BruZZi's Thread - AVS Forum | Home Theater Discussions And Reviews
 4Likes
  • 1 Post By BruZZi
  • 2 Post By RandyWalters
  • 1 Post By BruZZi
post #1 of 6 Old 09-14-2017, 12:35 AM - Thread Starter
BruZZi's Avatar
Quoted: 52 Post(s)
Liked: 101
Arrow BruZZi's Thread
How To Check The Hours on Your Plasma
• Panasonic — Consumer Models
• Panasonic — Commercial Models
• Panasonic — Premier VX Models
• Panasonic — UK & European Models
• Fujitsu
• Hitachi
• HP
• LG / Zenith
• Pioneer
• Samsung
• Samsung — UK & European Models
Panasonic
Consumer Models
2013 Models : _X60 / S60 / ST60 / VT60 / ZT60
2012 Models : _X50 / XT50 / UT50 / ST50 / GT50 / VT50
2011 Models : _X3 / S30 / ST30 / GT30 / VT30
2010 Models : _X24 / C2 / U2 / S2 / G20 / G25 / GT20 / GT25 / VT20 / VT25
  • Press and hold the {VOL -} button ON THE PLASMA TV.
  • Then press the {INFO} button on the remote control 3 times.
  • "Start Adjustment Menu" message will be displayed followed by the Service Menu.
    • ADJUST {Picture Adjustment}
    • WB-ADJUST {White Balance Adjustment}
    • OPTION {Option Setting}
    • V-SUS {V-SUS Adjustment}
    • AGING
    • SRV-TOOL {Service Tool}
  • {1} & {2} buttons move up/down through options.
  • Press the {2} button once to select "SRV-TOOL".
  • Then press the {OK} button to access it.
  • Using the cursor keys, highlight the right side
    of the last item "PTCT :00.00.00.00.00" :
  • Then press and hold the {MUTE} button for 3 seconds.
  • Time and Count will be displayed in red color:
    __TIME = Hours : Minutes of operation.
    COUNT = Times the Plasma was powered on.
  • To exit, turn the power off.
    WARNING BY BRUZZI: The {VOL+} and {VOL-} buttons are used
    to change values while in the Service Menu. Make sure not to touch
    those buttons when navigating menus & sub-menus.
2009 Models : _ PX14 / PS14 / C1 / U1 / X1 / S1 / G10 / G15 / V10 / Z1
2008 Models : _ PX80U / PZ80U / PZ85U / PZ800U / PZ850U
  • TC-P54Z1: Press and hold the {VOL -} button ON MEDIA RECEIVER.
    All Other: Press and hold the {VOL -} button ON THE PLASMA TV.
  • The Service Menu will be displayed with the following options:
    • AGING
    (On older firmware(s), hours shown must be divided by 256 for correct value)
2007 Models : _ PE77U / PX75U / PX77U / PZ77U / PZ700U / PZ750U
  • Then press the {RECALL} button on the remote control 3 times.
  • The Service Menu will be displayed with the following menus:
    • ADJUST (PICTURE ADJUSTMENT)
    • WB-ADJUST (WHITE BALANCE ADJUSTMENT)
    • OPTION (OPTION SETTING)
    • AGING
    • RM-SET (REMOTE CONTROL CODE SETTING)
    • SRV-TOOL (SERVICE TOOL)
  • Using the cursor keys, select the right side
    of the last option "PTCT :00.00.00.00.00" :
  • Time and Count will be displayed in red color.
2006 Models : _ PD60U / PX6U / PX60U / PX600U
2005 Models : _ PD50U / PX50U / PX500U
  • The Service Menu will be displayed.
  • Use the {1} or {2} buttons to select "Option".
  • Then press and hold the {MUTE} button on the remote for 3 seconds.
    TIME = Hours of Operation (Hex Numbers)
    COUNT = Times the Plasma was Powered On (Hex Numbers)
    CONVERTING HOURS IN HEX TO DECIMAL (Tip by Jasonbanks )
    In Windows, open the calculator. Click "View" and set it to "Scientific" Mode.
