Official Panasonic PX60/600 Tweaking, Settings, Issues, Technical Thread! - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #91 of 7245 Old 03-26-2006, 10:03 AM
Beto3645's Avatar
Originally Posted by Objectivity View Post
Is there a website that tells you what systems do this? I have comcast in Toms River, New Jersey.
I don't know of a website that tells you which cable companies provide unencrypted HD signals. Just try it. Plug your cable directly into the Panny (no STB). Perform a channel scan with your Mode set to All so that the scan includes analog and digital channels. If you get HD channels this way, you are in luck.
In this thread, post #1721,
http://www.avsforum.com/avs-vb/showt...61#post7377361
TXG80R reports that he gets HD channels without a STB via Comcast in Flower Mound, Texas. I get HD channels without a STB via Time Warner Cable in San Diego, California. Is this the beginning of a database?
Beto3645 is offline
post #92 of 7245 Old 03-26-2006, 09:52 PM
dano1122's Avatar
to date, i've only heard of one person successfully hooking up a 60u to a pc via dvi to hdmi. that was with a 6600gt card at 1280x720.
can some of you who have a 60u and have a pc with dvi please report detailed results via dvi->hdmi? thank you.
dano1122 is offline
post #93 of 7245 Old 03-26-2006, 11:03 PM
flossy's Avatar
I was wondering if I should purchase the current OPPO OPDV971H DVD player for my new 42 60u PDP or wait for the newer one coming out in April. Will the new DVD player be a better performer with my PDP?
Any help would be appreciated.
flossy is offline
post #94 of 7245 Old 03-27-2006, 06:07 AM
Beto3645's Avatar
I asked the same question in a different thread. When using my DVD player, an inexpensive progressive scan Toshiba 3950, I thought the picture was VERY good, both through component and s-video. This means that the de-interlacer and upscaler in the Panny must be very good indeed. (I also have the 42-inch 60U.)
Someone replied that the new Oppo will have HDMI but will NOT have a deinterlacer. HDMI might be reason enough to get the new Oppo, which apparently will be less expensive than the 971.
A private e-mail from Oppo said this:
"We will be releasing a new DVD player in April. If you are concerned
about de-interlacing, then you will want to purchase the OPDV971H, as
the new player will not have a Faroujda chipset. However, if you have
an external scaler, or want a universal audio player (DVD-A and SACD
support), then you will want to look into our next product."
Beto3645 is offline
post #95 of 7245 Old 03-27-2006, 06:38 AM
jspirate's Avatar
Originally Posted by TXG8OR View Post
am Switching to Verizon FIOS in 2 weeks so I'll see what differences there are between HDMI and Component inputs.
You are a lucky person. FIOS sure does sound exciting!
jspirate is offline
post #96 of 7245 Old 03-27-2006, 07:59 AM
DNero's Avatar
I have the 50" 60U and I have a general question regaring connecting it to my Scientific Atlanta 8300HD cable box.
Currently, I have it connected HDMI to HDMI via a 1080p-certified IXOS HDMI cable (not a cheap cable). My brother, who installs A/V equipment, tells me that HDMI is crap, and I should have spent that $ on component or optical cables instead.
Now, of course, I'm wondering if component or optical would produce a finer image. What do you think?
DNero is offline
post #97 of 7245 Old 03-27-2006, 09:31 AM
giggle's Avatar
Just picked up my 50px60u on Sat. and hung on wall that night. Set up to my comcast motorola DVR through component right now. I have the pic set on break in mode currently and I am very impressed so far. Colors are great and the blacks seem damn good on HD channels. (of course this is my first plasma). I am also pleasantly surprised by the SD picture as well.
Questions about the break in mode, I read to set as low as tolerable, but how low should it be. I am currently on -16, -14, and 0. (for picture, brightness, and sharpness) Is that good enough. Also should I have it set to lighter or darker for the darkness option?
Any help would be great, thanks in advance!!!
giggle is offline
post #98 of 7245 Old 03-27-2006, 09:36 AM
tangfoot's Avatar
For the previous generation models, the general concensus has been that 0 across the board is sufficient. If you are comfortable with the picture at the settings you listed, then I see no reason to change them.
