TH-42PX60U left side 2" screen missing - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 02-11-2017, 11:36 AM - Thread Starter
Liked: 0
Hi,
My tv recently had the issue where the left side of the screen has a yellow bar from top to bottom and then about 2" of the screen are also missing on the left side.
1) Is the service manual available for this TV?
2) Does anyone know what specific board may be failing?
Thanks for your help.
ID:	1959841   Click image for larger version
pby27 is offline
post #2 of 6 Old 02-11-2017, 04:58 PM
Quoted: 269 Post(s)
Liked: 115
Take the back off. Unplug and reset the ribbon cable that is directly under it. Make sure that is goes back in all the way. Might work.
Test Ickles is offline
post #3 of 6 Old 02-12-2017, 08:43 AM - Thread Starter
Liked: 0
Hi,
I disassembled rear cover, removed two screws to ribbon cable and re-seated. Unfortunately not a quick fix.
Any other suggestions?
pby27 is offline
post #4 of 6 Old 02-12-2017, 09:09 AM - Thread Starter
Liked: 0
FYI
I removed the cable again and powered up TV; doesn't quite match the symptom when the cable is connected, for example there is the "yellow" vertical line and about 2" of black (picture missing). When the cable is disconnected there are at least 3" of white.
Could it be a specific board?
The service manual might help; any suggestions on how to get a copy?
pby27 is offline
post #5 of 6 Old 02-12-2017, 04:13 PM - Thread Starter
Liked: 0
Originally Posted by pby27 View Post
Hi,
FYI
I updated the following with an sdcard:
micro program & eeprom
firmware
I ran the self test and everything shows "OK" even though the issue still exists.
Issue(s)
1) yellow line on very left side of screen
2) approximately 2" of left side of screen are black
pby27 is offline
post #6 of 6 Old 02-13-2017, 06:07 PM
Quoted: 269 Post(s)
Liked: 115
Since the quick fix didn't work I suggest starting a thread over here.
http://www.badcaps.net/forum/forumdisplay.php?f=31
I hate to just throw ideas out but C boards are responsible for vertical issues. Or could be A board has an issue.
missing image , panasonic plasma , TH-42PX60U , yellow line
