Very Specific Panasonic buzz question (with photos) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 08-01-2015, 03:08 PM - Thread Starter
Liked: 4
Question Very Specific Panasonic buzz question (with photos)
Hey there
I know about the long and storied past of buzzing Panasonic panels and believe me, I've searched for the answer to my question and I've come up empty.
TH-42PX80U 42 inch 720p, made in May 2008
I took off the back and isolated exactly where the buzz is coming from. The buzz is louder when the image on the screen is brighter. It's quite loud.
Here's the rear:
The buzz is coming from this board:
Specifically, this little guy is making the buzz (center of the photo with the yellow tape around it):
My question: is there anything I can do to minimize this piece's buzzing?
Second question: if the answer to the first Q is no- does anyone have any idea what it would cost to take this somewhere and have that buzzing piece replaced.
Thanks so much and I apologize for asking something that I'm sure has been asked in the past (I just couldn't find an answer no matter how many buzzing threads I searched through).
ak2112 2 is offline
post #2 of 6 Old 08-01-2015, 03:16 PM
HLdan's Avatar
Quoted: 442 Post(s)
Liked: 200
Thing is, buzzing is not something that is defective. It's inherent with Plasma technology. It's not a buzzing tube or a chip that needs to be replaced with a non-buzzing one. Lurking around you may see a few people that have Plasmas that claim theirs does not buzz. I'm not buying that. I think they just don't hear it. I have 2 Plasmas of different brands and they both buzz, albeit in different ways, but they both still buzz.
People here have had Samsung and Panasonic "repair" their sets, screens replaced, tightened or loosened screws and the buzzing still happens. The sound is coming out from the screen and that's just they are designed. At this point, save your money and don't look to pay a technician that claims they can stop the buzzing by charing you to replace a part they claim causes the buzzing. Chances are after you've paid them you will be disappointed with the results. Just ignore it and enjoy they beautiful unmatched PQ that Plasmas are famous for. Good thing you're not dealing with an LCD TV. There would be a lot more things you'd be trying to have "fixed" that are not repairable.
HLdan is online now
post #3 of 6 Old 08-01-2015, 03:37 PM - Thread Starter
Liked: 4
Thanks Dan.
I absolutely understand what you're saying. And yes, this set has always buzzed a little. So have all of my friend's Panasonics. It's just how they work.
Mine has currently gotten much louder and that's why I started this topic. I had the tv in storage for a few months, took it out, plugged it in and was greeted by the much amplified buzz that stands out quite a bit unless the volume is raised.
But regardless, your point is well taken. I was just looking for some sort of quick fix/clever thing people here might know about regarding my situation.
ak2112 2 is offline
post #4 of 6 Old Today, 07:00 AM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 271 Post(s)
Liked: 594
Originally Posted by ak2112 2 View Post
.....Mine has currently gotten much louder and that's why I started this topic. I had the tv in storage for a few months, took it out, plugged it in and was greeted by the much amplified buzz that stands out quite a bit unless the volume is raised....I was just looking for some sort of quick fix/clever thing people here might know about regarding my situation.
The TV should be fixable.
That appears to be a transformer, a common failure point on electronic devices and is a common source of excessive vibration and buzzing when they go bad or come loose from the board they're soldered to. There are companies out there that successfully repair bad Panasonic boards. Many defective excessively buzzing Plasmas have been successfully repaired when the source of the buzzing was a defective transformer or coil or board.
Can you identify exactly which board it's on? You can either buy a used or refurbished board, or have yours repaired.
One good place that has repaired boards for AVSers is ModusLink PTS
http://www.moduslinkptstvboards.com/...ir-and-return/
And there are Panasonic service techs on Ebay that can repair your board.
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo Series3 & Premiere, TWC Cisco 8742HDC DVR, Onkyo TX-SR333 AVR, URC MX-780, R40, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #5 of 6 Old Today, 05:45 PM - Thread Starter
Liked: 4
Thank you very much Randy!
It's the powersupply board, specifically the switching transformer circuit reference T601 that is the source of my buzz.
I never even considered ebay, but as I search, I think I now have an idea of what I can do.
Thank you very, very much Randy.
ak2112 2 is offline
post #6 of 6 Old Today, 08:09 PM
"Don't PM Me Bro"
Quoted: 271 Post(s)
Liked: 594
Maybe try gently pushing on that buzzing power supply transformer with a pencil eraser (to isolate you) and see if you can get it to stop buzzing. And examine the transformer for hairline cracks. You may be able to just re-solder it where it attaches to the circuit board.
I found a few old links that may be useful:
Panasonic TH-42PX80U Repair Adventure
!!! FOUND !!! Fix for BUZZ on Panasonic PLASMA 2010
PX80U Service Manual:
http://www.scribd.com/doc/24963802/1...Plasma-Display
_________________________________________
Randy
