Samsung PN60F5300 No Power! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 11-03-2014, 09:22 AM - Thread Starter
Cyndi7's Avatar
Liked: 0
I have a Samsung PN60F5300AFXZA that was delivered on 3/25/14. It worked great up until a thunderstorm on 8/27 when lightning struck a tree in my backyard (it’s in my living room at the front of the house). Power went off and came right back on, everything else anyway. It was on before the power went off and has never turned back on. No standby light, no power, nothing. Nothing else was damaged. Receiver, cable box, cable modem, router, PS3, Wii and blu-ray in the same surge protector are all fine.
I tried leaving it unplugged for a few days and it still didn't work.
At first, I thought that it would be the fuse on the power board that is located close to the power inlet. Nope, it has continuity. I also tried a different cord.
After doing some research on the forum, I thought that the problem would be some capacitors on the power board. There were no visible issues with any of the capacitors or anything else. I went ahead and ordered a replacement power board. I installed it and still nothing.
What should I do next?
Cyndi7 is offline
post #2 of 10 Old 11-03-2014, 11:10 AM
hpp8140's Avatar
Quoted: 201 Post(s)
Liked: 65
Main Board
hpp8140 is online now
post #3 of 10 Old 11-10-2014, 06:19 PM - Thread Starter
Cyndi7's Avatar
Liked: 0
Thanks! I got the new main board in the mail today and installed it. It works again!!! The original power board was fine.
I saw another post that mentioned a multiplexer on the main board being damaged by lightning which requires the whole board to be replaced. Does that mean the damage to the main board was done by a magnetic field, EMP or transient static electricity from lightning proximity?
Cyndi7 is offline
post #4 of 10 Old 11-10-2014, 07:17 PM
RWetmore's Avatar
Quoted: 323 Post(s)
Liked: 174
Congrats on the successful self fix.
RWetmore is offline
post #5 of 10 Old 04-17-2016, 10:05 AM
snyper99's Avatar
Quoted: 20 Post(s)
I am having a similar issue as the OP except mine just shut off on its own the other night and wont come back on. I've read about the 8500's having bad power supplies and (or) the Y-board being bad. I still need to pull the back off to see if hopefully it just blew a fuse instead of it being something more costly.
snyper99 is offline
post #6 of 10 Old 04-25-2016, 12:03 AM
PhilipsPhanatic's Avatar
Quoted: 386 Post(s)
Liked: 50
Does the 5300 red LED flash any troubleshooting codes like other plasma TVs did years ago (Philips, Panasonic) ?
PhilipsPhanatic is offline
post #7 of 10 Old 04-29-2016, 01:38 PM
snyper99's Avatar
Quoted: 20 Post(s)
It doesn't do anything at all, no clicks, buzzing or flashing lights. I pulled the back panel off and took my meter to a fuse and it has continuity. I looked at the capacitors and they all seemed to be fine, here are some pictures of the insides. The "fuse" im referring to can be seen in the last picture.
ID:	1413482   Click image for larger version
ID:	1413490   Click image for larger version
snyper99 is offline
post #8 of 10 Old 06-19-2016, 08:42 AM
snyper99's Avatar
Quoted: 20 Post(s)
bump
snyper99 is offline
post #9 of 10 Old 08-08-2016, 09:53 PM
swaik2006's Avatar
Liked: 0
power out
bump
mine just went out too, all these tvs months of each other, warranty just ended, this sucks, is it easy to replace board?
swaik2006 is offline
post #10 of 10 Old 08-08-2016, 11:41 PM
Quoted: 386 Post(s)
Liked: 50
Spoke to a guy recently who told me that all of today's HDTVs -- including the Samsungs (which he owns) -- have poor-quality Chinese circuitry and parts.He repairs them for a living.
I was surprised to hear this, since I had assumed the quality had improved from 5-10 years ago as early bugs had been worked out. But apparently, cost pressure has led to the use of inferior parts and chips and the like.
Says he sees lots of problems that happen, like the vertical line problem on the Samsung SmartTVs. Happened to a friend's TV recently and he says it is unfixable and "just happens" -- sometimes fixing itself based on temperature/weather.
