Official Panasonic PX60/600 Tweaking, Settings, Issues, Technical Thread! - Page 19 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #541 of 7245 Old 05-04-2006, 07:15 AM
jkratze1's Avatar
Originally Posted by futurepannyowner View Post
The HDMI signal is reset when the resolution of the source changes. It does not really bother me, I don't know what the big deal is.
This is my first experience with HDMI and I'm not used to seeing the screen blip with every resolution change. It occurs on first power-on on or whenever I make a change from SD to HD or HD to SD. It is quite annoying and seems like this may be a bug in the HDMI protocol.
jkratze1 is offline
post #542 of 7245 Old 05-04-2006, 08:32 AM
scherer326's Avatar
I just set all my HD channels to 1080i on the STB and for SD channels I set it to 480p. It only has to change once then.
scherer326 is offline
post #543 of 7245 Old 05-04-2006, 09:13 AM
GeorgeRam's Avatar
i would like to thank everyone in this forum. because of this forum i bought the 50" 60u, xbox360, directv hd dvr,and a toshiba hd dvd player. everything looks sweet on my 50" 60u. thanks again
GeorgeRam is offline
post #544 of 7245 Old 05-04-2006, 10:53 AM
emailmeif911's Avatar
Nice!
Thanks for sharing.
emailmeif911 is offline
post #545 of 7245 Old 05-04-2006, 12:24 PM
wtfer's Avatar
Quoted: 234 Post(s)
Liked: 63
Originally Posted by scherer326 View Post
PLEASE ADVISE:
I have the 42px60u and love the picture but for some reason on dark shows or movies (expecially HBO-HD), I see rainbow colors on occasion. What is causing this. Should I adjust something in the settings, i.e. picture?, brightness?, color?, tint?
Need help.
Damn is anybody else but Scherer326 & me noticing this??
I tested a few videogames & the rainbow like after-image is horrible.
It's literally worse then ghosting I seen on any LCD panel.
I mean it's seriously looks EXACTLY like ghosting except, as hard to believe, much worse since the color is always a yellowish blur.
Is there any settings or adjustments, anything in the service menu to lessen this?
I mean one of the few advantages plasma panels had over LCD was no ghosting, seems like all that was a bunch of lies.
wtfer is offline
post #546 of 7245 Old 05-04-2006, 12:27 PM
Elemental1's Avatar
Hmm..did it do this before you hooked up the PC/Game unit?
My HT
In the words of English philosopher Edmund Burke, ÂAll that is necessary for the triumph of evil is that good men do nothing.Â
Elemental1 is offline
post #547 of 7245 Old 05-04-2006, 12:32 PM
SchwettyBalz's Avatar
Originally Posted by dnamertz View Post
I won't be getting an HD STB box from DirecTV with the cost around $500, at least not for a while. I might switch to Comcast HD if they ever get Tivo service.
My DirecTv box does in fact have an s-video out on it, so it looks like I'll be able to run an s-video cable from the box to the TV and then plug the antenna into the TV via the coaxial input?
I love tivo as much as anyone but I went ahead and got a Motorola 6416 from my cable company (Cox). Directv offered me $150 or $300 (i dont remember) off the box and free HD service for 3 months, but I still told them no. My mom has Comcast and I don't really like the software on their box, the Cox software isn't that bad, but its no Tivo. Still, if recording shows is important to you, Comcast software is better than no HD DVR at all.
Xbox: SchwedyBalz
Go Jackets!
Go Bolts!
SchwettyBalz is offline
post #548 of 7245 Old 05-04-2006, 02:39 PM
scherer326's Avatar
wtfer, what are your settings:
Mine are
Standard
Picture: +12
Brightness: +5
Color: -2
Tinti: -5
Sharpness: -5
Color Temp: Warm
Black LeveL: Light
Other settings: Off
This seemed to less the rainbow effect. I thought the effect is suppose to lessen over time, is this correct?
post #549 of 7245 Old 05-04-2006, 05:12 PM
megeed's Avatar
Update: I can't wait, my replacement should be here tomorrow. Sears was pretty nice about it. The most annoy thing was repackaging the TV and loading it into the car. I hope the new doesn't have any issue. I can deal with the buzzing, but the turning off/over heating thing was a major flaw. What are the chances that I get two lemons?
I now debating ordering the VIP622 from dishnetwork. They want $299. I was going to order it today, but at the last minute I realized that the second tuner was on SD, and you can't watch another program on TV1 when an HD program was recording. Any opinions on the VIP622
I also order a mount from Tigerdirect.com. It is only .98 inches off the wall. Hopefully I will have everything done and post a picture.
