Official LG plasma thread - Page 37 - AVS Forum | Home Theater Discussions And Reviews
post #1081 of 1101 Old 08-18-2010, 09:51 AM
MarkRichard's Avatar
LG update for historic reference:
Saturday came and service called to reschedule again because the part didn't arrive. Service guy #1 and service guy #3 arrived on Monday to replace the plasma panel. Total bill now is $1,983. The problem is still there and service guy now says he can't see it, but I do and so does my 9 yr old son. Service guy told LG on the phone that he doesn't see the problem anymore. I said why did you tell LG that you can't see it anymore? My son pointed out the flashing problem very clearly again. Service guy says "oh that problem yes I see it". Anyhow service says they have now replaced everything and this case will be turned over to an LG advocate and I will be called.
MarkRichard is offline
post #1082 of 1101 Old 08-18-2010, 10:01 AM
motogp's Avatar
what your seeing is color shift. its a problem on this unit. but it only shows up on light colored scenes. maybe lg will release a firm ware upgrade to fix it. but for the price we paid, i dought they do anything about it.
motogp is offline
post #1083 of 1101 Old 08-18-2010, 01:09 PM
I can define the flashing problem clearer now that I have studied it. I don't watch the set that much, so in the beginning I didn't notice right away. After watching a few dvd's I started seeing the flashing but thought it was because of the way the film was shot. Then I thought bad dvd. Then bad dvd player. Even though I could see it on almost every dvd I could not find it sufficient enough to show service. I thought the problem might be related to contrast or brightness and if I played with all the settings I could accept a so-so picture if it removed the flashing. But no matter how I re-arranged the settings the flashing still occurred. Contrast, brightness, dynamic contrast, black level etc. settings had little effect on the flashing. That's when I started the first service call. Now after much practice I can show it easily. The dvd Wild Bill' is the best example. Near the beginning of the movie there is a scene showing a prairie like background while they display movie credits in white type. Every time the type appears the entire background gets darker until the type goes away then the background gets lighter. It doesn't have to be white type though this shows the problem best. Any movie scene that has someone turning their hands or face or moving a sheet of paper that is lighter than the background will cause the problem.
post #1084 of 1101 Old 08-25-2010, 09:54 AM
olivluca's Avatar
Try to return it now that you can show the problem: if your panel is like mine (ps8000, but I saw a report of a 50pk950 doing the same) after 1000-2000 hours of usage the flashing will disappear, albeit with very bad blacks, and you'll have no recourse then.
olivluca is offline
post #1085 of 1101 Old 09-01-2010, 01:01 PM
Geoff4RFC's Avatar
Quoted: 317 Post(s)
Liked: 1573
I haven't noticed any one posting one of these, an LG50PS30. I got mine from Costco for 8 and a half about 5-6 months ago and it's beautiful. Took me a couple of months to adjust from the look of my 42" LCD but now it's the "movie" TV
Spinning the rear tire at 150mph while at 3/4 lean angle will put wrinkles in your seat
Set up:
Integra 70.4--Oppo 103--LG50"Plasma--Emotiva: XPA-3, XPA-2 x 2--PolkAudio: RTiA9 x 4--CSiA6--FXiA6 x 4--Epik: Empire x 2--XBOX 360--Furez 10awg homemade cables
Geoff4RFC is offline
post #1086 of 1101 Old 10-30-2010, 07:53 PM
keeganl's Avatar
I was given an LG 42PC5D-UL Plasma that no longer worked. The TV is in great shape, but will not remain on. When i try to power it on, I hear a click on the power board and then the set powers back down. My question is, that I can buy a new power board, but there are at least two different part numbers for the power supply board that fits in the LG 42PC5D. I am unsure as to whether the chassis number makes a difference in the power supply board part number or if they all fit and work in the LG 42PC5D. Any help with this situation would be great. I would love to have a new 42" plasma up and running for under $100.
keeganl is offline
post #1087 of 1101 Old 01-03-2011, 01:49 PM
bugs_bunny01's Avatar
does anyone one the normal operating temperatures for the plasmas?
my tv seems too hot...
bugs_bunny01 is offline
post #1088 of 1101 Old 01-04-2011, 12:13 AM
kyotousa's Avatar
I got the LG PK250...How is LG plasma against burn in playing video game?
kyotousa is offline
post #1089 of 1101 Old 01-05-2011, 04:16 PM
cpierce624's Avatar
I'm about a day away from purchasing an LG 50PK540 but have a question that I haven't found an answer for yet.