I've learned that there are three things not to discuss with other people: Religion, politics, and the Great Pumpkin.
tangfoot is offline
post #99 of 7245 Old 03-27-2006, 10:44 AM
Ethek's Avatar
Originally Posted by mziegler View Post
J
3. I've never really worried about surge protectors--any specs/web sites I should consider?
I would look into one that can filter and isolate the power for each outlet in addition to providing surge protection for all outside connections. I wanted something that filtered line noise because I have an aquarium on the same circuit and it uses a fluorescent lamp.
My personal choice was the Tripp Lite HT10DBS. It has a 3750 joule rating and has 3 sets of coax in/outs for my HD Tivo. (two tuners and the OTA antenna), phone and RJ45 hookups.
It was affordable enough that I could get one for every TV location in the house. It seems fairly popular on the forums.
Ethek is offline
post #100 of 7245 Old 03-27-2006, 10:52 AM
TXG8OR's Avatar
I have the a Comcast Motorola STB and am using cheap monoprice component cables and the picture is great. I have a monoprice HDMI cable that I will switch to when I get FIOS and a new STB.
TXG8OR is offline
post #101 of 7245 Old 03-27-2006, 11:52 AM
josephvman's Avatar
Can anyone tell me if the Th-42PX60u will allow the "Just" mode via HDMI input? I've got a PX50u, and one of the things that annoys me is that it won't convert a 4:3 aspect to 16:9 via HDMI, through my HD cable box. I can work around it by using the "Zoom" mode in the cable box, but it takes going through a couple of menus, and it really chops off a pretty good piece of the image.
josephvman is offline
post #102 of 7245 Old 03-27-2006, 12:03 PM
bloviate me's Avatar
Yes. I am running HDMI from the HD Cable box to the monitor and can switch between all of the modes. (Unless I am doing something wrong.)
bloviate me is offline
post #103 of 7245 Old 03-27-2006, 12:18 PM
DNero's Avatar
I can confirm that as well. HDMI from the STB to TV and I use "Just" practically all the time.
DNero is offline
post #104 of 7245 Old 03-27-2006, 01:59 PM
cubanismo's Avatar
I had a question regarding the SD card functionality of the new 60u series. Has anyone been able to view pictures at full screen? I realize the picture will output in 4:3 per say and have bars on the sides, but images seem zoomed out (bars on top and bottom) when viewing them on my 50px60u. Anyone, have any luck in enlarging their images? thanks!
cubanismo is offline
post #105 of 7245 Old 03-27-2006, 03:55 PM
optivity's Avatar
IMO... if you're looking to support 480p (and possibly up converting 480i --> 720p/1080i) over component... it may be worth the wait... but the OPDV971H does a great job up converting 480i --> 720p w/DVI --> HDMI.
optivity is offline
post #106 of 7245 Old 03-27-2006, 03:59 PM
josephvman's Avatar
That's good to hear. I've got a problem with my PX50, and they might be replacing it with a PX60.
post #107 of 7245 Old 03-27-2006, 06:46 PM
CorCentral's Avatar
I reside in TN and use Ben Lomand cable w/Cablecard.
Is there a setting somewhere that when you're watching something you can press a button and see a description of the program you're watching? When I hit the "Recall" button, it only shows the channel, format & time.
If it's because of the cablecard I understand, but if my small 27" JVC has this option and my 4k Panasonic does'nt, I'll be pissed.
CorCentral is offline
post #108 of 7245 Old 03-27-2006, 07:09 PM
tingham's Avatar
Quoted: 62 Post(s)
Liked: 31
I think that feature is only availible with a cable box. You could call your cable company and ask?
Go Phillies! Go Eagles! Go Sixers! Go Flyers!
tingham is offline
post #109 of 7245 Old 03-30-2006, 07:22 AM
cerrato's Avatar
I have a new 50PX60U and I am trying to figure out how to do several things:
1. How can I get the Aspect Ratio I have set for the current input (Cable) to stay the same when I change the input source (DVD), and then change back (Cable)?
2. Is there a way to prevent the CH+/- buttons from doing anything? I am not using an antenna, so if I press these buttons by mistake it always results in a screen of "snow".