Originally Posted by megeed View Post
I called Sears, and they said I have to bring it in and then wait for another one to be delivered. Should be two days maybe three. I hope the new one doesn't have the buzzing.
I also bought a monster power conditioner.
megeed is offline
post #550 of 7245 Old 05-04-2006, 06:03 PM
Docism's Avatar
All very good choices! That's awesome George... aren't new toys the best?!
megeed - how in the heck did you get a packaged 50" in a car??? I has an SUV and after I saw the size of the box I wouldn't even attempt to load my 42" set.
Some folks just choose alternate realities, and there's nothing that can be put into words here that will co·ax them out of that.
Docism is offline
post #551 of 7245 Old 05-04-2006, 07:40 PM
dnamertz's Avatar
C. a Panasonic DVD-CV50 DVD player (its 5 years old and I don't even think it has progressive scan...at least its not mentioned in the manual. It also has optical & coaxial digital outputs as well as component and s-video).
Would I be likely to get better PQ from DVDs if I move the cheap $25 Nexxtech DP3222 DVD player from my bedroom and hook it up to my new 50PX60U? Its a cheap model with fewer features than the 5-disc 5 year old Panasonic CV50 DVD player I mainly use now, but the Nexxtech does have progressive scan while it doesn't appear that the Panasonic does. Is the progressive scan important enough that it will creat better PQ from a $25 player than an older Panasonic that cost over $250 at the time?
dnamertz is offline
post #552 of 7245 Old 05-04-2006, 10:36 PM
jamescam's Avatar
I recently picked up the TH50PX60 and loves it! I do however seem to have an issue I was hoping I could get some help with. My DVD player is connected via Composite cable however when I switch over to watch a DVD movie at first the picture is pretty bad with diagnol lines running through the image however after a few minutes they fade away and the picture is crystal clear. I am thinking this is a problem with the Composite cable that I am using (it was a free cable I got with my ComCast box that I don't use since I am using HDMI) but not sure. The DVD player is about 5 years old so it could be that as well. I tried both Composite inputs and the same thing happens on either input. Any advice is appreciated, thank you!
jamescam is offline
post #553 of 7245 Old 05-04-2006, 10:54 PM
soncomet's Avatar
Buy a new dvd player.
soncomet is offline
post #554 of 7245 Old 05-04-2006, 11:12 PM
Artwood's Avatar
Quoted: 60 Post(s)
Liked: 244
Composite cable by definition is the worst connection possible.
Is it just me or does every product discussed here at the forum acused of having rainbows? I bet some of the people that post in could see rainbows on an etch-a-sketch!
Artwood is offline
post #555 of 7245 Old 05-05-2006, 12:14 AM
NathanC's Avatar
Some people see that effect on plasmas. See this thread: http://www.avsforum.com/avs-vb/showthread.php?t=603995 . I've noticed it some while playing GR:AW on my 360, usually on Rocky Cove. Way better than LCDs blurring and bad blacks, though. The world of HDTVs seems to be filled with compromises at this point. I think i've heard it improves over time, though, so i'll be interested in seeing how it looks after a month or so.
NathanC is offline
post #556 of 7245 Old 05-05-2006, 01:13 AM
flossy's Avatar
Nice setup GeorgeRam, damn you make that panel look so sexy
flossy is offline
post #557 of 7245 Old 05-05-2006, 04:38 AM
megeed's Avatar
I meant SUV. I have a Honda Pilot. It fits perfectly.
megeed is offline
post #558 of 7245 Old 05-05-2006, 05:47 AM
High Gear's Avatar
Quoted: 28 Post(s)
this can help us all.
High Gear is offline
post #559 of 7245 Old 05-05-2006, 07:00 AM
Beaner's Avatar
I should be getting mine this weekend and will report later.
I like the idea of having a thread dedicated to settings...saves us from having to sort through the hundreds of other posts.
Looks like you have an "o" in your title instead of a zero.
Might wanna change it so it's not confusing for newcomer looking for this model.
Beaner is offline
post #560 of 7245 Old 05-05-2006, 07:42 AM
ISF_Fred_Md's Avatar
I'm trying to perform a service menu-level calibration and have a few questions that I'm hoping can be answered here. My setup is a Directv HD Tivo and a DVD player, both with HDMI connections. I use an HDMI 2x1 switcher to feed the set one 720p signal. I could use Avia or DVE through my DVD player for calibration, but I prefer to use my Sencor VP300 signal generator.