When changing the channel, does the picture switch immediately or is there a noticeable (half second or so) lag where the screen goes blank first?
One of my friends has this TV and it has a lag, but they have it hooked up to rabbit ears so I think that might be the problem and not the TV itself.
Does anyone have this TV hooked up to cable and can help me out? A noticeable lag is probably a dealbreaker for me.
cpierce624 is offline
post #1090 of 1101 Old 01-24-2011, 02:24 PM
zairs's Avatar
i have an lg 50pc55 that im trying to get into the other menus, nothing is happening. i hold both menu buttons down the normal menu screen comes up then disapears then the channel apperes then dissapears a few seconds later then the L+R box appears and then dissapears again ive also tried repeatedly taping the menu buttons
i did get a replacement remote a while back, its the same one i think, all the buttons work and it looks the same
zairs is offline
post #1091 of 1101 Old 10-24-2011, 07:53 AM
julianj99's Avatar
HI,
First post. I would like some help and advice.
I bought the above plasma LG42 PT 353. I live in the UK. I have an echo problem on the surround sound. I gather this sort of thing is not uncommon on big-screen setups and I have tried all I can to rectify it via the sound system.
I wonder if I can do something via the LG service menu - eg delay the LG sound a little.
The remote has "Home" instead of menu - which brings up the main menu. I have tried all sorts of combinations of presses but I cannot reach the Service Menu. Any ideas?
thanks
julianj99 is offline
post #1092 of 1101 Old 04-17-2013, 02:06 PM
HDTimeShifter's Avatar
Liked: 37
What are the differences between the 60PN6500, 60PA6500, 60PA6550? The model in Consumer Reports is the 60PA6500. The model on LG's web site is the 60PN6500. Is the PA6500 an older year model and the 60PA6550 just the Sam's version of the older model? Are there any technical differences? (Sorry if this has been covered, but I just started research on 50" plasmas to replace my dying 34" Sony CRT and the 60" LG looks to be the best deal with all competitors twice as much.)
HDTimeShifter is offline
post #1093 of 1101 Old 05-13-2013, 01:51 PM
Noose's Avatar
Quoted: 12 Post(s)
I think the PN series is newer as I just swapped my 2 month old 60pa6500 for one due to a vertical blue line on the screen.
Sony KDL60EX645 LED 60" TV, Bell 9242 sat,Onkyo 608 rec, XBOX 360, PS3, PS4 Paradigm Mon7v.5,ADP-190,CC-290,PW-2200 sub.
Noose is offline
post #1094 of 1101 Old 05-14-2013, 03:23 PM
johnqle's Avatar
Based on your last post, I saw that you have owned both the PA6500 and PN6500.
Would you mind post some review/comparison b/w the two models on the new PN6500 owner thread that I just started?
Your feedback will be very much valuable and appreciated for the rest of us as you can speak for both models... Thanks.
http://www.avsforum.com/t/1472652/official-lg-50pn6500-60pn6500-2013-1080p-plasma-series
johnqle is offline
post #1095 of 1101 Old 05-16-2013, 04:44 AM
Robert Bays's Avatar
I am in NewZealand, and had problems with LG care service in regard to my 50PA6500, it developed a black bulge from the side of the screen, not the pixels but just under the glas, like the glue they bond it with. after weeks of messing around and no replies, i made a comment on the terrible service on their NZ facebook page. the NEXT day, i got a call from the service maneger saying i was getting the new 2013 50PN6500 as a replacement, and an apoligie.