3. Is there a way to disable the "TV" and "Video 3" inputs so that when I use the TV/Video button I have fewer items to scroll through?
4. During break-in period should color temp be set to "cool" or "warm"?
cerrato is offline
post #110 of 7245 Old 03-30-2006, 07:53 AM
crippldogg's Avatar
Quoted: 37 Post(s)
Liked: 47
Question for the 42PX60U owners, are you feeding your plasma 720P or 1080i from your STB?? Right now, my STB (motorola 6400 HD-DVR with Cox cable) defaults to 1080i and I'm using component cables instead of HDMI.
The Weekend Warriors
crippldogg is offline
post #111 of 7245 Old 03-30-2006, 09:10 AM
dcgilbert's Avatar
last year at this time new owners of the 50 series panny were finding they couldn't adjust gray scale, color,or overscan in the service menu. what's the verdict on the 60 series?
dcgilbert is offline
post #112 of 7245 Old 03-30-2006, 11:27 AM
hayabusa55's Avatar
Last night, I got done watching Sopranos on my DVR, and I turned down the sound while trying to check the hours. I heard some crackling sound. Automatically, I got scared. I heard things about our sets making noise... The horror!
Turns out, the harddrive on my DVR was recording something... Close one!
hayabusa55 is offline
post #113 of 7245 Old 03-30-2006, 02:29 PM
hayabusa55's Avatar
I am having trouble pulling up Closed Captions... what's all that about?
post #114 of 7245 Old 03-30-2006, 05:26 PM
futurepannyowner's Avatar
I found that my STB defaults to 1080i with component and 720p with DVI. I have mine set to 1080i since most of my HD channels are in 1080i and these new Panasonics handle 1080i wonderfully.
futurepannyowner is offline
post #115 of 7245 Old 03-30-2006, 11:20 PM
dukmahsik's Avatar
hey guys just thought I'd chime in, I bit the bullet tonight and ordered the 50in, it'll be here wednesday! can't wait!
dukmahsik is offline
post #116 of 7245 Old 03-31-2006, 06:39 AM
cerrato's Avatar
- To get the Clock in the Service Menu to work, does the CLK MODE need to be set to 1, 2, or 3? My Clock is not changing from "65".
- How to assign code for TV remote VCR control so that it can control the volume of a Sony stereo receiver ?
cerrato is offline
post #117 of 7245 Old 03-31-2006, 06:50 AM
danny25's Avatar
I'm having a strange problem with my 37PX60U. I can pick up all the local OTA HD channels except two, 4-1 and 8-1. When I'm on those channels the TV says "Poor signal quality". I figured I just needed a new antenna, but I found the signal meter in the menu and those 2 channels both hover around 70% reception, while 11-1 which I can see doesn't even get a signal that good, it hovers around 40-60%. Any ideas? I'm really hoping it's not something wrong with the TV.
danny25 is offline
post #118 of 7245 Old 03-31-2006, 09:09 AM
hidephonish's Avatar
what type of antenna are you using? Signal source maybe far away >30 miles. Also direction of signal might affect. Could try moving antenna around. There are websites that you can plug yr address/zipcode into and show you the OTA signals and direction. here's one: www.antennaweb.org
Hideph
hidephonish is offline
post #119 of 7245 Old 03-31-2006, 11:52 AM
danny25's Avatar
I don't know what type of antenna it is. Its a flat antenna that plugs in to an outlet for power. I tried a regular rabbit ear antenna from another TV in my house and I had the same problem.
I checked on one of those sites and all the major channels are coming from the same direction. And the farthest channel from my house is about 11 miles. I have one more test to do this afternoon, I have a huge antenna in my attic that I'm going to try pluggin it into. If that doesn't work I may have to return the TV.
danny25 is offline
post #120 of 7245 Old 03-31-2006, 01:18 PM
that should work...
I suppose cable is out of the question...
Panasonic Th 58px60u 58 Inch Plasma Hdtv , Panasonic Th 42px600u 42 Plasma Hdtv Television , Panasonic Th50px600u 50 Inch Plasma Flat Panel Hdtv