    Select "Hex" and enter the number. Then click "Dec" to convert it to decimal.
Panasonic
Commercial Models
12U / 20U ??? :
  • Press and hold the {VOL -} button ON THE PLASMA DISPLAY.
  • Then press the {RECALL} button 3 times on the remote.
  • The Service Menu (CAT) will be displayed.
    (CAT = Computer Aided Test Menu)
  • Using the cursors keys on the remote, select "SD Mode".
  • And press the Action key { } to access it.
    On the MTBF (Mean Time Between Failure) parameter:
    WT = How many times the unit was powered on
    PT = The cumulative time in hours
  • To exit the SD Mode, press the {R} button.
  • To exit the CAT menu, turn the power off.
8UK / 9UK / 10UK / 11UK:
  • Then press the {STATUS} button 3 times on the remote.
    (Status button is the one above Setup button}
  • To exit the CAT menu, press the {STATUS} button.
  • To completely exit the Service Menu, turn the power off.
3UY / 4UY / 5UY / 6UY / 7UY:
    (Status button is the one below Power button}
Panasonic
Premier VX Models
VX300U Models:
"COMING SOON"
VX200U Models:
"COMING SOON"
VX100U / VX100E :
  • And press the {OK} button to access it.
Panasonic
2011 Models : _
2010 Models : _
2009 Models : _
  • Then press the {0} button on the remote control 3 times.
    • AGING
  • {1} & {2} buttons move through options.
  • To exit, press the {POWER} button on the plasma.
2008 Models : _ PZ80 / PZ81 / PZ82 / PZ85 / PZ800 / PX8 / PX80 / PX81
2007 Models : _ PV7 / PV70 / PV71 / PZ700 / PX7 / PX70 / PX71 / PX72
  • Then press the {0} button 3 times on the remote.
  • The Service Menu will come up.
  • The hours used will be displayed in the right lower corner.
    TIME : Hours and minutes of operation
    COUNT : Times the Plasma was powered on
  • To exit, press the {EXIT} button or turn the power off.
Previous Models :
  • Set the channel to CH99.
  • Select the EQ 12kHz.
  • Press the {HOLD} button on the remote control.
  • The Service Menu 2 will be displayed.
  • Using the {GREEN} button on the remote,
    scroll down to the last Option Menu: "Hours".
  • To exit, press {EXIT} or turn the power off.
Fujitsu
Consumer Models
  • Press and hold the {ENTER} button on the remote
    until the Service Menu is displayed:
    • Monitor Mode A
    • Monitor Mode B
    • Extend Adjust
  • Select "Monitor Mode A" and press {ENTER} to access it.
    Hours Meter:
    To determine total hours, add RGB and video for the total hours on the plasma
    (each number represents hours on that selected input).
    Disregard total hours. That's the number of hours the Plasma is plugged in.
Hitachi
Consumer Models
HDS69 / HDT79 / HDX99 :
  • Using the remote, press the following buttons:
    {MENU}, {MENU}, {8} & {SELECT}
  • Use the {UP} or (DOWN} buttons to select "PDP"
  • The press the {SELECT} buton to access it.
  • Hours used will be shown in the "OPERATION TIME"
HP
Consumer Models
PE-4200N / PL-4200N / PL-5000N
( Rebadged Panasonic PX500 Series )
  • Press and hold the {VOL -} button ON THE PLASMA.
LG / Zenith
Consumer Models
PZ950 :
  • Go to "Home".
  • Then go to "Set Up".
  • Select "Support" from the "Set Up" Menu (icon = a question mark)
  • Select "Product/Service Info" from "Support" Menu.
  • You'll then see hours used, current software version, serial number, and more.
    Thanks Wooty for the info.
PG20 / PG25 / PG60 :
  • Press and hold the {VOL -} button on the remote.
  • Then press and hold the {MENU} button on the TV.
  • After the password screen comes up, press
    the following code: {0} {0} {0} {0}
  • The hours used is shown after "UTT".