Robert Bays is offline
post #1096 of 1101 Old 09-14-2013, 12:13 AM
stegen's Avatar
Quoted: 94 Post(s)
Liked: 86
How do you get into the screen that lists the hour numbers on a 50pcd50
stegen is online now
post #1097 of 1101 Old 05-03-2016, 08:27 AM
Liked: 0
i bought an LG plasma 60PB5600 16 months ago and then one day it just died. not even status lights will turn on.
i'm eligible for an extended warranty through my credit card company, but they are asking for a copy of the original warranty. i can't find my copy. i've spent forever on LG's website / on the phone with LG and they don't have a copy of the warranty either... hard to believe that is possible. does anyone have a copy of the warranty for an LG plasma they can take a picture of and send to me? thanks so much.
also, any suggestions for what to try to do with TV other than getting a repair would be appreciated.
rb16 is offline
post #1098 of 1101 Old 05-03-2016, 09:00 AM
EscapeVelocity's Avatar
Quoted: 530 Post(s)
Liked: 291
I wonder how the black levels are on an LG PK950
Epson 8350 / Panasonic AX-200u / Optoma Graywolf 92" / Draper Luma 92"
Samsung 51F8500 / Panasonic P50ST60 / Vizio P502ui-B1 / Sony 50W700B LCD
Sony S790 / Panasonic BDT-220 / Roku 2 XS & Roku 2
Samsung F550 / Speakercraft CS3 / Yamaha YAS-105
EscapeVelocity is online now
post #1099 of 1101 Old 05-11-2016, 10:32 AM
Liked: 0
Hi,
I have the 60PB5600 and had a few quick questions:
PICTURE QUALITY:
* Does anyone have the optimal picture setting for this model?
FIRMWARE UPDATE:
The reason is any to update the firmware is mainly due to HDMI negotiation issues - this model has a very hard time connecting over HDMI. It is EXTREMELY hard to get the TV to recognize anything whatsoever which is extremely frustrating. Other TV's including LG TV's recognize the same devices whereas this one does not. It sometimes takes hours JUST to.
* Does anyone know if it is possible to update the firmware on the model and what the newest version is? My installation menu version is v2.6 if it helps.
** UPDATE: I was able to get into the "EZ Adjust menu" which showed the "Module ROM Version" as "60R6_4DA1D0". I was unable to get any information on this anywhere. Is this the newest version? Am I in the correct place and is there another Service Menu besides the EZ Adjust menu? Not sure if Module ROM version is synonymous for the firmware.
REAL CINEMA:
* I am using Expert1 expert mode and" Real Cinema" is grayed out when using HDMI. Pressing info shows "1080p @ 60Hz", but I have a feeling the signal being sent is not 1080p. Is this why this is happening? On Component it is not grayed out. Perhaps it is because the feed is not being recognized as 24p?
Many thanks!!!
E---Man is offline
post #1100 of 1101 Old 10-16-2016, 06:25 PM
MrSilvia's Avatar
Motion Blur
Originally Posted by E---Man View Post
PICTURE QUALITY:
I found a thread on these forums with the settings for this TV and I cant seem to dig up the link anymore, but I'm still on the hunt, so I'll link it as soon as I find it.
FIRMWARE UPDATE:
Do you have a link to the latest firmware update file and process? What I've found online hasnt worked on my TV
Hi all, I'm subscribing to this thread because I'd like to get updates on the conversation. I'm also getting some extreme motion blurring issues I cant seem to crack...
Does anybody know of any solutions to the motion blur issues? This has been happening since I bought the TV and I've even had an LG technician replace the main board in the TV without any resolution.
I'm running a PS4 and XBOX1 through HDMI to a Pioneer VSK-1020 receiver. I've also tried to feed the TV with a clean signal directly from the consoles with the same issues. One thing I noticed in the specifications on this TV though is that it claims that HDMI can only process 1080i, not 1080p, but component can process 1080p? I'm planning on buying an HDMI to Component cable converter to see if the TV can process 1080p from the converter a bit better.
Has anyone experienced this before?
MrSilvia is offline
post #1101 of 1101 Old 10-16-2016, 07:35 PM
MrSilvia's Avatar
PICTURE QUALITY:
E---Man, I found it!
Here is 1:
Any more info on LG PB6600 (or other 2014 model) plasma?
Here is 2:
MrSilvia is offline
