FAQ & RULES LINKS_ Plasma & Panasonic Plasma FAQ - Read First! - Page 46 - AVS Forum | Home Theater Discussions And Reviews
post #1351 of 1376 Old 11-20-2008, 09:19 PM
Abcoon's Avatar
Hi guys! I have a plasma Tv Panasonic 42PV80(Brasil ) = 42PX80(USA) shows some kind of colored lines at the TV's borders. The pics below shows the line you see when you come close to a 42's TV around 0.3 meters with a camera with its macro on. Is it normal to plasma or its a TV model problem, since other guys are having it too?
P.S: Sorry for my bad english.
"It has two ways of in them disconnects of the miseries of the Life :músic and cats" - Albert Schweitzer
Abcoon is offline
post #1352 of 1376 Old 12-05-2008, 07:29 AM
dave42's Avatar
I have a th-50PHD6uY plasma with the extra slot. I want to install a DVI board (TY-42TM6d). Currently there is slot 1 open.
Isn't that the slot that the DVI board must be installed in? I also have the composite/component board and the PC input that I'm using. What are the rules on where they can go? I tried reading the other posts, but they are confusing. Thanks.
dave42 is offline
post #1353 of 1376 Old 12-14-2008, 10:47 AM
Skik's Avatar
Hi,
i'm also looking to find a Full HD 40-42 inch screen.
Now I've found a promotion with the THD-42PF82 for a nice price and 5 years warranty. But I can't find any information about this type. With what version can i compare it? The PZ80? 85?
I hope that there are some people who can help me out.
and by the way, is a 5 year warranty something worth thinking about or is it more of a salles trick?
Greetz.
N.
PS Forgive me for my terrible englisch..
Skik is offline
post #1354 of 1376 Old 12-21-2008, 03:29 AM
Hunter Smith's Avatar
five months ago i purchased a TH-50PZ700A Panasonic plasma Viera tv unit. After several hours of use it has this terrible hot smell coming out of it, there dosnt seem to be any problem with the set apart from the smell, it gets that strong that it gives me a headache, has anybody had this problem.
Hunter Smith is offline
post #1355 of 1376 Old 12-26-2008, 12:17 PM
Jay_Davis's Avatar
Well, there's two possibilities:
- You have a component burning out. That means the set will eventually fail.
- Something fell into the set and is burning. That may or may not cause a problem in the long run (depends what it was and what it fell onto).
Either way you may want to have it checked out.
Jay_Davis is offline
post #1356 of 1376 Old 03-01-2009, 08:26 AM
con771's Avatar
I just got my 46 inch Pz80 and I noticed something very strange. I put all settings on 50 for the break-in period and I noticed that after 30 mins I was motion sick. Also all images look a little blurry when moving. I tried a DVD, HD TV, SD TV, different cables, HDMI and composit. Also tried different settings with no luck. It still happens. The tv is only 6 hours old but it is very strange and hard to watch. However the images with little movement look great. I sit about 10ft away.
Any ideas what this could be or what I can do?
con771 is offline
post #1357 of 1376 Old 10-26-2010, 07:41 AM
_Michaelangelo_'s Avatar
Quoted: 52 Post(s)
Liked: 65
Cheat Sheet - Panasonic Plasma 2010 Consumer Model Summary
* In contradistinction to the Professional models
I don't understand why it is so hard to just find a nice concise SUMMARY of all Panny models. So instead of kvetching about it here is a quick summary in case anyone is trying to sort out all the various models and how they are different.
* References:
http://panasonic.net/avc/viera/us201...on_plasma.html
http://panasonic.net/avc/viera/us2010/index.html
* Detailed description of various Models
http://www.avsforum.com/avs-vb/showt...2#post17866062
Sorted from most features to least features
Code:
Series  Sizes             Example     Res.  3D  HDMI NeoPDP $MSRP Lines
VT25    50,54,58,65       TC-P65VT25  1080  Yes 4    Yes    $xxxx 1080
GT25    42,50             TC-P50G25   1080  Yes 3    Yes    $xxxx 1080
G       42,46,50,54       TC-P42G10   1080  no  3    Yes    $ xxx 1080
S2      42,46,50,54,58,65 TC-P50S2    1080  no  3    Yes    $  xx 1080
U2      42,50             TC-P50U2    1080  no  3    no     $   x  900
C2      42,46,50          TC-P50C2     768  no  2    no     $   x  720
Buyer Beware: Check the Native resolution AND "Moving Picture Resolution" !!!
