SAMSUNG (ps51d6900dm) TURNING ON ISSUE - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-24-2014, 07:39 PM - Thread Starter
Liked: 0
The problem is the tv turns on and gets to the logo but then turns off! tries 3 times and for safety reasons stops trying to turn the tv on i believe.
I did a few checks and by no means am i very knowledgeable when it comes to fixing tv's but i checked all my voltages and they seem to be fine and disconnected other boards yet still came to the conclusion its the power supply.
I then heard about heating the board with a hairdryer to see if it turns on! which it did turn on. So i isolated it to a part of the board and found when i pushed on the IC the tv stayed on when not heated. I then believed it was a cold solder joint. It worked after re soldering this area for a week! then the same problem happened again! Is this part likely to be causing this problem and if so where can i get this part as i have had no luck looking myself!
Photo attached of IC i believe is faulty!
Panzer_green is offline
post #2 of 4 Old 08-24-2014, 09:01 PM - Thread Starter
Liked: 0
Im new to being on a forum so if i have added this to the wrong spot please let me know! Kind regards Martin
post #3 of 4 Old 08-25-2014, 05:01 AM
tom669's Avatar
Quoted: 149 Post(s)
Liked: 139
When you say turn on... Does the display light up at all, or are you only hearing the relay click?
tom669 is offline
post #4 of 4 Old 08-25-2014, 06:15 AM - Thread Starter
Liked: 0
It turns a back light on then switches off straight away. If left unplugged for a bit the first time its turned on it will show the Samsung logo before turning off.
diy , fix , help please , plasma , Samsung
