How to check hours used on Samsung D8000? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-27-2016, 03:08 PM - Thread Starter
el pablo's Avatar
I have a 64D8000 plasma and was wondering if anyone knows how I can check the hours used? I don't see the option in the service menu like on other Samsung models. Any info is appreciated, thanks!
el pablo is offline
post #2 of 4 Old 07-02-2016, 10:35 PM - Thread Starter
el pablo's Avatar
I'm beginning to believe this isn't possible on these panels for some reason. Can anyone verify? Thanks.
el pablo is offline
post #3 of 4 Old 07-04-2016, 11:49 AM
Steve Zodiac's Avatar
Turn on TV.
Press on remote: Mute, 7, 3, 7, Enter
Hours used is to the right of 'MRT' - around half-way down the menu.
Power off TV to come out of the menu.
This process doesn't reset all your settings.
Steve Zodiac is offline
post #4 of 4 Old 07-04-2016, 01:10 PM - Thread Starter
el pablo's Avatar
Originally Posted by Steve Zodiac View Post
Turn on TV.
Awesome thanks! Does MRT stand for Multiple Render Targets? Do you know how this
differs from PDT (panel display time) that is on other models? It seems those models also display MRT but the two values differ. Thanks again!
el pablo is offline
