Samsung F8500 has stopped transmitting 3D: HELP! - AVS Forum
Old 01-02-2015, 05:53 AM - Thread Starter
Ronald Epstein's Avatar
Quoted: 26 Post(s)
Liked: 87
Suddenly, without reason, my Samsung F8500 has stopped transmitting 3D
Now, it does show a blurred 3D image on the screen
It is just not transmitting the signal to the glasses.
I have tried 3 different pair of glasses from the ones included with the display to special $50 Active3D glasses I have purchased
None of the glasses will sync with the Samsung.
I first noticed the problem when I tried to play a 3D game on my PS4. At first, I thought it was the fault of the PS4 itself.
Then, today, when I tried to watch a 3D movie, I saw the blurred image on screen but the glasses would not sync.
I tried all these things....
1. Went to menu settings on the Samsung. 3D is turned on. Display shows 3D image
2. Tried several 3D movie titles. All showed blurred 3D image. None of them synced with my glasses
3. Tried several different glasses. All had fresh batteries and/or were recently charged
4. Updated my display to the latest firmware
So, any reason why the display might suddenly not be syncing with the eyewear as it has been for nearly the past year?
Ronald Epstein is offline
Old 01-02-2015, 07:04 AM
eric3316's Avatar
Quoted: 752 Post(s)
Liked: 928
Did you try resetting the TV.
eric3316 is offline
Old 01-02-2015, 07:07 AM
kucharsk's Avatar
Quoted: 220 Post(s)
Liked: 139
Have you tried re-pairing the glasses with the TV?
kucharsk is online now
Old 01-02-2015, 07:56 AM - Thread Starter
Quoted: 26 Post(s)
Liked: 87
There is juice in all the glasses. I have rechargeable ones that show they are charged.
The batteries in the Samsung glasses are still good. In fact, I just opened up a new pair.
I know how to pair the glasses with the display. I do it all the time when I watch a 3D movie.
I am not certain I want to reset the display. It has been calibrated and I don't want everything to go back to default.
Is there a possibility something is wrong with the display transmitter that it is not properly transmitting the signal to the glasses?
The display is showing a blurred image so it is displaying what it should. It's the communication with the eyewear that is the problem.
Thanks for all your replies thus far
Old 01-02-2015, 08:01 AM
kucharsk's Avatar
Quoted: 220 Post(s)
Liked: 139
You didn't answer the question of whether the glasses were paired.
You typically only need to do this once, not even after a battery change, but if the 3D transmission hardware is broken re-pairing would fail.
Old 01-02-2015, 10:20 AM - Thread Starter
Quoted: 26 Post(s)
Liked: 87
The glasses pair simply by pressing the button on them. The display recognizes the transmission and there is a connection.
So, yes, based on that, the glasses have been previously paired.
Old 01-02-2015, 10:44 AM
Blue Rain's Avatar
Quoted: 135 Post(s)
Liked: 38
Try a long press and then a short press.
Also, sometimes the 3d defaults back to off so check that also.
Polk 7.1
Samsung PN60F8500
73" 73738 Mits DLP
Onkyo TX-NR3008
Panasonic AE4000 Projector
Blue Rain is offline
Old 01-05-2015, 01:35 PM - Thread Starter
Quoted: 26 Post(s)
Liked: 87
I am the OP and wanted to follow-up with everyone on this issue...
Suddenly, the 3D on the Samsung is again working.
Not certain what the hell the problem was, but I did some HDMI
juggling and suddenly found the glasses were syncing again.
So, back to display nirvana with my Samsung F8500.
Thanks to all of you for your assistance.
