colored vertical lines on screen - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 08-01-2016, 06:11 PM - Thread Starter
Liked: 0
Hello,
Make: Samsung
Model: PN50B450B1DXZC
Pictures: http://imgur.com/a/wG0rf
I have vertical lines that are multicolored and go through the menu, as well as appear on the test screen. I have tried cleaning the connections, updating firmware, using a different plug/power bar but it all failed.
I have also found a blow capacitor on the power board. Would that be causing the issue?
Is this fixable?
Cheers,
Tom
tgs.fish is offline
post #2 of 5 Old 08-07-2016, 11:13 PM
PhilipsPhanatic's Avatar
Quoted: 397 Post(s)
Liked: 52
According to a guy I met who services TV's and Samsungs....no.
It's the lousy quality of the circuitry and it happens at random. He does say it could fix itself based on temperature changes, don't ask me why.
PhilipsPhanatic is offline
post #3 of 5 Old 08-08-2016, 10:48 AM
tylerSC's Avatar
Quoted: 721 Post(s)
Liked: 166
I have the same issue with a blue vertical line on a Samsung 51E7000 plasma that seemed to occur after a power surge. I wonder also if there could be a blown capacitor or some other circuitry that could be repaired.
tylerSC is offline
post #4 of 5 Old 08-09-2016, 12:03 AM
Quoted: 51 Post(s)
I started with single vertical line on mine 51f8500 about 1.5 months ago, couple of weeks later it become two. now I have 3 vertical lines and afraid it will only get worse
vavan is offline
post #5 of 5 Old 08-10-2016, 08:51 AM
Quoted: 397 Post(s)
Liked: 52
I was told it's the DISPLAY, not any caps or circuit board parts that could be replaced.