My questions are:
1) Are the service menu settings specific to each INPUT or each SCAN Rate? My VP300 doesn't have HDMI out, so I was hoping to hook it up using component cables and a 720p signal. If the sm settings are specific to the component input on the tv that I use, this obviously won't work.
2) I noticed that when I enter the service mode, the set goes into torch mode. Is it switching to Vivid?
3) Assuming that the answer to #2 is yes, should I be utilizing Vivid mode all the time, since that is the mode I will be calibrating in the service menu? Currently, I have the tv set to Standard mode, so it creates a problem for calibrating b/c the tv is apparently not staying in Standard mode when I enter the service menu.
And I really do need to calibrate in service mode b/c I want to tweak grayscale.
This is my first panny plasma calibration. I have done a couple panny CRT rear-projectors and I recall similar issues. I'm much more experienced with Mitsubishi, so I appreciate any help. Thanks.
ISF_Fred_Md is offline
post #561 of 7245 Old 05-05-2006, 08:10 AM
scherer326's Avatar
Highgear, what is your color temp set to?
post #562 of 7245 Old 05-05-2006, 08:20 AM
DNero's Avatar
Would these same settings translate to other models in the 60U line? For example, would these TH-42PX6OU settings look the same on a TH-50PX6OU? Anyone know?
DNero is offline
post #563 of 7245 Old 05-05-2006, 08:26 AM
Torr90503's Avatar
Hi
I am browsing this particular thread since few days now and its very informative. Thanks to all the members who are contributing good info on new panasonic plasmas.
I've got 50PX60U for a month now and its been great since. Keeping my settings on Standard, Picture on +9 and Brightness on +5 and others on zero, works for me.
This week I noticed "stream of colors" during NBA Playoff game on TNT, I am still in SD mode. It was appearing on the blazer wore by PHX Suns Coach which had little square design on it and then I notice it on the Tie of the reporter which again had thin lines on it. Sometime seems like a glittering effect. Has anybody else notice it ? I do notice it now during news cast or other programs with similar clothing designs.
Its like a Rainbow, I have read threads about rainbow effect and not sure thats what im experiencing but I see this effect only on certain designs (like small sqaures, close thin lines) where it seems PDP color manager is unable to identify which color to show
Again Thanks to all members.
Cheers
Torr90503 is offline
post #564 of 7245 Old 05-05-2006, 08:28 AM
scherer326's Avatar
probably the same settings would be good for the 37in and 50in I believe.
post #565 of 7245 Old 05-05-2006, 08:55 AM
svgtom's Avatar
Last night I watched the DVE calibration disc and plan to do the calibration later today. One thing mentioned on the disc is that the most ideal color temp setting is Warm. Why is this as I thought Normal was the best setting?
svgtom is offline
post #566 of 7245 Old 05-05-2006, 09:50 AM
High Gear's Avatar
Quoted: 28 Post(s)
it is set at normal. I'll add that. Thanks!
post #567 of 7245 Old 05-05-2006, 10:00 AM
scherer326's Avatar
I talked to the guy who did the review on cnet.com for the 42px60u and he said that the "Warm" temperature is the standard temperature.
I had mine set to normal and changed it to warm recently. I think it looks alot better.
post #568 of 7245 Old 05-05-2006, 10:25 AM
scherer326's Avatar
quick question, with the 60u tv what should you set the STB resolution to for HD:
720? 1080?
post #569 of 7245 Old 05-05-2006, 10:52 AM
mbroadus's Avatar
Quoted: 506 Post(s)
Liked: 147
My settings for Panny Plasma are as follows:
Cinema
Pic. +11
Brightness +15
Color +5
Tint +2
Sharpness +12
Color Temp - Warm
Panasonic P60VT60 Calibrated by Chad B
Marantz NR-1504
GoldenEar SuperSat 50s
SVS PC-2000
AppleTV 3
Sony PS4
mbroadus is offline
post #570 of 7245 Old 05-05-2006, 10:57 AM
AbyRai's Avatar
I have searched the forums alot, where can I find the picture settings for my 42PD60U ...or Can I apply the above settings for PD60U also?
Any help is appreciated...
AbyRai is offline
Panasonic Th 58px60u 58 Inch Plasma Hdtv , Panasonic Th 42px600u 42 Plasma Hdtv Television , Panasonic Th50px600u 50 Inch Plasma Flat Panel Hdtv
