Plasma TV Lifespan? On average how long can they go for? - AVS | Home Theater Discussions And Reviews
 7Likes
post #1 of 43 Old 03-21-2015, 04:32 PM - Thread Starter
DRC72's Avatar
Quoted: 59 Post(s)
Liked: 26
I've had my Hitachi Plasma TV for almost 7 years, and it's still going strong. Generally how many more years can I expect it to last?
Sent from my AT&T iPhone 6 Plus using Tapatalk
DRC72 is offline
post #2 of 43 Old 03-21-2015, 05:57 PM
videoaddikt's Avatar
Quoted: 20 Post(s)
60,000 hrs seems to ring a bell. I think that is for when your display has half the brightness. Likely something else will fail before you get there. I think the newer models are now rated closer to 100k hours.
Samsung PN51F8500, Emotiva UMC200, Emotiva XPA-5, Samsung BD-H5900 BluRay, Dish Hopper, Furman Elite pf-15 conditioner, Dali Ikon (Ikon6, Vokal2, OnWalls) Outlaw Audio LFM-EX subwoofer.
videoaddikt is offline
post #3 of 43 Old 03-21-2015, 06:30 PM
wxman's Avatar
Quoted: 363 Post(s)
Liked: 333
Half life on new plasmas are around 100,000 hours per the post above. In other words, that's 11.4 years if you leave your tv on 24 hours a day, 365 days a year.
wxman is online now
post #4 of 43 Old 03-21-2015, 06:40 PM - Thread Starter
DRC72's Avatar
Quoted: 59 Post(s)
Liked: 26
Well I certainly don't do that, but 11.4 years sounds like a long time. I hear a bunch of numbers thrown around, Usually 7 to 10 years is what I hear, and that's with normal on and off use.
DRC72 is offline
post #5 of 43 Old 03-21-2015, 07:35 PM
fierce_gt's Avatar
Quoted: 1245 Post(s)
Liked: 1247
to be honest, this is a question I don't think anybody could answer. there are ppl that for one reason or another are just 'hard' on electronics, and they may find their TV's fail every 2-3yrs. others, don't even realize they are babying their display and it'll last 20yrs no problems.
Displays: Samsung PN64F8500/JVC X35
AVR: Pioneer VSX-1018AH, 5.1 audio
Sources: HTPC(Mediabrowser), PS3, XBOX360, Wii, Sony DVP-CX995V
Control: Harmony One
fierce_gt is offline
post #6 of 43 Old 03-21-2015, 07:49 PM
breezy2012's Avatar
Quoted: 101 Post(s)
Liked: 46
Does screen saver time count toward the panel's lifetime hours?
Sometimes I'll be relaxing in the HT room after dinner and get sleepy and just sort of close my eyes and fall asleep there on the couch. When I wake up the screen saver is on (and has been for hours). I usually do this a few times a month (it's very comfortable down there) so that would be an extra few hundred hours a year.
Since no picture is playing (just the little Samsung icon bouncing about) and the screen is otherwise black I wasn't sure if that would tax the screen the same way a full picture does.
breezy2012 is offline
post #7 of 43 Old 03-21-2015, 08:04 PM
Quoted: 448 Post(s)
Liked: 277
Then you have the issue of a failure that can be fixed with a board replacement but only if you can find one. This happened to a friend of mine who had a Phillips display. It was only 3 years old and already the replacement board he needed wasn't available. So its not only the panel but also other components that may cause you to have to toss the display.
Samsung 64F8500, Panasonic 65VT50, Oppo 95, Tivo Roamio for OTA, Dish VIP722, Marantz AV8801 preamp, Rotel Amps, Atlantic Tech 8200 speakers, Seaton Submersive HP, Calman 5, Chromapure, VideoForge HDMI II, Klein K10A, i1Display3pro, i1pro2, eecolor colorbox.
JimP is online now
post #8 of 43 Old 03-22-2015, 12:55 AM
cr671's Avatar
Quoted: 23 Post(s)
I have a Hitachi 42" plasma I've had for 6 years as well and it's still going strong. I didn't really have a good reason to upgrade to my Samsung 60" except we simply wanted a larger screen size.
I thought about selling it, but decided to hang into it & put the Hitachi in our spare room, being that plasmas are now extremely hard to come by.
Until OLED comes down to a reasonable price point, (Which won't happen for quite some time) I'll be all set for many years to come.
S5 tap'n
cr671 is offline
post #9 of 43 Old 03-22-2015, 01:06 AM
Quoted: 232 Post(s)
Liked: 132
How do they do that?
xvfx is online now
post #10 of 43 Old 03-22-2015, 01:25 AM
andy A's Avatar
Quoted: 16 Post(s)
On just about 10yrs with our old Samsung HP-S5053. It just got moved to the bedroom to make way for the new 64in plasma.
andy A is offline
post #11 of 43 Old 03-22-2015, 01:41 AM
sarahb75's Avatar
Quoted: 122 Post(s)
Liked: 58
Thumbs up Just Don't Be Turning Your TV On And Off More Than You Have To
I should think that if you don't abuse your Hitachi, then unless your TV becomes the victim of a close lightning strike, or some very unusual power surge, odds are good that it will give you another 7 years of faithful service.