    Thanks crkpot for the info.
Pioneer
Consumer Models
5020FD / 6020FD
You cannot access the Service Menu on these models using their regular
remote controls. But there are other ways to check the hours used:
  1. Service Remote Control Models: GGF1589 or GGF1633
  2. Get ControlCAL and then follow these instructions:
    http://www.controlcal.com/forum/showthread.php?t=120
KRP-500M / KRP-600M
PRO-101FD / PRO-141FD
PRO-111FD / PRO-151FD
  1. Set up the Network and use the following address:
    http://<krp ip address>/cgi/service_right.cgi
  2. Service Remote Control Models: GGF1589 or GGF1633
  3. Get ControlCAL and then follow these instructions:
  4. Get KuroReader
4280HD / 5080HD :
  • Using the remote control:
  • Turn off the TV Guide feature.
  • Turn off the power to set the TV into standby mode.
  • Press the {DISPLAY} buton once and wait 4 seconds.
  • Then press {LEFT} {UP} {LEFT} {RIGHT} {POWER} buttons
    within 5 seconds.
  • The Plasma will turn on with the "Information" page displayed.
  • Use the {DOWN} button to select "Hours Meter"
    PANEL = Hours of operation.
    ...MTB = Hours the set has been plugged in.
4270HD / 4271HD / 5070HD / 5071HD
6070HD / 6071HD / 507PU / 607PU
    within 5 seconds.
4360HD / 5060HD
    within 5 seconds.
Samsung
Consumer Models
2011 "D" Models
Coming Soon
2010 "C" Models
  • While the TV is in standby mode:
  • Press the {MUTE}, {1}, {8}, {2} & {POWER} buttons.
  • The TV will turn on with the Service Menu displayed.
  • Use the {UP} or {DOWN} buttons to select "SVC"
  • "PANEL DISPLAY TIME" will be one of the items listed.
  • To exit, press the {POWER} button.
2009 "B" Models: B550 / B560 / B590 / B650 / B850 / B860
  • Press the {INFO}, {MENU}, {MUTE} & {POWER} buttons.
  • Using the {UP} or {Down} buttons, select "Control".
  • Then select "Sub Option".
2008 "A" Models: A450 / A550 / A650
  • Use the {UP} or {DOWN} buttons to select "PDP OPTION".
    or
    Use the {UP} or {DOWN} buttons to select "OPTION BYTE".
  • To exit, press the {RETURN} button and/or turn the power off.
    NOTE: After exiting, all picture settings will be reset to
    default values. So make sure to write down custom
    adjustments before accessing the Service Menu.
Samsung
2011 "D" Models:
2010 "C" Models:
  • Use the {UP} or {DOWN} buttons to select "SVC".
2009 "B" Models:
2008 "A" Models:
8mile13 likes this.
BruZZi is online now
post #2 of 6 Old 09-14-2017, 12:35 AM - Thread Starter
BruZZi's Avatar
Quoted: 52 Post(s)
Liked: 101
Reserved 1
post #3 of 6 Old 09-14-2017, 12:36 AM - Thread Starter
BruZZi's Avatar
Quoted: 52 Post(s)
Liked: 101
Reserved 2
post #4 of 6 Old 09-18-2017, 06:45 AM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 526 Post(s)
Liked: 781
Well this is a blast from the past !
BruZZi and Bruce2019 like this.
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #5 of 6 Old 09-18-2017, 11:37 AM - Thread Starter
BruZZi's Avatar
Quoted: 52 Post(s)
Liked: 101
Proof that I'm still alive.
Bruce2019 likes this.
post #6 of 6 Old 09-22-2017, 07:53 AM
Ozymandis's Avatar
Quoted: 149 Post(s)
Liked: 155
Hitachi P50V701 - 11240 hours.
OLED65B7 | Yamaha v661 | Aperion 5.1 w/ SVS sub | PS4 Pro | Xbox One S | HTPC (i7-7700K, 1080 Ti, Define Nano S)
Ozymandis is offline