Notes:
* Lines = Moving Picture Resolution
* All TVs have Component input x2, Digital Audio x1
Q. Black Level Measurements / Issues
* http://www.avsforum.com/avs-vb/showthread.php?t=1167339
* http://www.avsforum.com/avs-vb/showp...postcount=3467
Q. How/Where do I check the manufacture/build date?
* Its on a sticker attached to the back of the plasma. (Thanks Guerillah)
* You can check the date without opening the box. Just pull out the gray tab on the back of the box (it secures the stand) and shine a flashlight up in there. (Thanks MakoCSH)
Q. How does the S2 compare to the G25?
A. TL;DR The consensus is that the G25 has better PQ then the S2, along with THX and a tad higher price.
* http://www.avsforum.com/avs-vb/showthread.php?t=1284948
* http://www.avsforum.com/avs-vb/showthread.php?t=1282416
* http://www.avsforum.com/avs-vb/showthread.php?t=1284207
* Uber Links - Calibration 12th generation
http://www.avsforum.com/avs-vb/showt...7#post17210257
Q. Are floating blacks still an issue?
A. Yes, with the 2010 consumer models and pre 2009 models. *sigh*. V25 is not as bad as the G20/G25.
One of the common test scenes is "The Matrix" blu-ray -- where Trinity is running from the agents; she rolls down the stairs and points her gun up at the window. Black levels reported to shift multiple times.
There have been no reported problems with the professional models.
http://www.avsforum.com/avs-vb/showthread.php?t=1236475
Q. Does a firmware upgrade help?
A. There have been no noticeable differences, sadly. For more information see the model specific threads.
Q. Movie playback - 48Hz or 60 Hz?
A. Some have reported flicker at 48 Hz. The recommended solution is to use 60 Hz.
"Know Thyself" - The Beginning of ALL Wisdom
I've shipped games on DS, PC, PS1, PS2, Wii, and helped numerous companies with PS3 game dev support. Ask me anything about game programming, game design, graphics, or color.
_Michaelangelo_ is offline
post #1358 of 1376 Old 11-03-2010, 07:33 PM
Quoted: 52 Post(s)
Liked: 65
Q. Difference the G and S series panels?
A. (Thanks fatuglyguy)
http://www.avsforum.com/avs-vb/showt...8#post19418048
they use different panels. the G series uses the "infinite black" 5mil:1 CR neoPDP panels, while the S series uses the standard 2mil:1 CR NeoPDP panels. The biggest difference is that the G series bonds the AR filter directly to the panel and thus it uses only a single pane of glass, like pioneer kuro or last year's panny Z1. The S series uses a very annoying double pane and to my eyes, just doesnt have the pop, black level, or color definition that the G series has. Check them out in person and judge for yourself. Most people would agree that the G series is definitely worth the extra cash. Either way, both offer a tremendous value for the money, and a TV like the G series Panasonic have pq far beyond what you pay for them.
post #1359 of 1376 Old 11-29-2010, 11:30 AM
Techno Tonis's Avatar
Read it! Thanks!
Techno Tonis is offline
post #1360 of 1376 Old 11-29-2010, 11:31 AM
Is there a thread that exists to help people make a tv purchase that is right for them?
post #1361 of 1376 Old 11-30-2010, 11:01 PM
EscapeVelocity's Avatar
Quoted: 528 Post(s)
Liked: 290
Hello, I am looking for the link to the site that had the history of changes to the Panasonic Professional Series plasmas. Anybody got it handy?
Epson 8350 / Panasonic AX-200u / Optoma Graywolf 92" / Draper Luma 92"
Samsung 51F8500 / Panasonic P50ST60 / Vizio P502ui-B1 / Sony 50W700B LCD
Sony S790 / Panasonic BDT-220 / Roku 2 XS & Roku 2
Samsung F550 / Speakercraft CS3 / Yamaha YAS-105
EscapeVelocity is offline
post #1362 of 1376 Old 11-30-2010, 11:16 PM
Quoted: 52 Post(s)
Liked: 65
Could you clarify your question please? Do you mean between the different display types: LCD/LED, Plasma, Projector? Or given a specific display type (plasma ) which brand to go with?
Usually it is best to give a budget amount up front, what type of PQ you have in mind, how you plan on viewing (movies/games), and viewing condition (day/night) so people can give their opinion...
Hope this helps.
post #1363 of 1376 Old 12-01-2010, 01:03 AM
Quoted: 528 Post(s)
Liked: 290
Does anybody know bruzzi, I think he was the one with the list of Panasonic Pro models changes through the years.
post #1364 of 1376 Old 12-12-2010, 03:37 PM
IDRick's Avatar
Liked: 24
I clicked on this thread to read the FAQ. Good job putting one together! However, the choice of colors is unreadable (at least to me). Guess I'll look for information elsewhere...