BTW, in my opinion, one thing that constitutes abuse of a TV is turning it on and off multiple times a day. Powering up is the hardest thing on a TV, so I tend to turn sets on in the afternoon and leave them on til I go to bed. And, knock on wood, the large number of TVs I've owned over the last 40 years have needed extremely few repairs.
People worry too much about TVs raising their electric bill. About 3 years ago Consumer Reports noted that if the average cost of electricity in the U.S. is considered, a Panasonic 50" plasma they had tested, would use just $50 worth of electricity in a year with average use. I believe they defined average use as 6 hours a day, but I'm absolutely certain their calculation used a figure no less than 5 hours.
sarahb75 is offline
post #12 of 43 Old 03-22-2015, 02:05 AM
fluxo's Avatar
Quoted: 105 Post(s)
Liked: 95
Generally these sets fail because some board or connector fails. The panel half-life is almost irrelevant.
RandyWalters, DavidHir and Edllguy like this.
fluxo is offline
post #13 of 43 Old 03-22-2015, 04:56 AM
RWetmore's Avatar
Quoted: 174 Post(s)
Liked: 110
Right. I agree with the advice of minimizing how often the set is turned off and on. Some sets even have a feature that allows you to turn the screen off while leaving the set on.
If a plasma set is babied and not the victim of some kind of power surge, I would think could last 10 years or more.
RWetmore is offline
post #14 of 43 Old 03-22-2015, 05:11 AM - Thread Starter
DRC72's Avatar
Quoted: 59 Post(s)
Liked: 26
No I definitely don't abuse it all. Heck I think the picture looks better than ever these days. My father had an LG plasma that lasted just under 5 years. It just decided not to turn on one day. From what I read online, his particular model was known to have circuit board failures. As for my electric bill, I doubt my plasma is contributing a lot. It's actually an energy star rated model.
DRC72 is offline
post #15 of 43 Old 03-22-2015, 08:40 AM
fierce_gt's Avatar
Liked: 1247
I wasn't really referring to any single component in particular. I'm not somebody that tends to get things fixed, unless I can do it myself. the way the market was, it didn't make any sense to spend 500bux to have a product diagnosed, when you could buy a superior one brand new for only a couple hundred more. I think it's the 'norm' to consider flat panels as non-repairable. My friend is a manager of the claims(warranty) department at a local shop, and she says they only repair about 10% of the claims.
if we were only talking the panel itself, I'd probably say the 60k-100k hr life span is a good rule of thumb. but it's far more likely some $3 cap blows on a board after 10k hrs, and something like that we just can't predict. and whether that cap will lead to a catastrophic failure, be easily diagnosed, etc, who knows.
JimP and Super Eye like this.
post #16 of 43 Old 03-22-2015, 08:41 AM
fierce_gt's Avatar
Liked: 1247
ask them, I've yet to have a tv fail before it was obsolete...
post #17 of 43 Old 03-22-2015, 08:47 AM
TCARCIO's Avatar
Quoted: 78 Post(s)
Liked: 68
Funny, I just did the same thing. My Panny 42" plasma is 10 years old and still working fine. I bought a new Sammy 60" plasma and moved the Panny to my bedroom.
TCARCIO is offline
post #18 of 43 Old 03-22-2015, 08:55 AM
Dennis Dickerso's Avatar
Gave my in-laws a Panasonic plasma twelve years ago and it's still going strong.
Dennis
Dennis Dickerso is offline
post #19 of 43 Old 03-22-2015, 10:58 AM - Thread Starter
DRC72's Avatar
Quoted: 59 Post(s)
Liked: 26
Wow! How much did it run you at the time?
DRC72 is offline
post #20 of 43 Old 03-25-2015, 06:50 AM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 230 Post(s)
Liked: 576
I tried to give my 89-year-old mother-in-law my trusty old 2005 42" PX50U, but the old bat prefers the 40" Sony LCD that i temporarily loaned her and she won't give it back
In my case, i paid $3,500 for that Panny 42PX50U back in 2005, and although it still works perfectly i can't even get $200 for it on Craigslist
The first Panasonic Plasma panels were rated for 30,000 hours till half-brightness (same as the tube TVs), then around 2005 it was bumped up to 60,000 hours, then a few years after that they claimed 100,000 hours. But that's just for the panel - the various circuit boards inside could blow at any given time (just like any other electronic device nowadays).
Chise likes this.
Randy
Sony 55W800B, Panasonic TC-P55ST60, TC-P50GT50, TC-P46G10, TH-42PZ700U, TiVo Series3 & Premiere, TWC Cisco 8742HDC DVR, Onkyo TX-SR333 AVR, URC R40 Remote.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #21 of 43 Old 03-25-2015, 07:02 AM
eric3316's Avatar
Quoted: 777 Post(s)
Liked: 949
Let's not forget, even if nothing blows on the TV and it does reach it's half brightness life the TV is still operable. It is not like it shuts off when it hits that number, it just loses it's full brightness.
