 705
I have another question. Is the firmware and service menu settings/data values stored on a single PCB like the main/logic board or is it spread among other PCBs and the panel too? Also, what is the link between the firmware version and settings/data values in the service menu?
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
Rythmik LV12R
post #6 of 17 Old 08-21-2014, 01:21 PM - Thread Starter
Liked: 705
For example, I noticed after a main board swap on this model that the MRT value (total hours on panel) did not reset to zero.
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
Rythmik LV12R
post #7 of 17 Old 08-22-2014, 04:56 PM
tom669's Avatar
Quoted: 150 Post(s)
Liked: 140
Usually, it's stored in the control board. Your set combines the two into one board, which makes it awkward for swapping boards, as it means potentially the hour count could get out of sync with the panel. Not sure how or if this is easily correctable.
tom669 is offline
post #8 of 17 Old 08-22-2014, 06:53 PM - Thread Starter
Liked: 705
So, the control board on a set that has separate logic and main boards would be the logic board or main board? And would that board need to be part of the panel for it to know how many hours are on the panel? I'm a bit confused.
post #9 of 17 Old 08-23-2014, 09:33 AM
tom669's Avatar
Quoted: 150 Post(s)
Liked: 140
Control board == Logic board. Different names for the same things. The board just keeps track of hours in its internal memory, adjusting drive waveforms as the panel ages.
tom669 is offline
post #10 of 17 Old 08-23-2014, 09:42 AM - Thread Starter
Liked: 705
so the "PDP Option" screen that shows the MRT value and panel temp is basically the stuff related to the logic board?
(https://drive.google.com/file/d/1cLb...it?usp=sharing)
And where does the firmware/service menu reside on? the main board, logic board, both, or is not localized to any PCB and rather is scattered across various parts (including panel)?
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
Rythmik LV12R
post #11 of 17 Old 08-23-2014, 11:28 AM - Thread Starter
Liked: 705
One more question is when a panel is swapped, which boards are considered the driver boards and part of the panel? I heard Samsung makes the panel/driver boards (panel assembly) as one unit to reduce manufacturing costs.
Are the following part of the panel assembly: X-Buffer, Y Buffer, X/Y Drive/Main, and two E Buffers? Leaving behind just logic, main, and SMPS?
And is the 'function' (http://www.shopjimmy.com/samsung-bn9...tion-board.htm) merely what allows you to control the TV from the jogstick or does it do more than that as well?
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
Rythmik LV12R
post #12 of 17 Old 08-23-2014, 01:56 PM - Thread Starter
Liked: 705
I want to say thanks in advance for any responses plus the ones you've given so far, since it's hard to get this info from Samsung or even online with a simple search. I like to understand how these things work, which is why I've obtained the service manual for my set plus looked at part listings for my model. It also seems the BFXZA (2014) version of this set is different in terms of the panel and PCBs (logic board might be separate from main board and part of panel, I think).
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
Rythmik LV12R
post #13 of 17 Old 08-24-2014, 04:22 AM
tom669's Avatar
Quoted: 150 Post(s)
Liked: 140
Those values will be stored on the control board, read back by the service menu, which is executed on the main board.
The control board, X-main, Y-main, E-buffer, F-buffer and Y-buffer are all part of the panel. In some cases, the SMPS is included with the panel module.
tom669 is offline
post #14 of 17 Old 08-28-2014, 12:10 AM
ivan2011's Avatar
Quoted: 25 Post(s)
I would like to ask if i may, what adjustments are required after a main board swap as far as adc, wb, etc?
ivan2011 is offline
post #15 of 17 Old 08-28-2014, 02:08 AM
tom669's Avatar
Quoted: 150 Post(s)
Liked: 140
Usually none unless you had the TV calibrated in which case it may need to be recalibrated or you might just be able to use the last values the calibrator used, if he wrote them down.
tom669 is offline
post #16 of 17 Old 08-28-2014, 03:28 AM
ivan2011's Avatar
Quoted: 25 Post(s)
Thanks for the reply, does the white balance need to be adjusted at all in the sm?
ivan2011 is offline
post #17 of 17 Old 08-28-2014, 03:31 AM
tom669's Avatar
Quoted: 150 Post(s)
Liked: 140
No, the factory values are good enough for most people. If you just adjust the Brightness/Contrast/Colour/Sharpness/etc in the user menu then they will be adequate.
tom669 is offline