IDRick is offline
post #1365 of 1376 Old 12-12-2010, 08:33 PM
kenabb's Avatar
IDRick,
Did you go down to the very bottom of the page (left side) and see if "AVSForum.com Default" is selected.
kenabb is offline
post #1366 of 1376 Old 12-12-2010, 09:11 PM
IDRick's Avatar
Liked: 24
Kenabb,
Yes. AVSForum.com Default" is selected. The regular forums are very readable but when I click on the FAQ, the colors are yellow, pink, purple, light blue, navy blue, etc. The combinations of colors is very hard on the eyes and therefore difficult to read. I can read it but the present format is very annoying and headache inducing. Thanks for taking a look.
IDRick is offline
post #1367 of 1376 Old 12-14-2010, 11:07 AM
entisnatch's Avatar
I've got a Panasonic G25 and have been unsatisfied with the internet content they provide. The company also doesn't seem to care too much about promoting it...won't even come out with Netflix capability (unless you live in the States...sadly I'm from Canada;-)) Any suggestions on ways to get internet content onto my G25??
entisnatch is offline
post #1368 of 1376 Old 03-01-2011, 07:16 PM
camachinist's Avatar
Originally Posted by IDRick View Post
Kenabb,
Try going to your browser 'View' menu item, select 'Page style' from the drop-down menu and then select 'No style'. It appears this disables style sheets and the page ends up with standard text on a white background. This worked for me with my Mac and Firefox. Otherwise, whoa...
Now, off to read the FAQ
camachinist is offline
post #1369 of 1376 Old 05-18-2011, 01:17 PM
GregF's Avatar
Got a "link can't be found" error when clicking the FAQ. Forgive me for not investigating further, just giving a heads up.
My sincere thanks to everyone who makes AVSforum such an awesome resource.
GregF is offline
post #1370 of 1376 Old 05-19-2011, 02:50 PM
Spaceman's Avatar
Quoted: 41 Post(s)
Liked: 139
I was in a local BJs Brewhouse recently and saw a huge Panasonic plasma over the bar that had 4 programs on the screen at the same time. Didn't get close enough to determine the size or ask about the model number. Does anyone know which model in the Panasonic line this might be? I've tried the Panasonic website without much luck.
Spaceman is offline
post #1371 of 1376 Old 06-10-2011, 09:50 AM
kris achar's Avatar
I think that it must be 65 inches panasonic probably GT25 or VT25 made in the year 2010.
Here is a link to panasonic plasma website but you will find only the 2011 models in the link given below !
http://www2.panasonic.com/consumer-e...00000000005702
http://www.youtube.com/watch?v=fX57AHXtYJs
i.e All the plasmas seen in the above link is VT30 & GT30.
But i feel newer tv's are always better than the previous year model,since the company R&D always incoperate some new things or rectify some minor bugs seen in old models.
By the way if you happen to visit that bar again,you can ask the bar manager,since it could be even 60 or 55 inches model too,one cannot just predict as to what size plasma you have seen there....
Love,
kris.
God Is With You !
kris achar is offline
post #1372 of 1376 Old 08-15-2011, 01:40 PM
tvaddicted's Avatar
Hi,
Reading alot here, thanks for the posted cheat sheet specs. I'm looking for a 46" plasma, [bigger than that might overwhelm my space] and I would appreciate current info on this size, mainly any inherent problems.
leaning toward a panny. I realize any model and any size can be a lemon, but would hate to be on intimate terms with CS or the repair tech. I have read about "buzzing" noise", board failure, PS failure, the dreaded " blink of death"[ which I now have on my sony crt which is 6 years old] "FB" and the list goes on.[ on all sizes and models] I realize I will have to pull the trigger at some point [ probably sooner than later, as the crt is not going to heal itself] but is there any one with a 46 that is really happy?
How do I get the 5 year warranty? Do I have to purchase directly from panasonic for that?
Or is the smarter thing just go cheap and treat as a throw-away?
Please post any opinion/info you have.
I would be really gratefull!
If you have a 46, talk to me!
thanks,
tvaddicted
tvaddicted
tvaddicted is offline
post #1373 of 1376 Old 11-01-2011, 06:41 PM
Jeremy.l.stone's Avatar
x
Jeremy.l.stone is offline
post #1374 of 1376 Old 02-02-2012, 08:23 AM
jack54's Avatar
Quoted: 73 Post(s)
This sticky should be "un-stickied"! because over half the the links of The Official Plasma Forum: FAQ Thread don't work!
What good is that? a waste of time.
It was last updated years ago too:
jack54 is offline
post #1375 of 1376 Old 02-13-2012, 05:31 PM
F27
F27's Avatar
Quite a few people have issues with buzzing it seems, mine makes a slightly higher electrical noise on an all white screen but its inaudible from even a meter away.
F27 is offline
post #1376 of 1376 Old 05-20-2013, 02:22 PM
GBentley0001's Avatar
anyone have a collection of Panny flat panel stands? I need a TY-ST42PA20 or TY-ST08K
(I know... don't laugh... I'm 14 years behind the curve!)
GBentley0001 is offline