Now for a plasma this might be bad for some since they usually start out with less brightness then other techs but for Samsung F8500 owners, that shouldn't be an issue as half brightness will then bring it down to normal plasma standards. LOL
I have a 42" Insignia that I have had for 7 years. Granted on a black screen half of it looks grey and the other half looks like a lighter gray but it is still working!
eric3316 is offline
post #22 of 43 Old 03-25-2015, 07:05 AM
Quoted: 122 Post(s)
My parents bought a Panasonic TC-P50S1 at the beginning of 2009 and it still runs and looks great!
Edllguy likes this.
Michael Vincent Praino is online now
post #23 of 43 Old 03-25-2015, 02:51 PM
Quoted: 20 Post(s)
I just sold a Samsung plasma that is 7 years old. It ran several hours a day, most every day. It was calibrated in 2009, never missed a beat and still has a great picture.
post #24 of 43 Old 03-25-2015, 03:33 PM - Thread Starter
DRC72's Avatar
Quoted: 59 Post(s)
Liked: 26
My 50' Hitachi ran me $1300 back in 2008. Back then that was a great deal for plasma.
DRC72 is offline
post #25 of 43 Old 03-25-2015, 03:50 PM
kucharsk's Avatar
Quoted: 415 Post(s)
Liked: 235
My Panasonic plasma is going strong at ten years and I haven't had to turn up the brightness yet.
kucharsk is online now
post #26 of 43 Old 03-25-2015, 04:01 PM
Super Eye's Avatar
Quoted: 22 Post(s)
Liked: 24
This is true but true for any TV technology whether CRT, Plasma or LCD TVs lit by CFL or LED.
True again. Every TV I ever owned failed due to some $3 cap or some other part in a board or the power supply.
Super Eye is offline
post #27 of 43 Old 03-25-2015, 04:13 PM
fierce_gt's Avatar
Liked: 1247
it could be more about the way the market and consumers were in the 80's and 90's, but as a kid growing up with crt, it seemed common for a friend to have a tv repaired. seemed like we all had one or two sets in the basement that were far older than we were, most had seen the inside of a shop at one point or another before they were relegated to the basement. they were the only ones we were allowed to hook the nintendo up to, haha.
again, it's maybe more a trend with the market than a limitation of the technology, it just seems like all the repair shops have closed down, and it's now cheaper to replace a tv than repair it(unless you diy).
post #28 of 43 Old 03-25-2015, 04:55 PM
Super Eye's Avatar
Quoted: 22 Post(s)
Liked: 24
The last TV I took to a repair shop was my year 1995 31 inch RCA home theater CRT. Some little $3 part broke and I was told the damage took out a few other parts and I didn’t get my TV back from the repair shop for a few weeks and the bill was something like $280 mostly for labour - stupid mistake to get it repaired I realized. Then it broke again a couple years later and I ended up buying a much better PQ new year 2006 32 inch Toshiba CRT for $350. I put that in my “concert video cave” and when that broke (probably a $3 part) I replaced it with a $280 HDVT 40 inch flat panel that’s in my concert video cave now.
So when I made my statement “this is true but true for any TV technology whether CRT, Plasma or LCD TVs lit by CFL or LED” I was talking about my above CRTs.
Way back when I was a kid local Walmarts (They were called woolco in my town) still had TUBE TEST machines. Anyone remember those? You plug in your tube - set it to type and voltage and an analog needle gage would tell you if it needs replacement. Hey when my parents were young it was common to get your radio repaired. Much cheaper than buying a new one way back then.
post #29 of 43 Old 03-25-2015, 05:24 PM
fierce_gt's Avatar
Liked: 1247
i remember woolco, but not tube test machines... haha
i guess repairs have always been expensive, but tv's have gotten a lot cheaper since the days of CRT.
that being said, if my f8500 stopped working, i'd look into having it repaired right now. just because there's nothing cheap that could replace it. if my bedroom lcd died, it'd be a definite throwaway.
since we're sharing repair stories, the last thing i had repaired was a cd player for my car. i bought it used for about 100bux, after a year it stopped working. there was a shop that did free estimates so we took it in just to see. my dad ended up paying to get it repaired for me as a bday present, which made it even harder. on one hand i was pissed because he spent about 120bux to fix it, and i'd been looking at one for 200 that was so much better(and new) and now i couldn't buy it, on the other hand i felt super guilty cause he obviously thought he was doing something REALLY nice for me. anyway, that experience stuck with me, and now i generally don't have anything fixed unless i can diy it.
post #30 of 43 Old 03-25-2015, 05:49 PM
Super Eye's Avatar
Quoted: 22 Post(s)
Liked: 24
It was something like this.
ID:	625961   Click image for larger version
ID:	625969   Click image for larger version
