My new Dell W5001C - Page 20 - AVS Forum | Home Theater Discussions And Reviews
Old 06-12-2006, 01:32 PM
jterry's Avatar
No real problems with mine either. I'm on my 8th month of ownership now. Using the SA8300HD box and an upscaling Samsung via HDMI everything looks good. Even most SD channels.
jterry is offline
Old 06-20-2006, 02:29 PM
panafreak's Avatar
I was planning on getting this plasma but was concerned about the VGA input. Does anyone know if VGA will support 1024 x 768 on the plasma? So technically VGA to VGA is HD content if coming from my computer/multimedia center. Any help would be helpful. Thanks!
panafreak is offline
Old 06-21-2006, 05:53 AM
karlw2000's Avatar
Even better is 1360x768!!! You can set up the TV for 1 to 1 pixel mode and it looks beautiful. I recently hooked up a cheap WindowsXP MCE machine and I definitely like to watch DVDs from the PC instead of my upconveting Samsung DVD player that uses HDMI. I bought a long VGA/Audio cable from monoprice.com (cheap) so I don't even have to worry about the audio cable anymore.
karlw2000 is offline
Old 06-27-2006, 08:16 AM
panafreak's Avatar
Thanks for the reply. So, all I need now is a computer to send the signal...So all I need to do is set up my resolution on my computer to 1360 x 768 and 1 to 1 pixel mode on the Dell? Sounds so easy. So this is a true upconverting DVD player then...fullest resolution possible. Why spend money on an expensive upconverting DVD player when your computer can do it already...LOL.
Old 06-30-2006, 06:52 AM
dave123's Avatar
General maintenance question: for those of you who've lifted the W5001C off of it's stand to hang it on the wall, there are dust covers included with the tv to cover the holes left from where the stand was attached. The manual says to make sure to put those caps on.
The other day I was looking for something behind a console that we have under the tv (which is hanging on the wall) and noticed that BOTH dust covers were on the ground under the TV. They must have fallen at some point, but I don't know when. It could have been a couple of months.
What could have happened? Any damage? What should I do now? Just put the caps back on or should i go buy a can of compressed air and blow the hell out of those holes? etc...
Thanks guys!
dave123 is offline
Old 07-16-2006, 05:01 PM
ZZen's Avatar
An owner of of the Dell 5001 wrote a news story about one of the many problem this and other Dell TV's have at digg newsDell HDTV digg news
Check it out and "digg" it so it gets more exposure.
ZZen is offline
Old 12-19-2006, 06:05 PM
rsimieng's Avatar
Hello all, I recently got my w5001c and didn't notice this until after the burn in period when I turned the contrast and brightness up to 40: in the lower half of the screen, about 2 inches from the bottom, 4 inches wide vertically runs this reddish haze across the screen. It only appears when there is a bright background. Unfortunately, I watch plenty of Anime with light backgrounds.
I thought it might be the interference from the power so I re-organized the cables. I also ran the conditioner for 1 hour and that didn't fix it. Checked the different connections and still no go. Any other possible ideas?
Next step: I did order a power conditioner so hoping it might a power issue but considering I live in a brand new high tech condo, I can't imagine that.
Thanks for all your help!
rsimieng is offline
Old 03-05-2007, 09:27 PM
karlw2000's Avatar
Don't know who is still around, but after around 11 months, I returned my Dell to Costco. As had happened to someone else, the bezel paint was peeling off. For the price I paid, I wasn't about to keep this TV as an eyesore.
Old 12-16-2007, 07:06 PM
jterry's Avatar
I still have mine but it is going to bedroom duty soon. I thought I would move up to a 1080P and just hooked up my new Samsung LNT5271. I've never had any problems with the Dell. It's actually been a good TV but it doesn't compare to the picture quality of the 5271.
jterry is offline
Old 01-08-2008, 06:50 PM
tulanejosh's Avatar
I know this thread is very very old and no one is probably even monitoring it anymore. But Im going to give it a go. Im noticing some overscan on my W5001C. I dont particularly like it. Is there anything i can do to correct it? I am conntecting to a Directv HD DVR with an HDMI table.
tulanejosh is offline
Old 01-15-2008, 12:03 AM
techie2's Avatar
Hey,
Try these settings for the display,
Contrast 45
Brightness 45
Sharpness 6
Color Temperature Natural
Color Tint 50
Color Saturation 50
I set the display to these and am a bit happier with it's output now.
Joe
techie2 is offline
Old 03-20-2013, 03:36 PM
piper1113's Avatar
HI...WONDERING CAN YOU HELP ME OUT?....i HAVE THE SAME MODEL,JUST BOUGHT USED......OF COURSE CAME WITH NO SPEAKERS!!!...CAN THESE WORK WITHOUT?....DO THEY HAVE INTERNAL SPEAKERS???...I HAVE A SET OF SPEAKERWS HOOKED TO REAR BOTTOM - AND + CONNECTIONS,BUT NO SOUND....DO YOU HAVE ANY INFO YOU CAN GIVE???.I'd greatly appreciate it...my model is the w5001chd hdtv w pdp......nice picturetalking to DELL SUPPORT is like ebating your head in the wall....and T.V. shops want to sell yuh....shoot me an email if you get time or want to fool with it....Thanks 765 346 6705 317 495 1335 Dave
piper1113 is offline
Old 03-20-2013, 03:41 PM
piper1113's Avatar
Check your connections before you do anything...if you have manual? Check it....if not you can download it complete,it's 67 pages long...DELL.COM....I can't get any sound,have speakers hooked up.....just bought this used..no speakers like what showed up online,so they got me there,also only had time to see a picture...didnt think bout the sound,my bad...anyway do thee have internals,or is it required to have a seperate box ie: cabale box etc.......my cable runs straight in,like an antenea,no box.....can you help???? Dave piper1113 317 495 1335 or just email me....thanks
Old 03-20-2013, 03:50 PM
piper1113's Avatar
YES IT DOES....
Old 03-20-2013, 03:58 PM
piper1113's Avatar
Always make sure to DISCONNECT the power completely before changing "ANY" connections......manual instructs that,so a power strip would be good with an on and off button...
