I did ask a similar question in the relevant thread but I find some questions get overlooked due to the speed at which the threads move.
So anyway I'm hoping some of you can confirm if what I'm seeing is an issue or normal.
Basically what I noticed recently is that when powering up the VT60, once the screen goes from black (start up logo) to an image, there is a quick "sparkle" of black pixels that appear on the image.
To further test this I have been switching from a black screen say a blank input, or changing channels using the internal tuner, and again once the screen goes from all black to a light colored image I see black pixels sparkle briefly.
Now I have to be extremely close to see this, some would say it's a non issue. However my concern at this stage is that it may be the start of something more serious.
I would really appreciate it if anyone can confirm whether this happens on their set, simply by switching from an all black screen to an image, and looking if you see black pixels sparkle quickly on the light parts of the image.
No forum rule but does this really cry for a dedicated thread ? First of all you are having to press your nose to the screen to even see the behavior, I seriously doubt your set is unique. Not sure what the exact cause is but my advice is to stop worrying about things you have no control over. I can guarantee if you call Panasonic about this you will not not get a positive response. Just my 2 cents, I'll move on but I really think you are stressing over nothing.
However the reason for my concern is that I've never noticed this "issue" on previous panasonic plasmas.
I appreciate that I need to be extremely close to see this "issue", but my concern is that if it is infact not normal for the VT60 and possibly pixel misfire or something, then as I'm still in the return period I would simply return the panel.
I would rather avoid a situation where I ignore something, then 6 months later the issue gets worse and I then have to mess about with panasonic repair agents replacing panels etc.
So the reason I've even asked this question is for reassurance, i.e if most people said it was indeed normal behavior when going from a black screen to a light colored one then I'd know. However if a majority said their panel did not exhibit this behavior I'll simply return the panel.
Now before anyone suggests I simply return the panel if it's bothering me, I'd answer that it doesn't bother me at this stage as I can't see it from a normal viewing distance. It's more the worry that it's an issue that could get worse.
I understand where you are coming from but as I have mentioned I see the "specks" on the screen wipe so that is 2 panels that exibit the same behavior. I have approx 4400 hours on my panel now and no issues related to pixel misfires etc. Maybe that doesn't ease your mind, I am willing to perform the test later on this evening if it is something I can easily do within my setup.
If you were able to perform the test for me later on this evening and report back it would be much appreciated.
It's just a case of going from a black screen to a light coloured image, I usually use a blank input and then switch to an input with an image on, the black specs similar to what you've witness on the scrolling bar appear briefly.
Alright I will give it a try and report back. Other than this worry what are your general thoughts about the VT60 ? I am amazed on a daily basis with my set. I am hoping it lasts long enough for OLED to be perfected
Honestly you are not missing much from the ZT, they are pretty much identical in most viewing environments. I also think the fan issue is more prevelant on the ZT. Don't get me wrong fantastic set but I have no regrets. I had a VT50 which was a great set it its own right but had the yellow blob issue and had to return it. I agree on LG hopefully someone else picks up the OLED banner and runs with it.
LG is apparently faltering with OLED. Reports of canceled Canadian orders...I don't see anyone else getting on board anytime soon if they bail. I would buy an LG in a heartbeat, as the OLED tech is that good.
It's a little hard to tell from the video but if you are seeing magenta sparkles in a bright white background then the green sub-pixel is not firing reliably. This is indicative of a driving timing pattern which is a bit out of alignment. It could get worse over time as the phosphors lose efficiency but the timescale is probably pretty long (years, not months). It's not really harmful in and of itself so it depends on how noticeable it is during normal viewing.
Changing the sustain voltage might help but I have no idea what that particular service menu setting will do. If someone else has tried it with no ill effects then go ahead.
Getting in the service menu is Hold down volume button on TV then info button 3 times I believe. The VSUS setting I don't recall, I can test out this evening for you though. Maybe someone else remembers ?
bummer, if you can research/find out which register controls the rising ramp slope of the reset pulse (sometimes called Yrr or Yset), lengthening this parameter will get rid of the magenta sparkles. It will also raise your blacks a bit but it doesn't look like you need to change it very much to clean up the problem.
Related Threads
AVS Forum
34M posts
1.5M members
Since 1999
